WAM Chapter 4, project #2
I am currently taking a class on microcontrollers and we are using
the What's a Microcontroller text and BOE. I am stuck on project 2
of chapter 4. This project calls for us to design a program that
will run a pushbutton windshield wiper motor with six speeds. We
should be able to speed it up with one button and slow it down with
the other. I've gotten as far as getting the stepper motor to move
back and forth at the given speeds, but I just can't seem to get my
pushbuttons to do anything other than start the first speed. I am
currently trying to use a counter for each pushbutton and adding a
goto command for it to go to the speed that corresponds to the number
in the counters, but this has brought me nothing but a headache from
going over the whole thing over and over. Does anyone have any
advice or info on how I can get myself out of this chapter for good?
Any help would be highly appreciative. Thanks.
Wayne
Wayne
Are you perhaps using the wrong variable to dispatch in your GOTO?
Or, are you reinitializing that varible inside yur main loop?
Posting the code, particularly the loop in question, would help.
Russ
> Wayne
when I hit PB1. It will not change speeds in either direction.
Thanks, Wayne.
counter VAR Word
pb1counter VAR Byte
pb2counter VAR Byte
Start:
DO
pb1counter = 0
pb2counter = 5
LOOP UNTIL IN3 = 1
DO
IF IN3 = 1 AND IN4 = 0 THEN
pb1counter = pb1counter + 1
pb2counter = pb2counter -1
PAUSE 100
ENDIF
IF IN3 = 0 AND IN4 = 1 THEN
pb2counter = pb2counter + 1
pb1counter = pb1counter - 1
PAUSE 100
ENDIF
Speedcontrol:
IF pb1counter = 1 AND pb2counter = 4 THEN
DEBUG "Speed 1", CR, CR
'GOTO Start:
ENDIF
LOOP WHILE pb1counter = 1 AND pb2counter = 4
IF pb1counter = 2 AND pb2counter = 3 THEN
DEBUG "Speed 2", CR, CR
'GOTO Speed1:
ENDIF
IF pb1counter = 3 AND pb2counter = 2 THEN
DEBUG "Speed 3", CR, CR
'GOTO Speed2:
ENDIF
'Speed1:
'DO
'IF pb1counter = 1 AND pb2counter = 4 THEN
' FOR counter = 500 TO 1000 STEP 10
' PULSOUT 14, counter
' PAUSE 7
' NEXT
' PAUSE 500
' FOR counter = 1000 TO 500 STEP 10
' PAUSE 7
' NEXT
'ELSE
' GOTO Speedcontrol:
'ENDIF
'LOOP
'Speed2:
'DO
'IF pb1counter = 2 AND pb2counter = 3 then
' PAUSE 7
' NEXT
' PAUSE 3000
' PAUSE 7
' NEXT
'else
'ENdif
'Loop
counter VAR Word
pb1counter VAR Byte
pb2counter VAR Byte
Start:
DO
pb1counter = 0
pb2counter = 5
LOOP UNTIL IN3 = 1
DO
PAUSE 100
ENDIF
PAUSE 100
ENDIF
Speedcontrol:
'GOTO Start:
ENDIF
[noparse][[/noparse]Bug: Once you push button 1, the WHILE conditon is always
TRUE, which means you won't get past this poing.]
'GOTO Speed1:
ENDIF
'GOTO Speed2:
ENDIF
'Speed1:
'DO
' PAUSE 7
' NEXT
' PAUSE 500
' PAUSE 7
' NEXT
'ELSE
'ENDIF
'LOOP
[noparse][[/noparse]Bug: After button 1 is pushed, pb2counter will become 1
and pb2counter will become 4. This means that the
first IF test after the DO will always be satisfied,
whicl will trap the program in the DO ... LOOP
forever.]
'Speed2:
'DO
' PAUSE 7
' NEXT
' PAUSE 3000
' PAUSE 7
' NEXT
'else
'ENdif
'Loop
[noparse][[/noparse]Same bug as the last one, except with different values
being tested. But the program will never get here!]
I think you only need one counter. PB1 increments the counter, PB2
decrements it. Once it reaches 5, don't increment. Once it reaches
0, don't decrement it.
At first I thought testing bothe PB1 and PB2 was not necessary, but
then I realized that both could be pressed at the same time!
Learn to indent your code! It makes understanding it far easier!
