About AppMods
These are questions for Parallax:
1. What is an AppMod Extension? How far will it extend?
2. What are the dimensions of an AppMod board?
3. What female connecter is used for an AppMod?
4. How many AppMods can be stacked?
5. Can I purchase the AppMod female socket and extenders from Parallax?
I have a couple of ideas in mind for some generally (I think) AppMods
and want to try them out.
Russ
Russ
socket with pins that extend throuh the PCB into a socket below. The
socket is made by Samtec, and they come in various configurations. The
configuration selected depends on the board. For our programming
boards, we just need the sockets without the pins protruding through
past the requirement for soldering. For AppMod boards, we use longer
pins of course so that we can plug into sockets below.
2. I will upload a graphic that shows the standard dimensions and
connector placement of an AppMod board. The "typical" dimension is 2.5"
x 2.5" -- but we make a few AppMods that are smaller (like the RS-232
AppMod).
3. Same -- made by Samtec.
4. There's probably no electrical or physical limit -- just depends on
how the pins are defined and how much current is going to be required by
the various devices. I've seen BOE-Bots with up to four AppMods stacked
on it.
5. We will be adding the connector to our "Component Shop" this week.
-- Jon Williams
-- Dallas Office
From: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=b7vfA49VxTLswdRZdKwTZajwGj01JJioSEqwoWrPR7n6BsD15L1n00U_10qrpEogq6WAQCmqSI01HVdG]home.rr@c...[/url
Sent: Wednesday, February 25, 2004 12:00 PM
Subject: [noparse][[/noparse]basicstamps] About AppMods
Russ
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
* RS-232 DCE AppMod
* 20-pin AppMod extender
* M-F stand-off
* 4-40 screw
* 4-40 nut
* Printed Documentation
My question #1 refers to the above "20-pin AppMod extender". Not sure
it is a necessary item, just curious.
Russ
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> 1. Not sure I understand the question. The AppMod connector is a 2x10
> AppMod).
> on it.
> -- Jon Williams
> -- Dallas Office
> From: russranshaw [noparse][[/noparse]mailto:home.rr@c...]
> Russ
> Yahoo! Groups Links
> abuse@p...
The "AppMod extender" is a Samtec socket that is used to increase the
space between AppMod PCBs.
-- Jon Williams
-- Dallas Office
From: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cXHI9Q8Ak5LP_MdVqjcin4d-o1Pitx4KHlDzdhpc-dUeAwv4zPP0uDyLxMcI1fnbChtWeeJcHm6hpzRZ]home.rr@c...[/url
Sent: Wednesday, February 25, 2004 2:17 PM
Subject: [noparse][[/noparse]basicstamps] Re: About AppMods
The AppMod RS-232 description states that the following are included:
* RS-232 DCE AppMod
* M-F stand-off
* 4-40 screw
* 4-40 nut
Russ
> The configuration selected depends on the board. For our programming
> 2.5" x 2.5" -- but we make a few AppMods that are smaller (like the
> RS-232 AppMod).
> by the various devices. I've seen BOE-Bots with up to four AppMods
> stacked on it.
> -- Jon Williams
> -- Dallas Office
Parallax?
> Russ
home.rr@c... writes:
Please allow me to answer:
An AppMod extension is a 2x10 female header that lifts the AppMod so it will
seat on a standoff at the bottom of the BOE.
2.525 left to right
2.5 top to bottom
It plugs into to the 2x10 female header (AppMod Connector) on the BOE.
Until you run out of I/O ports. I have one stack five high.
If you are talking about the female header on the AppMod that plugs into an
extender, that connector is the same as the extender - a 2x10 dual female
header with long solder tails.
Sid Weaver
W4EKQ
Port Richey, FL
