current capacity of bs2p40
For the bs2p40, the manual states that "the total per 8-pin group (P0-
P7, P8-P15, X0-X7, OR X8-X15) should not exceed 100ma (source or
sink) if using an external 5-volt regulator."
Does that mean that each of the 4 8-pin groups can handle 100ma EACH,
meaning the stamp can handle a total of 400ma on all 32 pins?
>No, as stated "per 8 pin group". There is a per pin limit (one pin only) and a
group limit as well. Both limits MUST be observed. This is true of all Stamps.
The limits vary from Stamp type to Stamp type.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
about the total overall capacity of all the pins. I have 24 LEDs
that I need to light up, each LED sucks 10ma. The way I interpret
the statement in the manual is that I cannot have more than a 100ma
draw for each of the 4 groups of 8 pins. So I'd have 80ma draw on P0-
P7, another 80ma draw on P8-P15, and another 80ma draw on X0-X7.
I just don't know if I'm interpreting the manual correctly.
--- In basicstamps@yahoogroups.com, Bruce Bates <bvbates@u...> wrote:
(P0-
EACH,
only) and a group limit as well. Both limits MUST be observed. This
> Regards,
> Bruce Bates
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
mA but the chip gets very very hot. And, not an the Stamps best day is
it ever going to sink or source 240 mA. You can either change to
low-current (2 mA) LEDS or use buffers to handle the your current
requirements.
-- Jon Williams
-- Dallas Office
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_J47KCzH8kalPDn34EfaZ9L73vUDm48tL721vnjWXheBWBpEKhD5ZhiXtpbAl93Mxh4VCcGSVC3CeBTB]andywatson@m...[/url
Sent: Wednesday, February 25, 2004 10:06 AM
Subject: [noparse][[/noparse]basicstamps] Re: current capacity of bs2p40
Yes, I know that each pin can source of sink 30ma. My question is
(P0-
EACH,
> Regards,
> Bruce Bates
or relays to power the LED's, but I'm working on a quick prototype
for testing, so I was hoping I could just run the LED's from the
stamp, but it looks like I'll have to try something else. Thanks.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Our recommendation is 60 mA MAX for all pins; we've pushed it up to
80
day is
> requirements.
> -- Jon Williams
> -- Dallas Office
> From: andy_watson5 [noparse][[/noparse]mailto:andywatson@m...]
P0-
> (P0-
> EACH,
pin
> > Regards,
> > Bruce Bates
you could 'flash' clumps of LED's then 'flash'
the next clump. Making sure that each clump
did not exceed the 60 mA rating.
80
day is
> requirements.
> -- Jon Williams
> -- Dallas Office
P0-
> (P0-
> EACH,
pin
> > Regards,
> > Bruce Bates
