Converting 3 bit ASCII to a decimal (Byte) number
Hi All:
Well I have managed several projects using the BS2P with great success but
now I am stumped (Doesn't take too mich) . My latest project is using the
stamp to communicate with another microprocesser which runs 20 different
DS1820 temp sensors. The microprosser reports to the stamp via a 9600 baud
(direct connrct TTL) to a PIC buffer which handles flow control to the stamp
(because of the lack of interrupts). The data received from the buffer is a
fixed 3 byter ASCII for each sensor and is not changeable by me. For a
temperature reading say of 87 I will get in ASCII a space then a 8 then a 7
or for 160 I will get a 1 then a 6 then a 0.
I store these readings in SPRAM. At the completion of all sensor data I send
the 3 bytes in ASCII to another PC for display. My need however is for the
BS2P to also convert these 3 bytes in SPRAM to a single decimal (byte)
number. This decimal number will then be used to determine if a (high temp
alarm or Low temp alarm) exists on that sensor. So my question to all is
how do I convert a 3 byte charactor stored in SPRAM to a 1 byte decimal
number. Any help would be appreciated.
Thanks All
Thanks All
TempStr VAR BYTE(3)
MyWord VAR WORD
MAIN:
TempStr = " 16"
GOSUB AsciiToDecimal
debug [noparse][[/noparse]DEC MyWord, 13]
PAUSE 500
GOTO MAIN
AsciiToDecimal: MyWord = 0
FOR I = 0 TO 2
IF TempStr(I) = 32 THEN NextFor
MyWord = MyWord * 10 + (TempStr(I) - "0")
NextFor:
NEXT
RETURN
' Note: the result of doing ' TempStr(I) - "0" '
' is to convert the ASCII value in TempStr(I) into
' a decimal number value for that character.
--- In basicstamps@yahoogroups.com, "Eric Adams" <hugs102@b...> wrote:
> Hi All:
success but
using the
different
9600 baud
the stamp
buffer is a
For a
then a 7
data I send
for the
(byte)
(high temp
to all is
decimal
> Thanks All
required) into your program.
' {$STAMP BS2p}
' {$PBASIC 2.5}
sensor VAR Byte(3)
idx VAR Nib
digit VAR Nib
spAddr VAR Byte
spChar VAR Byte
Setup:
PUT 0, " 87" ' ASCII demo data
PUT 3, "120"
PUT 6, "255"
Main:
FOR idx = 0 TO 2
GOSUB Convert_Str
DEBUG "Sensor ", DEC idx, " : ",
DEC sensor(idx), CR
NEXT
END
Convert_Str:
spAddr = 3 * idx
sensor(idx) = 0
FOR digit = 0 TO 2
sensor(idx) = sensor(idx) * 10
GET (spAddr + digit), spChar
IF (spChar <> " ") THEN
sensor(idx) = sensor(idx) + (spChar - "0")
ENDIF
NEXT
RETURN
-- Jon Williams
-- Dallas Office
-- (972) 659-9090
From: Eric Adams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4h1fSbi7SKRMHBUTegIUXlINRJNqN6ZqQ5SZl79K45bbOqKjgcjd-ENzpMFfoDcoBNa1Qa65t5BKFCoQKzb8]hugs102@b...[/url
Sent: Monday, February 23, 2004 2:01 PM
Subject: [noparse][[/noparse]basicstamps] Converting 3 bit ASCII to a decimal (Byte) number
Hi All:
but now I am stumped (Doesn't take too mich) . My latest project is
using the stamp to communicate with another microprocesser which runs 20
different DS1820 temp sensors. The microprosser reports to the stamp
via a 9600 baud (direct connrct TTL) to a PIC buffer which handles flow
control to the stamp (because of the lack of interrupts). The data
received from the buffer is a fixed 3 byter ASCII for each sensor and is
not changeable by me. For a temperature reading say of 87 I will get in
ASCII a space then a 8 then a 7 or for 160 I will get a 1 then a 6 then
a 0.
send the 3 bytes in ASCII to another PC for display. My need however is
for the BS2P to also convert these 3 bytes in SPRAM to a single decimal
(byte) number. This decimal number will then be used to determine if a
(high temp alarm or Low temp alarm) exists on that sensor. So my
question to all is how do I convert a 3 byte charactor stored in SPRAM
to a 1 byte decimal number. Any help would be appreciated.
Thanks All
This group is great when some of us suffer temporary brain death.
Thanks Again
Eric
Sent: Monday, February 23, 2004 3:01 PM
> Hi All:
the
baud
stamp
a
7
send
the
temp
is
> Thanks All
> Yahoo! Groups Links
