DC Motors, PWM, Cycles
Hello,
When using a DC Motor without an R/C circuit (according to the
documentation it does not need an R/C circuit ) what is the cycles set to?
The formula I have to determine cycles is
Charge time (Cycles) = 4 * R * C.
So without an R/C circuit, what should the charge time be?
Thanks.
Carl
Thanks.
Carl
create an analog output voltage when filtered through an RC circuit (and
buffered with a suitable opamp).
The PWM output is very irregular which is why it doesn't work for
motors, but is good for keeping a capacitor charged to a desired level.
-- Jon Williams
-- Dallas Office
From: cdisalvo0023 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j5oWb4X5zyBVBwpb-SRtn_OWRRzdfVOEi-g484Gt9xOr0hkffAwdsnaQ-pDIufhuxlHPeBOA0p9dPw45VpG9nwY]cdisalvo0023@y...[/url
Sent: Monday, February 23, 2004 1:35 PM
Subject: [noparse][[/noparse]basicstamps] DC Motors, PWM, Cycles
Hello,
to?
Thanks.
Carl
motor. This seems to work.
Is there another command you would suggest to achieve the same goal
(controlling the speed of a DC Motor).
Thanks.
Carl
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> The PWM instruction is not intended to drive motors; it is intended to
> -- Jon Williams
> -- Dallas Office
> From: cdisalvo0023 [noparse][[/noparse]mailto:cdisalvo0023@y...]
> Hello,
> to?
> Thanks.
> Carl
instruction, then... which instruction is appropiate to realize a good
DC motor control?
Yerko M.
Mensaje original
De: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nju1x98A0tkQs_ra6U53uF5OiSk6btV37dCaMt9DAfU9TgSRHnwsVNyAKzi_NE-sU1rRli2cORUbH02TuVKXqw]jwilliams@p...[/url
Enviado el: Lunes, 23 de Febrero de 2004 16:57
Para: basicstamps@yahoogroups.com
Asunto: RE: [noparse][[/noparse]basicstamps] DC Motors, PWM, Cycles
-- Jon Williams
-- Dallas Office
From: cdisalvo0023 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mshwuXOpPrbYKG2f7OdP2yOssDORaq5RBeVSdNRhGky4o9pyo5piBs-EerU7D_oyPFcg9snshFW4PcTdpM9A]cdisalvo0023@y...[/url
Hello,
to?
Thanks.
Carl
Yahoo! Groups Links
direction. Schematics, boards and programs can be found there.
jim
http://www.geocities.com/jimforkin2003/
From: Yerko Melgarejo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KiYKXevFWmLnWpXxjnYpCowst2XMsR33XNf0Mll0Z8Zim_typBWvlPuVm1l1FbS23VQZ-BZkipdC3O60a17pmqk]yerkomelgarejo@t...[/url
Sent: Monday, February 23, 2004 9:10 PM
Subject: RE: [noparse][[/noparse]basicstamps] DC Motors, PWM, Cycles
Hi, i have a similar problem with a DC Motor control using PWM
DC motor control?
Yerko M.
Mensaje original
De: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SPSbcEiwnqFD5cOPK_CGza3NPByyXjX6SLMvJ7zYlapESgrXDN7EHAWOSCHbYXJnI4D-H8PZqQze-u-ItKUoxA]jwilliams@p...[/url
-- Jon Williams
-- Dallas Office
From: cdisalvo0023 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=78KpYUs85ZWamivAh1s_0JHP0dssEzQmmnh4vBQW3V_JEihiLEC8T3MXxwUVO534XdNOy257JwRO0LgmW5Sb]cdisalvo0023@y...[/url
Hello,
to?
Thanks.
Carl
Yahoo! Groups Links
Yahoo! Groups Links
have two aspects.
POWER available. You can't drive a motor that wants more current than
your supply can provide.
NOISE A dc motor generates a humongous amount of electrical noise
which might cause problems.
In General - PWM is an excellent means of speed control (as long as
it is used properly.)
>DC motor control?
I never teach my pupils; I only attempt to provide the conditions in
which they can learn.
- Albert Einstein
