logic level mosfet VS. relay
In another thread, a logic level mosfet, like an IRL520 is
recommended instead of a relay. Is a logic level mosfet much faster
than a relay?
I am currently using a transistor and relay to control on/off for a
drill. Same setup for forward and reverse. Would it be beneficial
to switch to a mosfet?
I have switched drills. I am now using a 6VDC cordless drill.
Frank
than a relay?
Frank
or so. From memory, a typical relay may take 5 to 10 mS to close.
If turn on and turn off speed is not a concern, as I think is the case for a
drill motor, the transistor relay combination is just fine in my opinion.
ken
than a relay?
Frank
Starting is no problem. I modified my code so I wouldn't overshoot
my destination. I stop prematurely and inch up on the desired
measurement.
I may try the MosFet or switch to a DC Motor controller.
Thanks for the info!
Take care,
Frank
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> A logic level MOSFET is indeed much faster than a relay, by a
factor of 100
case for a
opinion.
> ken
faster
> than a relay?
> Thanks,
> Frank
The MOSFET has a much faster switching time. I would imagine that unless you
are using the drills in a robot for motion that the relay will work fine. When
the DC motor starts, stops and runs it generates lots of electrical noise.
The relay will isolate that from your control circuit. Im not sure what
protection the MOSFET will need to drive a DC motor.
The pullin time of the relay (5 to 100 ms.) is usually not a concern if you
are still drilling. The motor will take as much time to come up to speed so
turning it on 5 ms faster may sound good, but, like the EPA mileage ratings on
new cars, is not going to buy you much.
Hope this helps,
Alan Bradford
Plasma Technologies
In a message dated 2/22/2004 9:07:09 PM Eastern Standard Time,
franksmith512@y... writes:
than a relay?
Frank
--- In basicstamps@yahoogroups.com, plasmastamp@a... wrote:
> Hi Frank,
unless you
fine. When
noise.
what
concern if you
speed so
ratings on
> Hope this helps,
> Alan Bradford
> Plasma Technologies
faster
> than a relay?
> Thanks,
> Frank
