Variable voltage
Hey group!
I don't know how to accomplish this, so I thought I would ask for
your assistance. I need to be able to send a command from the Stamp
that will somehow convert to a voltage used to run the voltage control
on a 555 timer chip (to vary the frequency). However, I have to only
just output a command for a brief time as the stamp will be performing
other routines, but I need the voltage to stay on all the time. The
voltage value will only be changing every second, but will be
constantly happening as opposed to a one time event, so I need
something reliable that won't readily wear out. Let me know your
thoughts. Thanks!
thoughts. Thanks!
>Hey group!
>thoughts. Thanks!
>Look at digital potentiometers,
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
I just figured out how to use a digital pot the other day. Very handy and
will do what you want. I have a code snip for the MCP41050, and it should
work with any of the Microchip pots. Dallas/Maxim also makes pots that are
just as easy to use.
Jonathan
www.madlabs.info
Sent: Friday, February 20, 2004 1:25 PM
Subject: [noparse][[/noparse]basicstamps] Variable voltage
> Hey group!
> thoughts. Thanks!
> Yahoo! Groups Links
handy and
should
that are
> Jonathan
Hey there!
Thanks for the reply. I wasn't sure if a digital pot would wear
down over time or how well it would work having to change so often,
but everyone seems to feel that it would do well. The basic code for
using one would be very much appreciated. Also, what's your opinion
on how well these things last. As I said, it will be switching quite
often, but in small increments. What's happening is that this is part
of a variometer project I've been working on for quite some time now.
It's an instrument used for hang gliding to tell us if we're in lift
and how fast we're going up. Most have an audio option so that you're
looking at where you're going and not at the screen. the frequency
and beep rate get higher and faster as you get faster. The variometry
is being calculated in the Stamp, so I needed some way to put out a
varying voltage to control a 555 timer to change the frequency and
beep rate. This will also explain why I need something that will last
because of the constant use. Anyway, that's what I'm looking at. If
you feel a digital pot will handle this, then great. Thanks again for
the help.
David
I can't say how long they will last. I am just using my first one in a
circuit I am working on. I can say that they are fast and accurate so far.
Here is a code snip for a MCP41XXX:
cs con 0
clk con 1
si con 2
potData var word
potSet var potData.lowbyte
potData = %00010000100000000
main:
pause 100
debug "PotSet: ", dec potSet,cr
low CS
shiftout si,sck,msbfirst,[noparse][[/noparse]potData\16]
high cs
if potSet = 255 then
potset = 0
goto main
endif
potSet = potSet +1
goto main
That should get you up and going. You can get a free sample or two from
microchip, just go to their website.
Jonathan
www.madlabs.info
Sent: Saturday, February 21, 2004 6:11 AM
Subject: [noparse][[/noparse]basicstamps] Re: Variable voltage
> handy and
> should
> that are
> > Jonathan
> Hey there!
> the help.
> David
> Yahoo! Groups Links
simple stepper motor drive. The circuit works very well for small steps.
There are no moving parts in a digital pot to wear out. I have some units that
are
5 years old and still working fine.
I use the Analog Devices AD7376, but the Microchip units are just as good.
Good Luck,
Alan Bradford
Plasma Technologies
In a message dated 2/21/04 9:13:28 AM Eastern Standard Time,
geckoinc99@y... writes:
handy and
should
that are
> Jonathan
Hey there!
the help.
David
Another state of the art option would be a direct digitally
controlled oscillator like the
Linear Tech LTC6904 ($3).
http://www.linear.com/prod/datasheet.html?datasheet=1067
The frequency range of this one 8-pin chip is 1khz to 68mhz--right, 1
kilohertz to 68 megahertz--I2C or SPI input and complementary clock
outputs. Four control bits set the octave (1 to 2 khz, 2 to 4 khz,
etc) and then the resolution over that octave is 10 bits.
-- Tracy
