Can''t program from laptop
You did not mention if you are using a USB
to serial adapter with the laptop -- some
of these (especially the ones to connect
PDA's) don't work with the BS2.
Bafo and Keyspan are good brands of USB
to serial converters which work well.
Second thing: You may need to set your
FIFO on your laptop serial port to 0.
Toshiba's are infamous for this.
--- In basicstamps@yahoogroups.com, "wheatenuk" <alex.meek@d...>
wrote:
> Fairly new to all this but I've managed to create a shift light for
> my racing car.
> To date I've used the desk PC to load the program, but decided I
> should take the laptop out with me when testing in case I need to
> alter the code. However whn I use the same serial cable with the
> laptop, as soon as I start the download, the stamp restarts, and
the
> editor reports a 'hardware communications error'.
> if I move the cable back to the serial port on the desktop PC it
> works fine.
> Anyone know why this may be ?
> thanks
> my racing car.
the
> works fine.
> thanks
