help with -1.0v to 1.0v variable output circuit
Kind Sirs:
I am a newbie to basic stamps, but having built a couple of
circuits am having a ball!
We need to control variable voltage from -1.0 to 1.0 volts, (1mA)
in maybe 10 mV increments. Could someone point me in the right
direction? Basic Stamp cookbooks have circuits 0-2.5V, 255 steps but
I cannot find any that can span into negative values.
Thank you for looking at this!
Curtis
Curtis
First of all, you need two power supplies, one positive (typ: +5V) and
one negative (typ: -5V). This allows you to produce an output voltage
that ranges from +1V to -1V. You can purchase power supplies with plus
and minus outputs or you can easily build one out of two wall-warts
and two regulators(positive and negative).
The complete +1V to -1V circuit would consist of the following items.
1. Positive and negative power supplies, with a common ground.
2. BS2p Stamp (provides 2-wire I2C serial output to DAC)
3. MAX517 8-bit 2-wire serial DAC (digital-to-analog converter)
4. Three op amps (typ: use an LM324 which contains four op amps)
I suggest connecting the above components in the following manner.
1. The Stamp and DAC would run off the +5 supply.
2. The LM324 runs off +5 and -5 supplies.
3. The Stamp I2C output (2 pins) connects to the DAC and sends 0-255
serial data
4. DAC generates 0 to +5V output (in 256 steps)
5. Resistor divider on output of DAC reduces span to 0 to +2V
6. 0 to +2V goes into the positive input of the first non-inverting,
unity gain op amp (which acts as a buffer)
7. The second op amp is used to provide a buffered -1V reference.
8. The output of the first op amp is summed with the -1V reference in
the inverting input of the third unity-gain op amp.
9. The output of third op amp will be your desired -1V to +1V in 256
steps.
If you are not familiar with the general circuits described above I
would suggest referring to "Practical Electronics for Inventors'" by
Scherz, available from Amazon.
BTW, you could use any type of Stamp, not just a BS2p, to control a
parallel DAC (typ: AD558), but it would tie up at least 9 pins on the
Stamp.
Dave
--- In basicstamps@yahoogroups.com, "flightline2004"
<flightlinemail@c...> wrote:
> Kind Sirs:
> Curtis
wrote:
> Curtis,
and
voltage
plus
I'm thinking a center tap transformer. If you don't ahve two wall
warts already. then a 7805 and 7905 Voltage regulators(s)
items.
> serial data
PWM output from the Stamp would offer 256 steps and use the first of
the op-amps as the buffer.
in
> steps.
the
> Stamp.
> Dave
Heck Dave, ya almost got a Stamp Project all written up !
Dave
> > Kind Sirs:
(1mA)
but
> > Curtis
One way to generate the negative power supply for 1 ma of current is
to use a chip like the '7660 charge pump.
Here is a circuit that can operate from the PWM output of the Stamp:
400k 100k
Vdd --/\/\----o
| Vdd |
100k | >
o---Vout= Vin*1.25 - 1.25
Vin---/\/\-o----|+/
P0 | |/|
0.1=== | -5v ;
uf | `
| 7660 |--Vdd
Vss `
`--o--o---Vss
Vin Vout
0 -1.25 PWM 0,0,100
0.2 -1.0 PWM 0,10,100
1 0 PWM 0,51,100
1.8 +1 PWM 0,92,100
2 +1.25 PWM 0,102,100
The resolution is only about 20 millivolts, less than you asked for,
but that could be improved with one more op-amp scale down the PWM.
You can find the '7660 circuit in many references.
-- Tracy
>Kind Sirs:
>Curtis
side, consider an op amp with the + pin biased to 1/2 the power supply
voltage. (use a simple voltage divider). This +2.5 volts now becomes the
output's ground so it must be isolated from the stamp ground. Let's consider
using a 5 volt supply for this circuit. The bias voltage (new ground) is
now 2.5volts. An input above 2.5 volts will be one polarity, an input below
2.5 volts will be the other. If the circuitry you use inverts the inputs,
and has a gain of one, a +3 input will result in a -.5volt output and an
input of +2volts will result in a output of +.5 volts; both in reference to
the new ground. I hope I didn't confuse you. Breadboard the circuit and
play a little and it will make more sense. This will allow the device to
operate with only one power supply.
Jim
http://www.geocities.com/jimforkin2003/
From: barrowman11 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZT3f-rSik0aUWRYTmNtx4LMkEkMl7P7O7HVXwKmmp40ckj_5iEcyPtpHhl-OJPnHQKd0DbmQSbzB32MG]barrowman11@y...[/url
Sent: Saturday, February 21, 2004 12:22 AM
Subject: [noparse][[/noparse]basicstamps] Re: help with -1.0v to 1.0v variable output
circuit
Curtis,
serial data
steps.
Stamp.
Dave
> Kind Sirs:
> Curtis
Yahoo! Groups Links
