Need Help Increasing the Scaling Range for a Servo.
I have an RC circuit using a .1uf cap and a 10k variable resistor.
My RC time values are 1 all the way clockwise (min resistance)
and 605 all the way counter clockwise (max resistance)
I have no problems scaling these values with an offset to get servo
movement (duration) from 500 to 1000 but I would like to increase
the movement (duration) to 350 to 1150 which I have proven to be the
max servo movement range.
To get my values I performed the following:
time (Maximum) 500/605 = .827 * 605 = 500
time (Minimum) 500/605 = .827 * 1 = .827
After my values were scaled I added an offset:
time (maximum) = 500 + 500 = 1000
time (minimum) = .827 + 500 = 500
In my code I used the following commands:
BTW time is my Variable
time = time */ 212 ' Scale by .827 (x 256 for */)
time = time + 500
I then took time and used it as my duration argument for the servo
for positioning.
Everything works fine other then the fact that I can't seem to
figure out out to increase the range of movement. I want the
(Duration) argument to range from 350 to 1150.
Can anyone help point me in the right direction. Any help you can
offer would be greatly appreciated.
Lu Kwan
time = time + 500
for positioning.
Lu Kwan
Your span is now 1150 - 350 = 800. And the offset is 350.
duration = time */ 339 + 350
' */339 because 800/605 = 1.32 = 339/256
' division by 256 is implied in the */ operator
-- Tracy
>time = time + 500
>for positioning.
>Lu Kwan
I appreciate the help, I will try that out this evening when I get
home from work.
Lu
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Lu Kwan
> -- Tracy
servo
the
> >time = time + 500
> >for positioning.
> >Lu Kwan
