BS2 & the ISD25120
Hello,
I am working on a project with the BS2 where I am trying to make it completely
control the ISD25120 without using pushbuttons. There are 4 different messges I
want to play at 4 different times. It is supposed to play a message and then go
perform a function then come back play another message and then go perform some
other function and it will continue this process until it is done. I believe the
problems that I am having are a result of timing issues and possibly the PULSOUT
function on the BS2. If someone has any suggestions or sample code I would
appreciate the help.
Walter Carpenter
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
Walter Carpenter
Do you Yahoo!?
http://www.parallax.com/dl/docs/cols/nv/vol2/col/65.pdf
-- Jon Williams
-- Dallas Office
From: Walter Carpenter Jr. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SYaQzFMu4FKxBH584cZLwPUJVVUDocb9-PAFTUt3rEQROT8BVr6PmoJCUp3rT_kLJU5h8OCmLBm2fik]walterc33@y...[/url
Sent: Wednesday, February 18, 2004 1:15 PM
Subject: [noparse][[/noparse]basicstamps] BS2 & the ISD25120
Hello,
completely control the ISD25120 without using pushbuttons. There are 4
different messges I want to play at 4 different times. It is supposed to
play a message and then go perform a function then come back play
another message and then go perform some other function and it will
continue this process until it is done. I believe the problems that I am
having are a result of timing issues and possibly the PULSOUT function
Walter Carpenter
