BCD to binary converter
I need my basic stamp to control 16 different lights, so I figure
that I could just use 4 pins on the stamp to control a 4-digit BCD-to-
binary converter, which would mean I would use 12 less output pins on
the stamp. But I'm having trouble finding a BCD-binary chip.
Does anyone have any good suggestions for a BCD-binary chip?
This is not technically BCD, by the way (I resisted the urge to say BCD,
BTW).
Al Williams
AWC
*NEW Kits: http://www.awce.com/kits.htm
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BoLZoA7CUTtHYP7rX1WdjFzgtukhGa1w_kMllM73nK-_WUEB5uJADkg-4s5ygI5sy3oUKcE-0cc63XWg]andywatson@m...[/url
Sent: Wednesday, February 18, 2004 8:30 AM
Subject: [noparse][[/noparse]basicstamps] BCD to binary converter
Yahoo! Groups Links
to either question, you might consider using a couple of daisy-chained
74HC595 shift registers. Using just three pins you can control 16
outputs in any combination. And if you decide to go to 24 outputs you
just have to add another '595 to the chain.
Our StampWorks book shows how to use the 74HC595 with the BASIC Stamp
and how to string them together.
-- Jon Williams
-- Dallas Office
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QvDFhmTPFaveRDL7NHWelIHHIMBu1OZ02cE911zL1vnpoAGBtwBpEMfRJsCNI1h7EvYdw-w0s_qwMO9L2tw]andywatson@m...[/url
only provides 16 mutually exclusive outputs. I will need to control
the 16 outputs in various combinations, so I'll investigate the
74HC595. Thanks.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Do you need to have more than one light on at once? Or all off?
If yes
chained
you
Stamp
> -- Jon Williams
> -- Dallas Office
> From: andy_watson5 [noparse][[/noparse]mailto:andywatson@m...]
to-
on
16 outputs. In both cases, the extra pins would have more functions,
although in your case you probably don't care. Also with the PAK-IV you can
get some concurrency as the PAK does one operation and the Stamp does
another. Probably not important in this case though.
Now if you want to dim the lights... the PAK-Vc will handle 8 lights per
chip and you can gang them to drive a large number of outputs.
Al Williams
AWC
*New Universal PCB for any Basic Stamp
http://www.awce.com/asp3.htm
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ih93-Vc_EINTqfRzHrP4J2RDoOOm1u8hSZ1XkOSfZHthfaJL7jGj24HUSSQ2h9-pP5dkT95DBOyTUM_QKw]andywatson@m...[/url
Sent: Wednesday, February 18, 2004 10:22 AM
Subject: [noparse][[/noparse]basicstamps] Re: BCD to binary converter
Yes, I just looked at the datasheets for the 74154, and I see that it
74HC595. Thanks.
If yes
chained
you
Stamp
> -- Jon Williams
> -- Dallas Office
to-
on
Yahoo! Groups Links
22 outputs, which makes 31. So I've only got 1 free I/O, which
leaves little room for expanding the program/circuit later. I might
also be able to use 74HC595 shift registers to shrink the number of
inputs using SHIFTIN as well, but since I'm new to all this BASIC
stuff, I'm a little overwhelmed right now. Just looking for a simple
high pulse on a pin is easy. But using shift registers and loading
data into the stamp just doesn't make sense to me. Maybe if I stare
at it long enough, I'll understand it.
Thanks for all the advice guys.
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Probably overkill, but you could always use a BS2P/40 or add a PAK-
IV to get
you can
does
lights per
> Regards,
> Al Williams
> AWC
it
control
> 74HC595. Thanks.
> If yes
> chained
16
> you
> Stamp
> > -- Jon Williams
> > -- Dallas Office
BCD-
> to-
> on
Subject and
> Yahoo! Groups Links
