eb500 connection LED
I'm using eb500 bluetooth module with BS2sx. Do you know why the
connection status LED is always on even though there are no
bluetooth device around.
I also use another bluetooth module ROK 001 007, I can program this
ROK module to discover and establish connection with the eb500. But
I can't send or receive data between the two modules at all.
Pls give me some advice on this, thanks alot,
VT
VT
to the Mode Pin of eb500, the connection status LED is on as if
there's active connection with another bluetooth device already.
There are some things regarding the Bluetooth command
Create_Connection parameters: packet type, page scan repitition
mode, page scan mode, offset that the eb500 used. I want to know
these because I use another Bluetooth module (ROK 001 007) to send
the Create_Connection command to the eb500, but the connection
failed. So I doubted that maybe the 2 modules don't understand each
other. Am I right? Pls help, thanks.
(ps: I can use the ROK module to discover the eb500 module)
--- In basicstamps@yahoogroups.com, "VT" <a2vutuan@y...> wrote:
> Hi,
this
But
> VT
