ir-buddy simple problem
Ok, I have an ir_buddy connected to pin 15 and running the stock
program from parallax.com for the loopback test. its telling
me "Timeout Error - check connection" none of the other programs work
properly either. I sent the ir_buddys back and they told me they were
fine. I am using a BS2P24 and I am getting really frustrated. This is
making me feel real stupid.
Is it supposed to tell me this? I tried the program for sending and
receiving RC5 codes with my learning remote and it didnt not receive
anything, that program also told me time out error. the wire runs are
not long. everything is on the demo board.
wire-run to an IR_Buddy. The attached program
should set up the IR_Buddy properly, then wait
for you to press a key on the remote. It should
then output the keypresses.
Note you have to set your remote code for
RC5, or Phillips, for this to work. Note you
also have to connect your IR_Buddy to +5 and
ground, as well as the signal pin.
' Simple IR_Buddy Test Program
SerBaud CON $4000 + 84 ' 9600 baud, inverted
IR_Baud CON $8000 + 84 ' 9600 baud, Open mode, NOT inverted
IR_Pin CON 2 ' Or whatever data pin you have the IR_Buddy on.
IRDat VAR BYTE(8) ' Use locations 0..7
INIT:
GOSUB IR_Buddy_Reset
MAIN:
GOSUB ClearData
GOSUB IR_Buddy_GetData
GOSUB PrintData
PAUSE 500 ' Wait 500 mSec and go around again.
GOTO MAIN
END
IR_Buddy_Reset: ' Reset Cycle
LOW IR_Pin ' Set pin output, and low
PAUSE 5 ' Hold for 5 mS
INPUT IR_Pin ' Set pin High Impedance
PAUSE 50 ' and wait 50 mS, to complete init
RETURN
IR_Buddy_GetData:
SEROUT IR_Pin, IR_Baud, [noparse][[/noparse]$74, 10] ' $74 == Setup to get data to BS2
' 10 == Wait 10 mS before
' sending data.
SERIN IR_Pin, IR_Baud, [noparse][[/noparse]STR IRDat\8\255]
' Get 8 bytes, or to first '255'
RETURN
PrintData:
I = 0
NextByte:
IF (I = 8) OR (IRDat(I) = 0) THEN PrintDone
' else
SEROUT 16, SerBaud, [noparse][[/noparse]DEC IRDat(I), ", "]
I = I + 1
GOTO NextByte
PrintDone:
SEROUT 16, SerBaud, [noparse][[/noparse]13] ' Linefeed
RETURN
ClearData:
FOR I = 0 to 7
IRDat(I) = 0
NEXT
RETURN
--- In basicstamps@yahoogroups.com, "elfkeebler" <elfkeebler@y...>
work
were
is
receive
are
you may need to modify the SEROUT/SERIN baudmode parameter. I haven't
had the opportunity to update the demo code for conditional compilation
... I'll get to that as soon as I can. In the meantime, here's what you
need for the correct SEROUT/SERIN operation:
IRb96 CON 240 + $8000 ' 9600 baud, open
IRb48 CON 500 + $8000 ' 4800 baud, open
IRb24 CON 1021 + $8000 ' 2400 baud, open
-- Jon Williams
-- Dallas Office
From: elfkeebler [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZYAOr_RV7UOL-Nl3fkbr4fr9jo9YjSAZUWT8yHzaJbrbpACaMV8DGhh88MXQ1eLQpQK72JabpIbH_4M]elfkeebler@y...[/url
Sent: Monday, February 16, 2004 12:48 PM
Subject: [noparse][[/noparse]basicstamps] ir-buddy simple problem
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
PrintData:
I = 0 'it doesnt like this
but thank you for your effort.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...> wrote:
> The 'loopback' program is really to test a long
> INIT:
> MAIN:
> GOSUB ClearData
> GOSUB PrintData
> GOTO MAIN
> END
> RETURN
> IR_Buddy_GetData:
> ' sending data.
> RETURN
> PrintData:
> I = 0
> NextByte:
> ' else
> I = I + 1
> GOTO NextByte
> PrintDone:
> RETURN
> ClearData:
> FOR I = 0 to 7
> IRDat(I) = 0
> NEXT
> RETURN
> work
> were
> is
> receive
> are
>That program didnt work on pbasic 2.5
>PrintData:
Just insert the following near the top of the program:
I var byte
and try it again.
>> INIT:
>> MAIN:
>> GOSUB ClearData
>> GOSUB PrintData
>> GOTO MAIN
>> END
>> RETURN
>> IR_Buddy_GetData:
>> ' sending data.
>> RETURN
>> PrintData:
>> I = 0
>> NextByte:
>> ' else
>> I = I + 1
>> GOTO NextByte
>> PrintDone:
>> RETURN
>> ClearData:
>> FOR I = 0 to 7
>> IRDat(I) = 0
>> NEXT
>> RETURN
>> work
>> were
>> is
>> receive
>> are
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
Add 'I VAR BYTE' somewhere in the program.
> PrintData:
on.
> > INIT:
> > MAIN:
> > GOSUB ClearData
> > GOSUB PrintData
> > GOTO MAIN
> > END
> > RETURN
> > IR_Buddy_GetData:
to BS2
> > ' sending data.
> > RETURN
> > PrintData:
> > I = 0
> > NextByte:
> > ' else
> > I = I + 1
> > GOTO NextByte
> > PrintDone:
> > RETURN
> > ClearData:
> > FOR I = 0 to 7
> > IRDat(I) = 0
> > NEXT
> > RETURN
<elfkeebler@y...>
stock
programs
> > work
they
> > were
This
> > is
and
> > receive
runs
> > are
