multiple embedded blue clients?
Does anyone know if an embeddedblue transceiver module is cable of
simultaneous connection with multiple embeddedblue tranciever clients? The
manual only mentions connection between two modules.
Jeff
Jeff
>> module is cable of simultaneous connection with
Currently the embeddedblue transceiver module (eb500) supports only
a single active connection. You can address an unlimited number of
devices, but you can only communicate with one of them at a time.
Depending on your timing requirements, making and breaking the link
each time for multiple clients may be fast enough for you. Your
options open up a bit more if you are communicating with a PC or
PDA, which can typically connect with up to seven eb500 modules
simultaneously.
Talk to you soon,
Bryan Hall
A7 Engineering
www.a7eng.com
