Stamp 2, please help me!!!!!!!!!!!!! — Parallax Forums
edited 2004-03-27 13:32 in General Discussion
I bought the OEM Basic Stamp 2sx last summer for a robot I was
building, and was never able to get it work. Here is my setup: I
have a 7.5 1500mah battery + to the vdd, and - to the vss. I have 2
motors onboard that i want to use for the drive system. I have the +
of one motor going to p0, and the - going to p1. I have the second
motor's + going to p2 and the - going to p3. How can I get it to
move, forwards for example. I have read how to do it, but everytime
I try to, it says "download progress" loopback yes, and echo no. It
does not list my device type. I have it setup for com 1. It just
doesnt work though. I do not know what is the problem. Could you
please help, or give me some pointers? If anyone has an AOL IM, it
would be helpfull to me to chat with you that way, mine is
zsrcracing. Thanks again!
    edited 2004-02-15 14:08
    > robot I was
    > my setup: I
    > the vss. I have 2
    > have the second
    If I have read this right, then it is entirely
    possible you may have damaged your BS2SX already. The
    Stamp's output pins are not designed to drive motors
    directly. You would need an H-Bridge or other device
    to do this. I would recommend having the device
    tested for functionality without the motors attached!
    Knight Designs
    324 West Main Street
    Montour Falls, NY 14865
    (607) 535-6777
    http://www.knightdesigns.com
    __________________________________
    Do you Yahoo!?
    Yahoo! Finance: Get your refund fast by filing online.
    http://taxes.yahoo.com/filing.html
    edited 2004-02-16 02:05
    Sent: Sunday, February 15, 2004 9:08 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Stamp 2, please help me!!!!!!!!!!!!!
    > > robot I was
    > > my setup: I
    > > the vss. I have 2
    > > have the second
    Wouldn't it require first that the pins be driven high before any damage
    could occur? If he is not able to download to the stamp, the pins are not
    high by default are they? Something does need to be done with the outputs to
    buffer them if the stamp cannot drive that much current, but since he has
    not been able to run a program on the stamp, thus unable to drive the pins
    high, then how could there have been any damage? (If I'm missing something
    forgive me, I have not used a stamp before, but I just don't see how the
    motors being connected could have caused damage if the pins are not high.)
    CK
    edited 2004-02-16 03:15
    --- Joshua Simmons - CK <simmonsj2000@h...>
    > CK
    My apologies...He said he had never got the robot
    project to work. I 'assumed' that he had previously
    used the stamp. I thought it stopped working once he
    got to the motor section of it...Perhaps the person
    who posted the original message could clarify and save
    us all from making assumptions?
    Knight Designs
    (607) 535-6777
    Do you Yahoo!?
    edited 2004-02-22 01:32
    I have never got it to work, and still can not get it to work. Any
    suggestions? I am willing to send it to someone, if they think they
    can get it working.
    --- In basicstamps@yahoogroups.com, Chris Savage
    > > CK
    > Chris Savage
    > Knight Designs
    > (607) 535-6777
    > Do you Yahoo!?
    edited 2004-02-25 14:35
    Hi
    You say you connected your +7.5V (from the battery) to Vdd - which is
    incorrect, you should connect it to Vin. Vdd is meant for regulated
    5.0V supply only, Vin is the input to the onboard voltage regulator
    which converts your 7.5V to 5.0V.
    However, the onboard regulator may be insufficient to drive all of
    your external circuitry, particularly if you are going to drive
    motors.
    I recommend you connect the battery + to Vin, remove any circuitry
    from the stamp and try to find any sign of life: try downloading a
    (simple) program and see how it reacts.
    BTW: did you buy your OEM stamp as a kit or per-built? If you got it
    as a kit, check everything again.
    Regards
    Adrian
    edited 2004-03-27 12:09
    I'd be glad to try and help you get it working. The good news is that if it
    never worked, maybe something simple but obscure was missed. It sure helps to
    have a known working configuration to drop the part into.
    zmstark <zmstark@y...> wrote:I have never got it to work, and still can not
    get it to work. Any
    can get it working.
    > > CK
    > Chris Savage
    > Knight Designs
    > (607) 535-6777
    > Do you Yahoo!?
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Finance Tax Center - File online. File on time.
    > can get it working.
    If you have the ability to disconnect all the things it is connected
    to and just leave on power and the caoomnications to the PC for
    downloading that would offer a method of troubleshooting.
    Since you said OEM, I assume you have the proper clock crystal and
    memory chip to make it work.
    I would review the core processor and make sure you are connecting
    the OEM pins per the OEM schematic as it is NOT similar to the Stamp
    pin-out.
    I would recomend you connect only power, ground, serial and one
    output to one LED (with resistor)
    and run a simple program to blink the LED.
    Since you never got it to work, I'd take baby steps and just get
    anything to work, verify installation and soldering and so on.
    Dave
