Device on/off
I am using an BS2pe to acquire a GPS position every hour. To save
battery power the unit sleeps between fixes. I also plan to use a
reed switch to power the unit up. So I have incorporated the
suggested circuit given here:
http://www.angelfire.com/wizard/y2kbc/STAMPS/lps.gif
This works with a BS2 but I am having problems with both a BS2p and a
BS2pe. Is this something to do with the current draw? Do I need
different transistors?
Also, when the unit sleeps the I/O pin goes low and switches the
power off. I have tried putting a 10uF cap between the I/O and
ground but this does not seem to help. I have also tried a 4K7 pull-
up resistor but then the Stamp cannot switch itself off.
Any suggestions?
Helen
Any suggestions?
Helen
referring to:
That circuit with the capacitor on the i/o pin to hold it on would
work if you substitute a mosfet like the VN10 for the 2N1304 npn
transistor. As it is, the 2.2k and the base circuit drains off the
capacitor too fast. The circuit might work as it is if you
substitute a 100k resistor for the 2.2k, and include a >~1uF
capacitor on the pin. Also, I suggest that you leave out the second
transistor labeled "to other supplies", because it robs base current
from the 2N3906 that is supposed to supply current to the Stamp. {If
you do use two transistors like that, glue them together so they will
be at the same temperature and attempt to match their Vbe's.}
Some voltage regulators have a shutdown pin that can be used in this
manner. For example, there is an 8-pin LT1121 regulator on the
recent stamp modules, and that regulator turns off if its pin 5 is
pulled low by a resistance less than about 50kohms.
Note that the wake-up glitch (where the pins turn briefly to inputs)
is much shorter on the BS2pe than it is on the other Stamps, and thus
much easier to filter out. 0.1 millisecond as opposed to 16
milliseconds.
-- Tracy
>Any suggestions?
>Thanks,
>Helen
>power off.
Helen,
I'm confused... The whole idea of this circuit is so that the
Stamp can turn itself off. You should not be using the sleep command.
The ONLY way that the Stamp should turn itself on in this configuration
is from an external source.
Perhaps I should explain the "second" 2N3906 with the label "To Other
Supplies" more clearly. This is to power ANYTHING else that may be connected
through an I/O to the stamp. By doing this you can avoid any parasitic
supply voltage that could enter the stamp through an I/O when it is off. As
it is, the GROUND parasitic helps to keep the 2N3904 "off".
-Beau Schwabe
>Any suggestions?
>Thanks,
>Helen
Thanks for the help. I removed the second transistor and it is now
working with a 10uF cap. I am already using the LT1121 as the power
supply to the GPS receiver - it is a really useful device.
Thanks again,
Helen
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Helen
> referring to:
second
current
{If
will
this
inputs)
thus
> milliseconds.
> -- Tracy
and a
pull-
> >Any suggestions?
> >Thanks,
> >Helen
Just to clarify - the unit sleeps between hourly GPS fixes but also
needs to be able to switch itself off if it receives a command from
the RS232 connection. I removed the second transistor and put a 10
uF cap on the I/O and the system is now working fine.
Helen
--- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
and a
> >power off.
> Helen,
the
command.
configuration
label "To Other
connected
parasitic
off. As
> -Beau Schwabe
pull-
> >Any suggestions?
> >Thanks,
> >Helen
