Optoisolator needs inverting
Hello,
I'm trying to use an optoisolator to receive input from a stamp output pin, and
then have the optoisolator turn on a linear power regulator chip by connecting
it to the regulator's shutdown pin. When the shutdown pin is pulled low, it
turns off.
My problem is that all of the examples I've seen using optoisolators tie the
transistor emitter to ground, and the collector is the output which is tied to
+5 so that the switch is inverted. I'd like to set it up so that when the stamp
activates the optoisolator (through the internel LED) the output of the isolator
goes high.
Although I haven't seen any examples, can the transistor emitter be tied to
ground through a pull-down resistor, and the collector connected to +5? The
regulator shutdown pin would then connect to the emitter so that it is pulled
down to ground, except when the stamp output is high.
I know this method wouldn't work for driving loads, but the regulator shutdown
pin requires almost no current. Will this work? Suggestions?
Stewart
turns off.
goes high.
Stewart
collector) pulled high, then goes low through the NPN transistor when it
conducts. If you flip things around so that the collector ties right to
Vdd, the emitter is pulled-down to Vss, and your isolated output
connects to the emitter (between the emitter and pull-down), you'll be
good to go. When the transistor conducts you'll get Vdd across the
pull-down which will be present at your output line (about Vdd - 0.7,
depending on the transistor).
-- Jon Williams
-- Dallas Office
From: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qsdmYQqkfW0pbgW4MU10IAn6gZ8_-BK-vALXNIpCEGQyh8wy2u067dh7Y7IgJAIfSDaGp0uTYHdH8GEc43IUmsrh-HA4]stamplist@k...[/url
Sent: Wednesday, February 11, 2004 11:10 AM
Subject: [noparse][[/noparse]basicstamps] Optoisolator needs inverting
Hello,
pin, and
connecting
low, it
turns off.
the
tied to
+the stamp
isolator
goes high.
to
The
pulled
shutdown
Stewart
the group files section.
-- Jon Williams
-- Parallax
Sent: Wednesday, February 11, 2004 11:42 AM
Subject: RE: [noparse][[/noparse]basicstamps] Optoisolator needs inverting
As you indicate, the *usual* configuration has the output (tied to
-- Jon Williams
-- Dallas Office
From: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=obkQNkufkwJKWjTuHOUUTkIIO54NOq_LlcCrwBjvdCoMG4I_dm18CqtDGp_GWUTty_STtU0AFR8_GTnHF-q4RefdGTw]stamplist@k...[/url
Hello,
pin, and
connecting
low, it
turns off.
the
tied to
+the stamp
isolator
goes high.
to
The
pulled
shutdown
Stewart
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thanks so much!
stewart
On Wed, 11 Feb 2004 09:53:57 -0800, Jon Williams wrote:
> In case my description isn't quite clear, I've uploaded a schematic to
> -- Jon Williams
> -- Parallax
> From: Jon Williams
> -- Jon Williams
> -- Dallas Office
> From: Stewart Mayer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qWsmj7m_p5QcKhlpPTFClDCNvtcnFNo8Ol8HD1Yr1tZALcnTf1RH8AwkPS4vQjHhBSEFVxTrmNwAnkDPomrcmoaL37vP]stamplist@k...[/url
> Hello,
> pin, and
> connecting
> low, it
> turns off.
> the
> tied to
> +the stamp
> isolator
> goes high.
> to
> The
> pulled
> shutdown
> Thanks,
> Stewart
> Yahoo! Groups Links
> abuse@p....
of the message
> will be ignored.
> Yahoo! Groups Links
