i''m new, need help with command
Andy:
I built a simple alarm system for a storage shed using the BS2 doing just
what Jon suggested. A loop, that after all other housekeeping chores are
done, i.e. resting lights, clearing my LCD display etc, just loops forever
until an alarm contact is activated. The system then waits for the correct
input from a keypad and failing that sends X-10 signals to turn on lights
and sirens and then also sends me a message on my pager using an old 1200
baud modem as a cheap and easy telephone interface. The Stamp even
remembers which alarm point was activated (I only have 4 for this shed but
could be more) and sends to my pager which contact (#1-4) was activated.
The loop works great. It is simple and has never failed me.
Just my $0.02.
Al Sines, W3AL
Sent: Tuesday, February 10, 2004 10:57 AM
Subject: [noparse][[/noparse]basicstamps] Re: i'm new, need help with command
> Well, by "quick", I mean that the pin will only be high for maybe 0.5
> seconds. Assuming that the only thing going is the loop looking for
> a high on one of the 4 pins, I don't know if that 0.5 sec high is
> long enough. Perhaps I could add some kind of RC circuit to keep the
> pin latched for an extra second or so. The POLLMODE latching stuff
> looks a little more complicated. But if it's that much better, I'll
> try to figure it out.
> Thanks,
> Andy
> --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
> wrote:
> > The depends on how you define "quick" and keep in mind that standard
> > Stamp inputs are not latched. As Tracy suggested, however, you can
> use
> > POLLIN instruction with a MODE that will latch polled inputs, but
> note
> > that using POLL instructions work in between other things (the
> Stamp is
> > single threaded). In addition to the manual, and information on
> Tracy's
> > web site, you may find this article helpful:
> > http://www.parallax.com/dl/docs/cols/nv/vol2/col/69.pdf
> > -- Jon Williams
> > -- Applications Engineer, Parallax
> > -- Dallas Office
> > From: andy_watson5 [noparse][[/noparse]mailto:andywatson@m...]
> > Sent: Tuesday, February 10, 2004 8:58 AM
> > To: basicstamps@yahoogroups.com
> > Ah, I see. Thanks for the help. That sounds like it might work.
> > So if I have an infinite loop looking at the buttons:
> > Button_Scan:
> > IF (ButtonA = 1) THEN BtnA_Sub
> > IF (ButtonB = 1) THEN BtnB_Sub
> > IF (ButtonC = 1) THEN BtnC_Sub
> > IF (ButtonD = 1) THEN BtnD_Sub
> > GOTO Button_Scan
> > Is this loop quick enough to catch a quick pulse on one of the
> > momentary buttons? I just don't know how fast the stamp scans, and
> I
> > don't want the program to be looking at ButtonC when someone
> presses
> > ButtonA, but they release it by the time the program gets back to
> > looking at ButtonA again.
> > Thanks,
> > Andy
> > wrote:
> > > You can do this simply and prioritize your scan through simple IF-
> > THEN
> > > Button_Scan:
> > > BtnA_Sub:
> > > ' code for button A
> > > GOTO Button_Scan
> > > This uses an implicit GOTO in IF-THEN. The sample above assumes
> > that
> > > your inputs are active-high (read a 1 when the button is pressed -
> > > change to 0 for active low). While this code is a bit "grunt" it
> is
> > > simple and allows you to prioritize the buttons in the event that
> > more
> > > than one get pressed.
> > > If you want to check all the buttons in order and process those
> > that are
> > > pressed, you can change your code like this:
> > > Button_Scan:
> > > IF (ButtonA = 1) THEN GOSUB BtnA_Sub
> > > IF (ButtonB = 1) THEN GOSUB BtnB_Sub
> > > BtnA_Sub:
> > > ' code for button A
> > > RETURN
> > > -- Jon Williams
> > > -- Dallas Office
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> Subject
> > and Body of the message will be ignored.
> > Yahoo! Groups Links
> > This message has been scanned by WebShield. Please report SPAM to
> > abuse@p...
> Yahoo! Groups Links
Just my $0.02.
Al Sines, W3AL
> Thanks,
> Andy
> use
> note
> Stamp is
> Tracy's
> > -- Jon Williams
> > -- Dallas Office
> > Button_Scan:
> > GOTO Button_Scan
> I
> presses
> > Thanks,
> > Andy
> > THEN
> > > Button_Scan:
> > > BtnA_Sub:
> > > ' code for button A
> > > GOTO Button_Scan
> > that
> is
> > more
> > that are
> > > Button_Scan:
> > > BtnA_Sub:
> > > ' code for button A
> > > RETURN
> > > -- Jon Williams
> > > -- Dallas Office
> Subject
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
