Best Sensor Choice?
Hi All,
I'm new to BASIC stamps, and have a sensor question.
I'm building an application that has a small revolving paddle, driven
by a Parallax Servo. When the Stamp recieves a signal, the servo will
be activated. I'd like to install a sensor that detects when the
paddle passes it, and stop the servo. The paddle is thin, ~ 1/16th of
an inch. It's currently semi-frosted plastic, but I can easily paint
a line on it.
I was thinking about using a QTI Sensor
(http://www.parallax.com/detail.asp?product_id=555-27401) but I'm not
sure if it will be able to detect the very thin line passing it.
I could try using a stepper motor, but I like the idea of working with
a sensor, as this project is more fun hobby then serious application.
Chris McAvoy
a line on it.
Chris McAvoy
wrote:
> Hi All,
driven
will
of
paint
> a line on it.
The reflectivity is the key. the 1/16 might work, and you may be
able to add a little shoulder to increase the area?
Another method is a hall effect sensor, but then you would need a
small magnet on the paddle.
Another idea is to put the sensor on the shaft of the servo.
Dave
If the paddle can pass through a slotted phototransistor switch (see
Optek switch, Digikey 365-1008-ND), I would use it. Otherwise, glue a
small magnet on the paddle, and use a Hall sensor.
Dennis
From: Chris McAvoy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QufhYpb4OckiEvxMdx00kveuGSp_ccW1QjGUyTQI8mkVT23cLsYty2FEB5wNMsT5_KDlNkK8vDnIPcQ]mcavoy76@h...[/url
Sent: Tuesday, February 10, 2004 12:14 PM
Subject: [noparse][[/noparse]basicstamps] Best Sensor Choice?
Hi All,
I'm building an application that has a small revolving paddle, driven by
a Parallax Servo. When the Stamp recieves a signal, the servo will be
activated. I'd like to install a sensor that detects when the paddle
passes it, and stop the servo. The paddle is thin, ~ 1/16th of an inch.
It's currently semi-frosted plastic, but I can easily paint a line on
it.
I could try using a stepper motor, but I like the idea of working with a
Chris McAvoy
Yahoo! Groups Links
