Still having problem with Toshiba
Sorry this thread got so old...I was away for a while..Anyway I
disabled the FIFO buffers on my Toshiba laptop but I still cannot use
the Windows Based Stamp Program in the windows environment. I can use
the DOS version in a DOS window in WIN98 and it works fine. Also
STAMPLOT LITE works well. There was no significant change after
changing FIFO settings. Below is a copy of my original post and
someones generous reply. Thank You.
At 12:23 AM 1/29/04 +0000, generatorlabs wrote:
>I have had success using my stamp programming board with my desktop
>but when I try to use my laptop I cannot get a link between the
>windows-based stamp editor (latest version) and the stamp. The strange
>thing is that in DOS the laptop links up with no problem. That led me
>to believe I had a problem with windows98 but then I discovered that
>stampplot lite works fine in windows and it communicates flawlessly
>with the stamp. I think the windows-based stamp editor may have some
>issues on how it is accessing the com port...any suggestions????
>Oh in case you were wondering when I try to poll the stamp I get
>LOOP=YES, ECHO=NO but no stamp ID. I do know that the stamp is
>recieving an ATN signal because what ever programs are currently
>running in the stamp get paused/reset.
>Laptop is a Toshiba Libretto CT50 Pentium @ 75MHZ (yeah I know its
>slow but its tiny and I need the space on my bench)
>Thanks for any help.....
>Try setting the FIFO buffer on the serial port to zero, or as low as
it will
go.
>If that doesn't do it, write back.
it will
go.
>it will
>go.
Are you using a programming cable purchased from Parallax, or one which you
constructed yourself ?
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
statement into your program. This will tell the editor to open the
DEBUG window, which opens activates the comm port and keeps it open.
-- Jon Williams
-- Dallas Office
From: generatorlabs [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fSP4Yt2R0vXvKJe4a23YhHpnD6CiV7lSnE0utJykW0tiNphmsPMLwCYNoGsMQwAAHQzgCEq0Mq1_4kAs3X54jA]generatorlabs@y...[/url
Sent: Monday, February 09, 2004 9:55 PM
Subject: [noparse][[/noparse]basicstamps] Still having problem with Toshiba
Sorry this thread got so old...I was away for a while..Anyway I disabled
the FIFO buffers on my Toshiba laptop but I still cannot use the Windows
Based Stamp Program in the windows environment. I can use the DOS
version in a DOS window in WIN98 and it works fine. Also STAMPLOT LITE
works well. There was no significant change after changing FIFO
settings. Below is a copy of my original post and someones generous
reply. Thank You.
>I have had success using my stamp programming board with my desktop but
>Laptop is a Toshiba Libretto CT50 Pentium @ 75MHZ (yeah I know its slow
it will
go.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
> >it will
> >go.
which you constructed yourself ?
I am using the Parallax Basic Stamp II programming board with a
standard serial cable..
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
