Somewhat OT: Optical Gratings
Hello to all.
My project involves the detection of angular displacements as small
as 1/4th of a degree.
I will use simple optical gratings with five slits. Each slit will
have a width of 1/10th of a mm or perhaps less. When the slits are
aligned, I will have a window of 0.5 mm.
Which type of LED and photonic detector would be adequate? I will use
graphic arts photographic film for the gratings which I believe is
transparent for IR frequencies so IR is not adequate.
At this point I believe a bright white light LED might be adequate,
using a detector for visible light.
But there are several types of detectors. Perhaps someone here has
experience with them.
Thanks in advance.
Thanks in advance.
<proufo@c...> wrote:
> Hello to all.
I meant 1/40th of a degree. That is the angular displacement of a
nine-inch tonearm when it moves the width of a groove.
My project is a tangential-tracking turntable.
quarter century or so ago. Or if not, then exactly what are you trying to
detect and control?
Mike Sokol
mike@f...
www.fitsandstarts.com
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Monday, February 09, 2004 6:34 PM
Subject: [noparse][[/noparse]basicstamps] Re: Somewhat OT: Optical Gratings
> --- In basicstamps@yahoogroups.com, "Pablo Roufogalis L."
> > Hello to all.
> Yahoo! Groups Links
photoresistor or photodiode it will clearly illuminate or show through the
transparent art-work. however you will need to experiment with it, because
i dont know how transparent it is.
At 11:23 PM 2/9/2004 +0000, you wrote:
>Hello to all.
>Thanks in advance.
>Yahoo! Groups Links
<mike@f...> wrote:
> You mean like the Rabinow linear tonearm? I've actually played with
one a
trying to
> detect and control?
Hello Mike.
Coincidentially, I have described my project elsewhere as an updated
Rabco.
There are many linear-turntables. Mine will different because:
1) It uses a regular pivoting tonearm, not an specially designed
tonearm. In order to make it track tangentially, the armboard is
mobile, controlled by a Stamp, a step-moptor controller, a step motor
and a linear stage.
2) Instead of waiting for the arm to develop an angular error and
correct, it will keep a steady velocity and correct position and
speed if required. I believe mass-market designs from the 70s act on
error alone, including the Rabcos which used a mechanical sceme to
move the arm.
3) I aim to detect deviations of one groove. I believe mass designs
use a much larger error window.
BTW, Mr. Surround, my first iteration of the turntable will be for my
CD-4 Quadraphonic setup.
Best regards.
> This is very difficult because even if you use a bright white LED
and a
through the
because
Hello Gary and thanks for your comment.
Graphics arts film is very dark. The figure of merit here is density,
typically above 4.0. And there will be two layers of it.
I'm sure it will require a lot of tweaking though.
Would you use a photoresistor or a photodiode? What is easier to
interface?
Thanks again.
Most interesting....
And yes, my main gig is consulting and teaching surround production
techniques. As part of my surround seminars, I do discuss the original quad
technologies from the 70's, including CD-4. I'm curious as to what CD-4
records you have to play, and what cartridge and stylus are you using? Send
me a picture when you've got it working and I'll put it in one of my
PowerPoint slides.
If anyone on this group would like an explanation of CD-4 and SQ quad
records (which is what Pablo's project will decode), let me know and I'll
post a quick overview. Tracking error was the Achilles heal of getting quad
records to work properly, so Pablo's project has an excellent chance of
working WAY better than the original turntables of the 70's... at least as
far as quad records are concerned.
Mike Sokol
mike@f...
-William of Occam-
Sent: Tuesday, February 10, 2004 5:22 PM
> --- In basicstamps@yahoogroups.com, "Mike Sokol - Fits & Starts"
> one a
> trying to
> > detect and control?
> Hello Mike.
> Rabco.
> and a linear stage.
> move the arm.
> Best regards.
> Yahoo! Groups Links
<mike@f...> wrote:
> Pablo,
quad
and I'll
getting quad
chance of
least as
Hello again.
You'd be surprised how active the quaddie community is, even in 2004.
Check the forums at http://www.quadraphonicquad.com/forums and also
do a search for quad* at ebay. You'd be amazed.
Would love to provide pictures when the time comes to that. But many
at the forums can provide their current setups, up and running. Many
have extensive collections of Quad recording, way better than mine.
Will ask but you are invited to visit and join.
BTW, whatcha doin'heah? ;-)
Best regards.
I believe you can use an infrared source and detector for your
application. Photographic film that has a density of 4.0 should block
both visible and near-infrared light. You can set up a simple
experiment to test this effect by using a matched infrared emitter and
detector pair from Radio Shack (#276-142). Simply point the IR emitter
at the detector, measure the signal, then block the path with the
film. Be sure to measure the attenuation of a clear area on the film
as well as the high density area. I would expect an extinction ratio
(high density area signal/clear area signal) of at least 50:1. More is
better.
As for the ease of interfacing to a photoresistor or photodiode, I
think the real question is speed. Photoresistors are slow,
milliseconds. Photodiodes are fast, microseconds or nanoseconds. It
seems like your application would benefit from using a photodiode, so
the response time of the sensor is not an issue in your tone arm
control loop.
I would suggest that you do some preliminary experiments with the
actual gratings and optical components in a test jig, to check that
the on/off signal levels through the five tiny slits are sufficient.
This will help reduce any surprises downstream.
Dave
> interface?
> Thanks again.
Will test this for sure. Any idea on the size of the 'light
acceptance window' of the RS detector?
Thanks again.
--- In basicstamps@yahoogroups.com, "barrowman11" <barrowman11@y...>
wrote:
> Pablo,
block
and
emitter
is
> better.
so
> control loop.
No, I do not know what the actual viewing angle is, but you can a
rough measure by using the matching detector as an optical probe.
Dave
> Hello Dave and thanks for your suggestions.
> Thanks again.
Hmmmm. Why bother with the angular displacement? Why not simply
count revolutions of the turn table? Multiply counts x 0.04 to get
total angular displacement.
I worked with a shaft encoder once that used optical gratings and gave
an 18-bit count. One LSB of the encoder was 9.88 minutes of arc.
Your 0.04 degree resoulotion works out to 2.4 minutes of arc, so it
should be possible to use gratings. However, the "gottcha" is the
alignment and stability that you need. Also, one of the gratings
should have one less line-per-inch than the oterher to get a stable
Moirere pattern. Good luck! The encoder cost about $8000 and had to
be sent back to the factory to have its light bulbs replaced at a cost
of about $4000!
I'm afraid that a stepper motor would create acoustic noise that would
transmit to the tone arm. I'd suggest using a linear actuator.
Russ
> Hello to all.
> Thanks in advance.
wrote:
> Paublo,
gave
to
cost
> of about $4000!
would
> Russ
Hello Russ and thanks for your comments.
It is not the best solution to count revolutions because the spacing
of the grooves is not constant. The arm will lose tangentiality
immediately, grossly in some cases.
Yes! I saw the radial gratings one having one additional spoke in
my "Mechanism for intermitent motion" book. I think I can do that
with film but will try first with something simpler. I just need to
detect small deviations within a very limited range. I agree it will
be a challenge to align the gratings. One step at a time.
Will use a linear actuator, with a very, very fine pitch. Check it at:
http://www.sandbeads.com/siteimages/SS1.jpg
and the pitch:
http://www.sandbeads.com/siteimages/SS3.jpg
I will use a lot of damping to diminish any chance of pulses going to
the tonearm. Crossing my fingers, though.
Thanks again for your comments.
This is my current approach to the gratings. I increased the number
of slits to ten, giving a window of 1 mm, somewhat spaced.
http://www.sandbeads.com/siteimages/Gratings.gif
This represents the two gratings. The bottom one will move over the
top one (at this point in time).
There are four sensors corresponding to five individual gratings
pairs. The two extremes labeled 'Panic' will detect any gross
tangential error, which should never happen except at the end of the
record. In case any of those sensors activate, a servo will lift the
tonearm.
The one labeled 'Land between cuts' will move the tonearm inwards to
rapidly keep tangentiality when the arm moves between cuts (songs).
The comb-like slits detect angular deviation, inward or outward.
Although the system should correct confirmed one-groove deviations
immediately, these gratings are designed to keep state even with two-
groove deviations. This may change if I need to increase the number
of slits.
Any comment is welcome.
Sorry. There are FIVE sensors corresponding to five...
Back when we used to cut records on a lathe, the engineer would try to vary
the spacing between the grooves manually using the feed-rate control. It was
pretty much by intuition, since you had to have more spacing for really loud
passages to prevent groove-echo, but could cram the grooves closer together
for soft audio passages. That way you could get the most audio length on a
disc. There were a whole series of 45-RPM LP 10 inch singles for the DJ
markets, where a single 5-minute song was spread out using really wide
groove spacing and run at 45 rather than 33 1/3 RPM. Perhaps the first
hi-rez LP's?
Mike Sokol
mike@f...
-William of Occam-
Sent: Wednesday, February 11, 2004 7:33 PM
> --- In basicstamps@yahoogroups.com, "russranshaw" <home.rr@c...>
> wrote:
> > Paublo,
> gave
> to
> cost
> > of about $4000!
> would
> > Russ
> and the pitch:
> Yahoo! Groups Links
<mike@f...> wrote:
> FYI:
to vary
control. It was
really loud
together
length on a
the DJ
wide
first
> hi-rez LP's?
The (boosted) bass extension on those is astonishing, and the overall
sound is much better. It does make a difference.
There is a label that has reissued classic albums (one is Carole
King's Tapestry) at 45 rpm. It takes six 12" sides for an Lp and are
quite expensive.
