Boe-Bot Servos
I bought the Parallax Boe-Bot special and decided to play with it to learn a
little programming. It comes with the new updated servos. After I put it
together the RPM of the servos are not even close. I have to use a 500 pulse
time for one servo and a 820 pulse time for the other to get it to track
straight. I ended up shimming the servos so they "turn" to get it close... I
can now use 500/970 which is much better.
Is this a common problem with the new servos?
Hank Hagquist
HobbyTalk - http://www.hobbytalk.com
HobbyShopper - http://www.hobbyshopper.com
Hank Hagquist
you can insert a small phillips driver to set
the 'do-nothing' point -- which should be
1500 mS (or 750 on Pulsout).
2. I also bought the special. I havn't gotten
to the point of actually running it yet. Sigh.
Thus even if both are properly set to the same
'do-nothing' point, I don't know if they will
be the same speed at the same Pulsout setting.
More later, I'm sure.
--- In basicstamps@yahoogroups.com, "Hank Hagquist" <hankster@h...>
to learn a
put it
500 pulse
track
close... I
> Hank Hagquist
other. Needing a 360 ms offset just seems kind of extreme.
Hank Hagquist
Sent: Monday, February 09, 2004 3:26 PM
Subject: [noparse][[/noparse]basicstamps] Re: Boe-Bot Servos
> 1. The new servo's have a 'tuning' port, where
> to learn a
> put it
> 500 pulse
> track
> close... I
> > Hank Hagquist
The servos in your kit are different from (and better than) the servos
described in the
Robotics v1.5 text. There should have been a handout in your kit with
instructions for the Parallax Continuous Rotation servos and other parts
that have been changed (and improved). Look for "Robotics Appendix J"
on www.parallax.com -> Downloads -> Educational Curriculum.
Also available from the same page is the newly revised Robotics with the
Boe-Bot v2.0 text, which supports all the new hardware and PBASIC 2.5.
Regards, Andy
Andy Lindsay
Applications Engineer
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w0goqhm37BjcKo6I8_vwhmUS57EGrM76rZ6AvUaID5fMWPVXRl5D4WbFuraDxGezoxdEjdoEIIAljmNG8K5lqFRFhh0]allan.lane@h...[/url
Sent: Monday, February 09, 2004 12:27 PM
to learn a
put it
500 pulse
track
close... I
> Hank Hagquist
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
