SRF04 troubles
Hello all. I'm using 3 SRF04s for avoidance on my trinity robot.
Here is my code:
'{$STAMP BS2}
'''To get to first room
'Variables======================================================================\
l_dist VAR Word 'Variable for left srf04 reading
r_dist VAR Word 'Variable for right srf04 reading
f_dist VAR Word 'Variable for front srf04 reading
a VAR Word 'Counter for servos
'Navigation=====================================================================\
Firsthall: 'hall one for the maze
(fire-fighting)
GOSUB checksensors
IF f_dist < 580 THEN left1
IF l_dist < 290 THEN radjust1
IF r_dist < 290 THEN ladjust1
GOSUB forward
GOTO firsthall
radjust1:
GOSUB radjust
GOTO Firsthall
ladjust1:
GOSUB ladjust
GOTO Firsthall
left1:
GOSUB left
halltodoor1:
GOSUB checksensors
IF f_dist < 1450 THEN left2
IF l_dist < 290 THEN radjust2
IF r_dist < 290 THEN ladjust2
GOSUB forward
GOTO halltodoor1
radjust2:
GOSUB radjust
GOTO halltodoor1
ladjust2:
GOSUB ladjust
GOTO halltodoor1
left2:
GOSUB left
intoroom1:
GOSUB checksensors
IF f_dist < 3190 THEN checkforfire
IF l_dist < 290 THEN radjust3
IF r_dist < 290 THEN ladjust3
GOSUB forward
GOTO intoroom1
radjust3:
GOSUB radjust
GOTO intoroom1
ladjust3:
GOSUB ladjust
GOTO intoroom1
checkforfire:
STOP 'normally send to hamamatsu subroutine
'Subroutines====================================================================\
checksensors:
PULSOUT 0,5 'front srf04 is P0
OUTPUT 0 'delay
RCTIME 0,1,f_dist 'store value in f_dist
PULSOUT 1,5 'left srf04 is P1
OUTPUT 1 'delay
RCTIME 1,1,l_dist 'store value in l_dist
PULSOUT 2,5 'right srf04 is P2
OUTPUT 2 'delay
RCTIME 2,1,r_dist 'store value in r_dist
return
forward:
FOR a = 1 TO 10
PULSOUT 12,1000
PULSOUT 13,500
PAUSE 10
next
return
left:
FOR a = 1 TO 20
PULSOUT 12,500
PULSOUT 13,500
PAUSE 10
next
return
right:
FOR a = 1 TO 20
PULSOUT 12,1000
PULSOUT 13,1000
PAUSE 10
next
return
ladjust:
FOR a = 1 TO 6
PULSOUT 12,800
PULSOUT 13,500
PAUSE 10
next
return
radjust:
FOR a = 1 TO 6
PULSOUT 12,1000
PULSOUT 13,700
PAUSE 10
next
return
end
Here is my problem. the code works fine. It takes too long to execute. The robot
stops each time it needs to check the sensors. Is there anyway I can eliminate
this? Can I shorten my code? All help is greatly appreciated. Thank you.
John Baker
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Here is my code:
'{$STAMP BS2}
(fire-fighting)
GOSUB checksensors
GOSUB forward
GOTO firsthall
radjust1:
GOSUB radjust
GOTO Firsthall
ladjust1:
GOSUB ladjust
GOTO Firsthall
left1:
GOSUB left
halltodoor1:
GOSUB checksensors
GOSUB forward
GOTO halltodoor1
radjust2:
GOSUB radjust
GOTO halltodoor1
ladjust2:
GOSUB ladjust
GOTO halltodoor1
left2:
GOSUB left
intoroom1:
GOSUB checksensors
GOSUB forward
GOTO intoroom1
radjust3:
GOSUB radjust
GOTO intoroom1
ladjust3:
GOSUB ladjust
GOTO intoroom1
checkforfire:
checksensors:
OUTPUT 0 'delay
OUTPUT 1 'delay
OUTPUT 2 'delay
return
forward:
FOR a = 1 TO 10
PULSOUT 12,1000
PULSOUT 13,500
PAUSE 10
next
return
left:
FOR a = 1 TO 20
PULSOUT 12,500
PULSOUT 13,500
PAUSE 10
next
return
right:
FOR a = 1 TO 20
PULSOUT 12,1000
PULSOUT 13,1000
PAUSE 10
next
return
ladjust:
FOR a = 1 TO 6
PULSOUT 12,800
PULSOUT 13,500
PAUSE 10
next
return
radjust:
FOR a = 1 TO 6
PULSOUT 12,1000
PULSOUT 13,700
PAUSE 10
next
return
end
John Baker
Do you Yahoo!?
in your subroutines.
You could remove the 'Pause 10' from
your subroutines -- move the pauses into
your 'main' loop, and use some of that
time to check your sensors.
--- In basicstamps@yahoogroups.com, John Baker
> Here is my code:
> '{$STAMP BS2}
(fire-fighting)
> GOSUB checksensors
> GOSUB forward
> GOTO firsthall
> radjust1:
> GOSUB radjust
> GOTO Firsthall
> ladjust1:
> GOSUB ladjust
> GOTO Firsthall
> left1:
> GOSUB left
> halltodoor1:
> GOSUB checksensors
> GOSUB forward
> GOTO halltodoor1
> radjust2:
> GOSUB radjust
> GOTO halltodoor1
> ladjust2:
> GOSUB ladjust
> GOTO halltodoor1
> left2:
> GOSUB left
> intoroom1:
> GOSUB checksensors
> GOSUB forward
> GOTO intoroom1
> radjust3:
> GOSUB radjust
> GOTO intoroom1
> ladjust3:
> GOSUB ladjust
> GOTO intoroom1
> checkforfire:
> checksensors:
> OUTPUT 0 'delay
> OUTPUT 1 'delay
> OUTPUT 2 'delay
> return
> forward:
> FOR a = 1 TO 10
> PULSOUT 12,1000
> PULSOUT 13,500
> PAUSE 10
> next
> return
> left:
> FOR a = 1 TO 20
> PULSOUT 12,500
> PULSOUT 13,500
> PAUSE 10
> next
> return
> right:
> FOR a = 1 TO 20
> PULSOUT 12,1000
> PULSOUT 13,1000
> PAUSE 10
> next
> return
> ladjust:
> FOR a = 1 TO 6
> PULSOUT 12,800
> PULSOUT 13,500
> PAUSE 10
> next
> return
> radjust:
> FOR a = 1 TO 6
> PULSOUT 12,1000
> PULSOUT 13,700
> PAUSE 10
> next
> return
> end
execute. The robot stops each time it needs to check the sensors. Is
there anyway I can eliminate this? Can I shorten my code? All help is
> John Baker
> Do you Yahoo!?
behavior. I'm using standard modified servos. Where else would I put these
pauses? Are you suggesting that I put one pause 10 in each "main" loop? Also, I
read somewhere about a serial servo controller. Would it be faster to just
"serout" a command, and use the rest of the code the way it is? Thank you for
your time.
Allan Lane <allan.lane@h...> wrote:You have a lot of 'Pause 10'
lines
> Here is my code:
> '{$STAMP BS2}
(fire-fighting)
> GOSUB checksensors
> GOSUB forward
> GOTO firsthall
> radjust1:
> GOSUB radjust
> GOTO Firsthall
> ladjust1:
> GOSUB ladjust
> GOTO Firsthall
> left1:
> GOSUB left
> halltodoor1:
> GOSUB checksensors
> GOSUB forward
> GOTO halltodoor1
> radjust2:
> GOSUB radjust
> GOTO halltodoor1
> ladjust2:
> GOSUB ladjust
> GOTO halltodoor1
> left2:
> GOSUB left
> intoroom1:
> GOSUB checksensors
> GOSUB forward
> GOTO intoroom1
> radjust3:
> GOSUB radjust
> GOTO intoroom1
> ladjust3:
> GOSUB ladjust
> GOTO intoroom1
> checkforfire:
> checksensors:
> OUTPUT 0 'delay
> OUTPUT 1 'delay
> OUTPUT 2 'delay
> return
> forward:
> FOR a = 1 TO 10
> PULSOUT 12,1000
> PULSOUT 13,500
> PAUSE 10
> next
> return
> left:
> FOR a = 1 TO 20
> PULSOUT 12,500
> PULSOUT 13,500
> PAUSE 10
> next
> return
> right:
> FOR a = 1 TO 20
> PULSOUT 12,1000
> PULSOUT 13,1000
> PAUSE 10
> next
> return
> ladjust:
> FOR a = 1 TO 6
> PULSOUT 12,800
> PULSOUT 13,500
> PAUSE 10
> next
> return
> radjust:
> FOR a = 1 TO 6
> PULSOUT 12,1000
> PULSOUT 13,700
> PAUSE 10
> next
> return
> end
> John Baker
> Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
having to deal with the servos directly and you wouldn't need any of those
pauses. Scott Edwards makes a pretty good one that'll handle up to 8 servos
from one board and can be daisy chained to control more.
http://www.seetron.com/
Chris Shuster
Sent: Sunday, February 08, 2004 5:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: SRF04 troubles
> Allan, when I remove the pauses, my servos act up. They have unpredictable
Also, I read somewhere about a serial servo controller. Would it be faster
to just "serout" a command, and use the rest of the code the way it is?
Thank you for your time.
10' lines
> > Here is my code:
> > '{$STAMP BS2}
> (fire-fighting)
> > GOSUB checksensors
> > GOSUB forward
> > GOTO firsthall
> > radjust1:
> > GOSUB radjust
> > GOTO Firsthall
> > ladjust1:
> > GOSUB ladjust
> > GOTO Firsthall
> > left1:
> > GOSUB left
> > halltodoor1:
> > GOSUB checksensors
> > GOSUB forward
> > GOTO halltodoor1
> > radjust2:
> > GOSUB radjust
> > GOTO halltodoor1
> > ladjust2:
> > GOSUB ladjust
> > GOTO halltodoor1
> > left2:
> > GOSUB left
> > intoroom1:
> > GOSUB checksensors
> > GOSUB forward
> > GOTO intoroom1
> > radjust3:
> > GOSUB radjust
> > GOTO intoroom1
> > ladjust3:
> > GOSUB ladjust
> > GOTO intoroom1
> > checkforfire:
> > checksensors:
> > OUTPUT 0 'delay
> > OUTPUT 1 'delay
> > OUTPUT 2 'delay
> > return
> > forward:
> > FOR a = 1 TO 10
> > PULSOUT 12,1000
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > left:
> > FOR a = 1 TO 20
> > PULSOUT 12,500
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > right:
> > FOR a = 1 TO 20
> > PULSOUT 12,1000
> > PULSOUT 13,1000
> > PAUSE 10
> > next
> > return
> > ladjust:
> > FOR a = 1 TO 6
> > PULSOUT 12,800
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > radjust:
> > FOR a = 1 TO 6
> > PULSOUT 12,1000
> > PULSOUT 13,700
> > PAUSE 10
> > next
> > return
> > end
> > John Baker
> > Do you Yahoo!?
> Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Groups Links
Your program is very interesting. I just got a Davantech SRRF04 Ultrasonic
Range Finder on Wednesday, and I'm also having problems like you are having.
I've been learning how to use SRF04, and studying the timings with an
OPTAscope.
In the specs that came with the SRF04, it says the "Echo Pulse is Approx.
36 ms if no Object Detected". In your program you have 3 RCTIME commands
before sending PULSOUT to the servos. So, in the worst case that could be
108 ms, plus the 10 ms on the last PAUSE 10 that was executed before a
PULSOUT to the servos..
You might need to send pulses to the servos between the RCTIME commands,
depending on the distance from the SRF04 to the nearest object.
Steve
_____________
Sent: Sunday, February 08, 2004 3:15 PM
Subject: [noparse][[/noparse]basicstamps] SRF04 troubles
> Here is my code:
> '{$STAMP BS2}
(fire-fighting)
> GOSUB checksensors
> GOSUB forward
> GOTO firsthall
> radjust1:
> GOSUB radjust
> GOTO Firsthall
> ladjust1:
> GOSUB ladjust
> GOTO Firsthall
> left1:
> GOSUB left
> halltodoor1:
> GOSUB checksensors
> GOSUB forward
> GOTO halltodoor1
> radjust2:
> GOSUB radjust
> GOTO halltodoor1
> ladjust2:
> GOSUB ladjust
> GOTO halltodoor1
> left2:
> GOSUB left
> intoroom1:
> GOSUB checksensors
> GOSUB forward
> GOTO intoroom1
> radjust3:
> GOSUB radjust
> GOTO intoroom1
> ladjust3:
> GOSUB ladjust
> GOTO intoroom1
> checkforfire:
> checksensors:
> OUTPUT 0 'delay
> OUTPUT 1 'delay
> OUTPUT 2 'delay
> return
> forward:
> FOR a = 1 TO 10
> PULSOUT 12,1000
> PULSOUT 13,500
> PAUSE 10
> next
> return
> left:
> FOR a = 1 TO 20
> PULSOUT 12,500
> PULSOUT 13,500
> PAUSE 10
> next
> return
> right:
> FOR a = 1 TO 20
> PULSOUT 12,1000
> PULSOUT 13,1000
> PAUSE 10
> next
> return
> ladjust:
> FOR a = 1 TO 6
> PULSOUT 12,800
> PULSOUT 13,500
> PAUSE 10
> next
> return
> radjust:
> FOR a = 1 TO 6
> PULSOUT 12,1000
> PULSOUT 13,700
> PAUSE 10
> next
> return
> end
robot stops each time it needs to check the sensors. Is there anyway I can
eliminate this? Can I shorten my code? All help is greatly appreciated.
Thank you.
> John Baker
> Do you Yahoo!?
> Yahoo! Groups Links
the servo NO FASTER THAN every 10 mSec -- 20 mSec
is recommended. So I am not suggesting that
you refresh your servos faster.
My point was, currently you are waiting that
10 mSec in each subroutine. You could easily
use some of that 10 mSec to read your sensors
in the MAIN loop, and THEN wait 10 mSec before
the next refresh.
To make your life easier,
all you would have to do is insert one
'PAUSE 10' after FIRSTHALL: and HALLTODOOR:,
and INTOROOM1:
then remove the 'PAUSE 10' lines from the
subroutines. This would guarantee the pause
happened ONCE for each main loop, instead
of once for every subroutine
call you make.
unpredictable behavior. I'm using standard modified servos. Where
else would I put these pauses? Are you suggesting that I put one
pause 10 in each "main" loop? Also, I read somewhere about a serial
servo controller. Would it be faster to just "serout" a command, and
use the rest of the code the way it is? Thank you for your time.
lines
> > Here is my code:
> > '{$STAMP BS2}
> (fire-fighting)
> > GOSUB checksensors
> > GOSUB forward
> > GOTO firsthall
> > radjust1:
> > GOSUB radjust
> > GOTO Firsthall
> > ladjust1:
> > GOSUB ladjust
> > GOTO Firsthall
> > left1:
> > GOSUB left
> > halltodoor1:
> > GOSUB checksensors
> > GOSUB forward
> > GOTO halltodoor1
> > radjust2:
> > GOSUB radjust
> > GOTO halltodoor1
> > ladjust2:
> > GOSUB ladjust
> > GOTO halltodoor1
> > left2:
> > GOSUB left
> > intoroom1:
> > GOSUB checksensors
> > GOSUB forward
> > GOTO intoroom1
> > radjust3:
> > GOSUB radjust
> > GOTO intoroom1
> > ladjust3:
> > GOSUB ladjust
> > GOTO intoroom1
> > checkforfire:
> > checksensors:
> > OUTPUT 0 'delay
> > OUTPUT 1 'delay
> > OUTPUT 2 'delay
> > return
> > forward:
> > FOR a = 1 TO 10
> > PULSOUT 12,1000
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > left:
> > FOR a = 1 TO 20
> > PULSOUT 12,500
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > right:
> > FOR a = 1 TO 20
> > PULSOUT 12,1000
> > PULSOUT 13,1000
> > PAUSE 10
> > next
> > return
> > ladjust:
> > FOR a = 1 TO 6
> > PULSOUT 12,800
> > PULSOUT 13,500
> > PAUSE 10
> > next
> > return
> > radjust:
> > FOR a = 1 TO 6
> > PULSOUT 12,1000
> > PULSOUT 13,700
> > PAUSE 10
> > next
> > return
> > end
Is
is
> > John Baker
> > Do you Yahoo!?
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
You are doing the Servo stuff using 'FOR'
loops -- so you can't remove the PAUSE 10
inside the FOR loop. My Bad.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> When using servos you can 'refresh' the pulse to
> the next refresh.
> and INTOROOM1:
> call you make.
and
> lines
robot.
> > > Here is my code:
> > > '{$STAMP BS2}
> > (fire-fighting)
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO firsthall
> > > radjust1:
> > > GOSUB radjust
> > > GOTO Firsthall
> > > ladjust1:
> > > GOSUB ladjust
> > > GOTO Firsthall
> > > left1:
> > > GOSUB left
> > > halltodoor1:
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO halltodoor1
> > > radjust2:
> > > GOSUB radjust
> > > GOTO halltodoor1
> > > ladjust2:
> > > GOSUB ladjust
> > > GOTO halltodoor1
> > > left2:
> > > GOSUB left
> > > intoroom1:
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO intoroom1
> > > radjust3:
> > > GOSUB radjust
> > > GOTO intoroom1
> > > ladjust3:
> > > GOSUB ladjust
> > > GOTO intoroom1
> > > checkforfire:
> > > checksensors:
> > > OUTPUT 0 'delay
> > > OUTPUT 1 'delay
> > > OUTPUT 2 'delay
> > > return
> > > forward:
> > > FOR a = 1 TO 10
> > > PULSOUT 12,1000
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > left:
> > > FOR a = 1 TO 20
> > > PULSOUT 12,500
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > right:
> > > FOR a = 1 TO 20
> > > PULSOUT 12,1000
> > > PULSOUT 13,1000
> > > PAUSE 10
> > > next
> > > return
> > > ladjust:
> > > FOR a = 1 TO 6
> > > PULSOUT 12,800
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > radjust:
> > > FOR a = 1 TO 6
> > > PULSOUT 12,1000
> > > PULSOUT 13,700
> > > PAUSE 10
> > > next
> > > return
> > > end
> Is
help
> is
> > > John Baker
> > > Do you Yahoo!?
> > Yahoo! Groups Links
> > Do you Yahoo!?
Controller. I'd love to build my own, but I don't know where to start. I've
never successfully programmed a PIC.
Allan Lane <allan.lane@h...> wrote:Oh, darn, I just re-read your
code.
> the next refresh.
> and INTOROOM1:
> call you make.
and
> > Allan Lane wrote:You have a lot of 'Pause 10'
> lines
robot.
> > > Here is my code:
> > > '{$STAMP BS2}
> > (fire-fighting)
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO firsthall
> > > radjust1:
> > > GOSUB radjust
> > > GOTO Firsthall
> > > ladjust1:
> > > GOSUB ladjust
> > > GOTO Firsthall
> > > left1:
> > > GOSUB left
> > > halltodoor1:
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO halltodoor1
> > > radjust2:
> > > GOSUB radjust
> > > GOTO halltodoor1
> > > ladjust2:
> > > GOSUB ladjust
> > > GOTO halltodoor1
> > > left2:
> > > GOSUB left
> > > intoroom1:
> > > GOSUB checksensors
> > > GOSUB forward
> > > GOTO intoroom1
> > > radjust3:
> > > GOSUB radjust
> > > GOTO intoroom1
> > > ladjust3:
> > > GOSUB ladjust
> > > GOTO intoroom1
> > > checkforfire:
> > > checksensors:
> > > OUTPUT 0 'delay
> > > OUTPUT 1 'delay
> > > OUTPUT 2 'delay
> > > return
> > > forward:
> > > FOR a = 1 TO 10
> > > PULSOUT 12,1000
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > left:
> > > FOR a = 1 TO 20
> > > PULSOUT 12,500
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > right:
> > > FOR a = 1 TO 20
> > > PULSOUT 12,1000
> > > PULSOUT 13,1000
> > > PAUSE 10
> > > next
> > > return
> > > ladjust:
> > > FOR a = 1 TO 6
> > > PULSOUT 12,800
> > > PULSOUT 13,500
> > > PAUSE 10
> > > next
> > > return
> > > radjust:
> > > FOR a = 1 TO 6
> > > PULSOUT 12,1000
> > > PULSOUT 13,700
> > > PAUSE 10
> > > next
> > > return
> > > end
> Is
help
> is
> > > John Baker
> > > Do you Yahoo!?
> > Yahoo! Groups Links
> > Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
