Reading Small Voltages
Hello again.
Can a Stamp read voltages as small as 1mV, and discriminate between
signals that differ in magnitudes similar to 1mV?
If not, is there a workaround that would allow me to use small
voltage values in the Stamp programming?
Perhaps a serial interface that would feed the values to the stamp?
I want to detect angular displacement using a Honeywell HMC1501
displacement sensor. Info is is at www.digikey.com, search for
HMC1501.
Thanks in advance.
HMC1501.
Thanks in advance.
sensor range to span 0 to 4 volts. Send this amplified signal through a
12-bit A/D converter, where 2^12 = 4096, and use a reference value for
the A/D = 4.096 volts. The Maxim MAX187 is one A/D example among others
with this reference built in. The resulting Least Significant Bit (LSB)
reading is then = 4 volts / 4096, or close to 1 mV. The MAX187 has a
serial output for sending data to a Stamp.
You may have to adjust the sensor's output to zero, before amplifying,
which could be done with another op amp.
Dennis
From: Pablo Roufogalis L. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L8SUSsXtPMyyEY7hx4U2RArk5vwzx1xI2L3cTERG8tPDFn1c-i5n3NtrEkZEHe1AKPFzjHxs]proufo@c...[/url
Sent: Saturday, February 07, 2004 2:49 PM
Subject: [noparse][[/noparse]basicstamps] Reading Small Voltages
Hello again.
HMC1501.
Thanks in advance.
Yahoo! Groups Links
wrote:
> Use an op amp to amplify the sensor signal with a gain that allows
the
through a
for
others
(LSB)
a
amplifying,
> Dennis
Hello Dennis and thanks for the reply.
I don't understand the bit about adjusting the sensor's output to
zero before amplifying. My apologies for my ignorance. I don't know
much about these things.
Another thing: would noise be an issue if I wanted to measure 1/4th
of a mv, with a sensor range of, say, 50 mv?
BTW, I need to measure both positive and negative values. Would I
need a different A/D converter or a different scheme altogether? So
the above should be a range of -50 to 50 mv.
Many, many thanks in advance.
<proufo@c...> wrote:
> --- In basicstamps@yahoogroups.com, Dennis O'Leary <doleary@e...>
allows
> the
> through a
value
> for
> others
Bit
> (LSB)
has
> a
> amplifying,
> > Dennis
Do a little reading about op-amps.
This is NOT light reading at 464 pages, but might cover most
everything.
http://www.ee.nmt.edu/~thomas/data_sheets/op-amp-slod006a.pdf
You can get an op-amp with positive and negative voltages so that you
can read your +/- range.
Depending on the sensitivity you need, you can use a pair of inputs
on an op-amp and have one for inverting and one non-inverting so as
to read one ADC input for + readings and one for - readings.
The generic idea of the op-amp is that you connect your device to one
input and by using a few resistors, your op-amp can ampliphy the
signal.
Select the correct resistors and your 50mV can enter and the op-amp
can output 5 volts. The output would be linear, so 25mV would be 2.5
volts and so on.
The Analogue to Digital Controller (ADC) would then break your 5 volt
signal into parts, 512, 1024 or 4096 (or some such) depending on the
device. A 12 bit ADC will not be too expensive.
So, one way is to use a +/- voltage op-amp and have your input -5 to
0 to +5 volts.
Another way is to use a dual op-amp and input 0 to 5 volts that
represensts 0 to -50mV. And another channel that represents 0 to
5V from a 0 to +50mV input.
Google op-amp, check the sites like TI for data sheets. There are
more sites than you can imagine that will walk you thru the basics.
Once you have the basics, ask again, and we'll be able to offer some
things to watch out for.
BTW, Parallax has data sheets on connecting the ADC(s)
Dave
Dave
Will check the document.
I planned to use optical gratings and once the design was almost
finalized, I bumped into a magnetic device for measuring angular
deviation.
Maybe by the time I finish this second scheme, I'll move to moir
> Hello again.
> HMC1501.
> Thanks in advance.
Pablo,
I have a similar problem. I need to measure a -100 to +100 mv range
from a DC current shunt. I've been told this can be done using a
TLC2543 (Texas Instruments) ADC. This chip features 11 analog input
channels, an external reference input, low internal noise, and a
three-wire interface. It also has a bi-polar conversion mode, which
has a range of 1/2 of the reference voltage. So, if you used a 100 mv
reference, you would be able to convert -50 to +50 mv. Allegedly. I
have the chip but haven't tried using it yet. It costs $9 from
HobbyEngineering.
I intend to power the chip using a UA723 precision voltage regulator
(Texas Instruments). By setting the regulator's output to 5.12 volts,
the finest resolution when using the TLC2543's internal reference
would be 1 mv. I will be using a 204.8 mv external refernece for my
current readings, giving me a range of -102.4 to +102.4 mv, with a
resolution of 102.4/2048 mv, whatever that turns out to be! My 204.8
mv reference will be obtained by a voltage divider from the 5.12
output of the regulator.
For noise rejection, try a low pass filter on the ADC input.
Depending on the ADC you choose, a 1k to 10k low noise resistor in
series with the input shouldn't affect the reading since the input
current is so very small. Put a small capacitor from the ADC input to
the chip's ground pin. Cap size will depend on the frequence range
of your signal. You want to filter out the higher frequencies as much
as possible.
Finally, don't rely on a single reading. Take several and average them.
Good luck!
Russ
Rus is right about the series resisitor, especially if there is any chance
the input voltage can exceed the vRef. I have burnt a TLC2543 this way. The
chip can do a CMOS lockup and conduct a lot of current. Since I had
foolishly powered the ADC from the vReg of a B2p40, I also burnt the onboard
reg.
> as possible.
Oddly, that doen't seem to help me, although it should. I have tried .1 and
.01uF caps, and it doesn't reduce the noise. I find the noise level to be
about 1-3 mV depending on source. I also find that a .1 cap across the power
input doesn't help. I guess this means my circuit is fairly quiet.
Jonathan
www.madlabs.info
wrote:
> Pablo, Russ,
chance
way. The
onboard
> reg.
> > as possible.
.1 and
to be
the power
> Jonathan
> www.madlabs.info
Jonathan,
Have you used an oscilloscope to check the noise at the ADC input pin?
What about the converter's Vdd pin? If you're running the ADC chip
from the Stamp's Vdd, you can expect a bit of noise from that. This
would be translated to a fluctuating reference voltage in the ADC.
Try a resistor in series with the ADC's Vdd, with a pretty hefty
capacitor to ground. Try a 100 ohm resistor and a 10 microfarad
capacitor. Should stabalize the voltage a bit. Or do what I am going
to do, use a precision regulator. It's easy for me to say this, as I
have yet to actually build such a circuit! I will let you know when I do!
Russ
my TLC2543 circuit this weekend and I've spent the last two days trying
every noise reduction method (and locations for those methods) that I knew.
I'm using a 1.024 reference voltage so thats 0.25mv per step on the ADC
(1024/4096). Going directly from my opamp to the TLC2543 with no noise
reduction other than decoupling caps on the power pins, I was getting
readings fluctuating by +/- 100 or so - REALLY jumpy.
I tried many, many things and checked the scope. Lots of things helped a
bit, several things actually made it worse! The best result I got was when I
added an RC filter between the opamp output and ADC input and now I've got
fluctuations of +/- 1. Considering the error spec'd on the datasheet is 1lsb
anyway, thats about the best performance I can expect from this ADC!
Anyway, try this - route your signal through a 1k (or higher) resistor to
the ADC pin. Next run a 0.1uF cap from the ADC pin to ground. The closer to
the ADC the two components are, the better.
Thats it, simple, cheap, but man does it work wonders!
Note: The cap may tend to keep your signal showing a little higher than a
DMM would read - you'll have to compensate for that in software if its
important to you.
Oh yeah, I should tell you the scope readings too. Bear with me - new to the
scope and I still haven't quite figured out the 1x/10x stuff. I assumed that
when the probe is set to 10x, the reading on the scope would be 1/10th of
the real value. When I have a wave that shows as 5mV high (volts/div set at
5, 1x on probe - wave spans one vertical div) then switch the probe to 10x,
the wave ends up showing as 2.5mv... So I'm not quite sure how to interpret
the volts/div and probe setting now...
Anyway. With no RC filter, probe at 1x, volts/div at 20mv, the wave spans 3
divs - 60mV(?). Add in the RC filter and, at those settings, I see a solid
flat line! I have to switch down to 5mV/div and then the wave spans one
vertical division. With time/div set at .2uS I get about 5 peaks per div
(only a 20MHz scope - I aint rich yet [noparse]:)[/noparse].
If you can afford it, get yourself a scope. Its great being able to actually
see what effects various things have on your circuit!
> From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ysT6TKRtqz-OnRB5ySpu-103b57VM7zzcu7dC9bYZadY1Lq3MhWfpUoqqwAopn9vjt2VlosVH-8GlVhdxV4]doleary@e...[/url
> Sent: February 7, 2004 3:19 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Reading Small Voltages
> Use an op amp to amplify the sensor signal with a gain that allows the
> Dennis
> From: Pablo Roufogalis L. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=I8i8TfySCO0fzEePadzoTCv-myqvxG0uZxkjXf42kTd12vHF7qi54vuUh3GQD8qZNYfiJsDanA]proufo@c...[/url
> Hello again.
> HMC1501.
> Thanks in advance.
> Yahoo! Groups Links
> Yahoo! Groups Links
I think you have a couple of misconceptions about how the TLC2543
works that will need to be cleared up before you build anything or
write your Stamp program or the Javelin class function. Read the
data sheet very carefully!
-- The chip does not have an internal reference. The reference for
the chip is always the voltage applied to the external ref- and ref+
pins. So if you need to switch between two different reference
voltages, you will have to provide an external switch to do it.
(There are some A/D converters that do provide an internal reference,
for example, the TLV2556 does but the TLC2543 does not. The
MAX1238/39 has a choice of internal reference to the power supply,
internal to 4.096 volts, or externa. The MAX1270 has a selection of
references and does in fact accept bipolar inputs below Vss when
running on a single 5 volt supply.)
-- The minimimum reference voltage stated on the TLC2543 data sheet
for 12 bit resolution is 2.5 volts, from ref+ to ref-. Thus a 0.2084
volt reference is way below the specification, and you probably can't
get 12 bits of real resolution out of it. It does not hurt to try
though, and it will probably be pretty good.
-- Yes, the chip has a "bipolar" mode, but that does not mean it
will, for example, read voltages from -104.2 to +104.w when you apply
a 208.4 volt reference. What it means is
+104.2 volts input output a code of 0
0 volts input is a code of -2047
+208.4 volts input is a code of +2047
in twos complement. You would have to offset your truly bipolar
input to take advantage of that. It might be possible to use a
reference of -104.2 millivolts to ref- and +104.2 millivolts to ref+,
and that would give you the input span you need. The data sheet does
specify a common mode input range for the ref- down to 0.1 volt below
the Vss supply. But you would have to try it to be sure there isn't
some other gotcha'. It is not an application that is explicitly
treated in the data sheet, and it is always dangerous to assume that
a chip can do something that is over the edge of its intended design.
You could also try the converter with Vss offset to a negative
voltage. -- Or evaluate a different ADC such as the MAX1270, one
designed for signals below Vss.
-- Be sure to use protection resistors in the signals paths! Be
careful with with bypassing and with the analog ground path in
relation to ref-, to avoid noise.
-- I have Stamp demo code for the TLC2543 posted at
<http://www.emesystems.com/OL2tlc2543.htm>
-- regards,
Thomas Tracy Allen Ph.D.
mailto:tracy@e...
>--- In basicstamps@yahoogroups.com, "Pablo Roufogalis L."
>> Hello again.
>> HMC1501.
>> Thanks in advance.
>Pablo,
>HobbyEngineering.
>as possible.
>Good luck!
>Russ
connection between the probe tip and the scope's input ami;ifier. The
This is generally a 1 megohm load. The 10x setting places a 9 megohm
resistor in seriew with the signal, thous making a 10:1 divider. The
series resistor has a trimmer capacitor in parallel with it to
compensate for the capacitance of the cable and scope input. In
general, use the 10x setting because the 1x will place a capacitive
load on your source, which means it could be masking the source
sigmal/noise.
You wrote: "With time/div set at .2uS I get about 5 peaks per div ..."
This implies that your noise is 0.04us per cycle, which works out to
about 25 megahertz. Seems to about the range of a cpu's clock. To
reduce the noise, put the entire ADC, including a power supply that is
separate from the computer, in a shielded box, with the box connected
to ground.
I have a Techtronix 464 scope. Got it on eBay for $200 or so. It's a
beauty!
--- In basicstamps@yahoogroups.com, PatM <pmeloy@s...> wrote:
> What a coinkidink! Having just (finally) bought an oscilloscope, I
dug out
trying
I knew.
was when I
I've got
is 1lsb
resistor to
closer to
than a
> important to you.
new to the
assumed that
1/10th of
set at
to 10x,
interpret
spans 3
solid
actually
> > From: Dennis O'Leary [noparse][[/noparse]mailto:doleary@e...]
through a
others
(LSB)
> > Dennis
> > From: Pablo Roufogalis L. [noparse][[/noparse]mailto[noparse]:p[/noparse]roufo@c...]
> > Hello again.
> > HMC1501.
> > Thanks in advance.
> > Yahoo! Groups Links
> > Yahoo! Groups Links
I'm getting cold feet regarding this approach. Somewhat disappointed,
I'll go back to optical gratings and high/low signals.
If I don't get the results I need, I will try the Op-amp/ADC approach
then, but at this point it doesn't seem to be a promising path. The
noise figures mentioned here are similar to what I'll get as a signal
from the device.
Thanks again to all.
correct. I have read so many data sheets in the past few weeks that
they are getting all jumbled up in my mind! Yes, the MAX1270 appears
to be a better choice for my application.
I can amplify the 100 mv levels by 50x or so easily enough. Only one
of my sources will actually be bi-polar, and this can be handled by
biasing the op-amp appropriately (I think). I'm not used to using
these 5-volt only devices, especially op-amps! In the "old days" I'd
simply sum the input with a +100 mv level at the op-amp's - input
terminal, or feed it into the + input. Not sure which I'd do.
Glad it's not off the drawing board yet!
Russ
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Russ,
> -- regards,
> mailto:tracy@e...
> >> Hello again.
> >> HMC1501.
> >> Thanks in advance.
> >Pablo,
> >HobbyEngineering.
> >as possible.
them.
> >Good luck!
> >Russ
LTC1298) and get 0.2 mV resolution. If you need more resolution, get a
16-bit ADC.
-- Jon Williams
-- Dallas Office
From: Pablo Roufogalis L. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B8PoEhcnhdD1kKh4HjumyOQM6N2P_Oi1CN4KaaNRQ3boTcEb3cvstjoxKwQ2d0fKxvl6ezTH37SsZw]proufo@c...[/url
Sent: Saturday, February 07, 2004 4:49 PM
Hello again.
HMC1501.
Thanks in advance.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
5-volt range will give you 1.2 mV resolution. As indiciated in another
post, if you set your reference to 4.096 volts you can set the volts/bit
to 1 mV.
-- Jon Williams
-- Dallas Office
Sent: Monday, February 09, 2004 7:58 AM
Assuming that your span is 5 volts, you can use a 12-bit ADC (like the
16-bit ADC.
-- Jon Williams
-- Dallas Office
From: Pablo Roufogalis L. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E9K2mxF9Pbrpf9EjiaCUhXGKmiX-lw-OcmR3GwROIaziHKRCKMr-WcIHOm6eQ1g_avdFqmFWCEzeKw]proufo@c...[/url
Hello again.
HMC1501.
Thanks in advance.
I will use an optical grating first, with simple high/low logic,
hoping it will do all I need.
Thanks again.
