No sign on life in a chip...
I just recieved the breadboard for the 2p40 chip i have from a while
back and upon updating an older 2p40, i go to load the sw into the
chip and the software says it was successfull.
Problem is one of the commands is to make mainau pin15 on but the led
does not light up.
I assume that if it loaded the sw the chip is not toast right?
does not light up.
>does not light up.
Generally true, but one port may be blown and the rest of the chip may be okay.
Did you use the appropriate AUXIO or MAINIO command in the program ? Is the LED
connected correctly ?
You might also want to change the port assignment and try a different I/O port
to see if Port 15 is indeed blown. You may additionally want to add a DEBUG
statement as the first thing in the program: DEBUG "Executing" to ensure that
program execution has begun.
Bruce Bates
16-31 aux I/O. could you post your program? if not just simply do the
following
i always use the debug command when using outputs. it kind of prevents the
stamp from going to sleep.
also make sure the LED is good.
Debug cls
main
high 15
end
Gary
>does not light up.
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
going to sleep, but you may need to use it on your laptop computer to
keep the serial port from going to sleep.
The BS2p40 has two groups of pins: MAINIO and AUXIO. You must first
select the group, then pin fuctions will work in that group thereafter.
So, if you want to turn on AUXIO P15, you would do this:
Test:
AUXIO
HIGH 15
STOP
And yes, make sure your LED is good before assuming you've got a duff
Stamp.
-- Jon Williams
-- Dallas Office
From: Gary Denison [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MRsYnYwvpLG35KfwptFBOItXEcsUaimKFOc8uawm1PPzzxunJjh_JXIX5oxQRO1JD0jp]gdii@c...[/url
Sent: Friday, February 06, 2004 9:41 AM
Subject: Re: [noparse][[/noparse]basicstamps] No sign on life in a chip...
to my knowledge of the BS2p40 15 is not an Auxiliary I/O 0-15 main I/O
and
following
the
Debug cls
main
high 15
end
Gary
>back and upon updating an older 2p40, i go to load the sw into the chip
>and the software says it was successfull. Problem is one of the
>commands is to make mainau pin15 on but the led does not light up.
mainio
output 15
test:
out15=1
pause 1000
out15=0
pause 1000
goto test
Then i put the volt meter to the pin15 and it read 0 volts for a few minutes.
It send the commands into the chip successfully and that is why i wonder if the
chip itself is hosed.
Jon Williams <jwilliams@p...> wrote:
For clarification, you don't need to use DEBUG to keep the Stamp from
Test:
AUXIO
HIGH 15
STOP
Stamp.
-- Jon Williams
-- Dallas Office
From: Gary Denison [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y62TgixU4yGvOo7Jyuveeb_bw_9_3HsEIb-GfQ6M2GnWNFS03ZqlxAi48Bb7aS7Lhhjw]gdii@c...[/url
and
following
the
Debug cls
main
high 15
end
Gary
from the same email address that you subscribed. Text in the Subject and Body of
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Pins 16-31 are addressed as pin 0-15 as well. You have to add the AUXIO
command to access them, then remember to include a MAINIO command when you
want to address the main pins after having used the AUXIO command.
Forgetting the MAINIO or AUXIO has buggered me more than once.
Jonathan
www.madlabs.info
Sent: Friday, February 06, 2004 7:40 AM
and
> following
> Debug cls
> main
> high 15
> end
> Regards,
> Gary
> >does not light up.
> >Yahoo! Groups Links
> Yahoo! Groups Links
At 08:06 AM 2/6/2004 -0800, you wrote:
>Gary,
>Jonathan
>www.madlabs.info
>From: "Gary Denison" <gdii@c...>
>and
> > following
> > Debug cls
> > main
> > high 15
> > end
> > Regards,
> > Gary
> > >does not light up.
> > >Yahoo! Groups Links
> > Yahoo! Groups Links
>Yahoo! Groups Links
all of the stamp I/O lines are OPEN COLLECTOR. A pull up resistor 1k to 10k
should be fine, MUST be used to achieve valid logic states.
does not light up.
Yahoo! Groups Links
Do you Yahoo!?
BASIC Stamp is capable of sinking and sourcing current.
-- Jon Williams
-- Dallas Office
From: PHILIP GAMBLIN [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Qd6K62Ri14t7DFT__YzrcljoiCVjEzFlYF8a8BMLreSu35s8ShYEdjGdsUZjSQ4_rhZbltV6XE9J_3k]gremlin8650@y...[/url
Sent: Friday, February 06, 2004 4:15 PM
for what it is worth.
10k should be fine, MUST be used to achieve valid logic states.
Jon Williams <jwilliams@p...> wrote:This is NOT CORRECT; the Stamp IO
pins are not open-collector. The
-- Jon Williams
-- Dallas Office
From: PHILIP GAMBLIN [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eOjffAt2Pdqmphj0PYtH5N2BvW_t84m2McpWRH36xqOp-3e-dqa5fCOYhZLhsmgVWfkOWXmlRcRqgc4ISPo]gremlin8650@y...[/url
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
