New stamp project involving air and water valves — Parallax Forums
edited 2004-02-06 22:34 in General Discussion
I could use some advice. Here is the start of my TO DO list:
1. Find a source for the appropriate valves
1a. Air valve for compressd air system, up to 90 PSI but I imagine it will
be lower pressure.
1b. Water valve for city water pressures.
1c. Water valve for low pressure gravity feed--ideally 1b and 1c would be
the same model valve.
2. Figure out appropriate method of actuating valves--depending on what kind of
voltage/current levels these valves need. I would like to stay away from relays
if possible.
The above really is the only part I am unsure of. The construction details and
software should be a snap. Can anybody give me some suggestions?
--Dan
    edited 2004-02-04 01:49
    Sprinkler valves should work, Rainbird or brand X. Values operate on 24v,
    don't know current draw. Price for a 3/4" brand X is about $10, 1" a little
    higher. These should work for both pressure and gravity. Available from
    Home Depot.
    Jay Hocott
    5900 Geyer Springs Road
    Little Rock, ARkansas 72209-1842
    Phone: (501) 568-9524, 580-4608
    email: jhocott@s..., jay@h...
    Web site: http://www.hocott.net
    "Good is better than evil because it's nicer." Mammy Yokum
    Sent: Tuesday, February 03, 2004 12:14 PM
    Subject: [noparse][[/noparse]basicstamps] New stamp project involving air and water valves
    will be lower pressure.
    be the same model valve.
    kind of voltage/current levels these valves need. I would like to stay away
    from relays if possible.
    details and software should be a snap. Can anybody give me some
    suggestions?
    > Thanks
    > --Dan
    > Yahoo! Groups Links
    > To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    > To unsubscribe from this group, send an email to:
    > Your use of Yahoo! Groups is subject to:
    > This message has been processed by Firetrust Benign.
    edited 2004-02-04 02:20
    Having spent a good deal of my life working for Toro, let me suggest
    them too! [noparse];)[/noparse]
    Common irrigation valves are actuated with 24 VAC -- you'll have to use
    a triac ciruit. Save yourself some trouble, and locate a solid-state
    relay.
    -- Jon Williams
    -- Parallax
    From: Jay Website [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K43NlkCiftWelP3PoWZD6lTj7Vcv99akTGXG-Kj6aeuV0HSGGwxojJWnl68dSlsQXSP3BFS5Tg]jay@h...[/url
    Sent: Tuesday, February 03, 2004 7:49 PM
    Subject: Re: [noparse][[/noparse]basicstamps] New stamp project involving air and water
    valves
    24v, don't know current draw. Price for a 3/4" brand X is about $10, 1"
    a little higher. These should work for both pressure and gravity.
    Available from Home Depot.
    Jay Hocott
    Yokum
    > it
    > would
    > what
    away from relays if possible.
    suggestions?
    > Thanks
    > --Dan
    edited 2004-02-04 03:12
    How are they actuated? Is their some kind of inductive circuit in their
    that requires AC? Any ideas on a suitable air valve? I don't believe either
    of you were suggesting that these valves would work for air also, please
    let me know if you were.
    --Dan
    Sent: Tuesday, February 03, 2004 6:20 PM
    Subject: RE: [noparse][[/noparse]basicstamps] New stamp project involving air and water valves
    > relay.
    > -- Jon Williams
    > -- Parallax
    > From: Jay Website [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OhheZzm7drkDCnGIw7-DWd_UD1qrYnfQULyoZsae0o9uNOwWR7IxPFRjmVXKUOrXNgLGFKUe]jay@h...[/url
    > valves
    > Jay Hocott
    > Yokum
    > From: "Dan" <dankgus@p...>
    > > it
    > > would
    > > what
    > suggestions?
    > > Thanks
    > > --Dan
    > Yahoo! Groups Links
    edited 2004-02-04 03:25
    Water valves use a solenoid to pull a plunger off a small port that
    releases incoming water pressure from the top of the diaphragm that
    closes the main stream of water. Most consumer water valves are not
    suited for air.
    -- Jon Williams
    -- Parallax
    From: Dan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uRHWjEVXWuFzUcr--zDklbn9AIjh6U0dvfQoz9DPATWIsKJxSHK1_ddgxUt8wlf9qZS4V-WoIqMjfWE]dankgus@p...[/url
    Sent: Tuesday, February 03, 2004 9:12 PM
    valves
    either of you were suggesting that these valves would work for air
    also, please let me know if you were.
    --Dan
    valves
    > use a triac ciruit. Save yourself some trouble, and locate a
    > solid-state relay.
    > -- Jon Williams
    > -- Parallax
    > From: Jay Website [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZNzpsDY_1-gZSBCQ_3tkoM-mqKBJkzhPTFWcBd4ESCA2pVHw6j5sQI2X5ODTQodE_7uWTVKyzX2a]jay@h...[/url
    > valves
    > 1" a little higher. These should work for both pressure and gravity.
    > Jay Hocott
    > Yokum
    valves
    > > imagine
    > > it
    > > would
    > > what
    > stay away from relays if possible.
    > suggestions?
    > > Thanks
    > > --Dan
    edited 2004-02-04 03:35
    imagine it will be lower pressure.
    1c would be the same model valve.
    what kind of voltage/current levels these valves need. I would like
    to stay away from relays if possible.
    suggestions?
    > Thanks
    > --Dan
    > I work small solenoid valves on a regular basis. 1/4'' npt ports
    typically rated to 125-150 psig for water or air service. These are
    industrial parts and are not cheap. $150 or so. Coil voltages are
    120v AC and 24 vdc are available (maybe others) Cheaper sources
    appliance parts dishwashers and clothes washing machines valves from
    your local appliance repair place. All easily actuated via
    transistors or mosfets or relays. good luck
    edited 2004-02-04 10:20
    Hi Dan,
    I use ASCO valves all the time with stamps. They are industrial quality and
    cost $100-$130 each. They are brass body valves and quite reliable. I use them
    for Water, Natural Gas, Oxygen, Compressed Air, and Nitrogen.
    I connect a solid state relay (SSR) to the stamp2 out put pin and drive the
    SSR directly. Use an LED and 470 Ohm resistor for a pull-up. This will act as
    the pull-up resistor, an indicator the circuit is active, and current limits
    the output pin to 3 - 4 ma so you don't have to worry about Max pin output
    current. Search Digikey for Grayhill Mini SSR units. I am away from my office or
    I
    would give you part numbers.
    I use 120 VAC Solenoids, but this works for 24 VAC or DC units.
    The advantage to the industrial units is they are rated for continuos use,
    and less prone to failure. You need to think of the cost/damage if the unit
    fails and lets the water/air run for a few hours/days unchecked due to a
    failure.
    Contact me if you need more info.
    Hope this helps,
    Alan Bradford
    Plasma Technologies
    www.plasmatechnologies.com
    In a message dated 2/3/2004 8:42:26 PM Eastern Standard Time,
    dankgus@p... writes:
    of voltage/current levels these valves need. I would like to stay away from
    relays if possible.
    and software should be a snap. Can anybody give me some suggestions?
    --Dan
    edited 2004-02-04 13:25
    check out this web site for methods to switch valves using transistor
    interfacing.
    jim http://www.geocities.com/jimforkin2003/
    From: gremlin8650 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6LNiM_SAB-CJPf3vzSvPYak9_b8Kh2U0te8zU4oB52ZEZQE2-xF4N3ZpWXtV21VpI6j1QXs88ODYDP5KYw]gremlin8650@y...[/url
    Sent: Tuesday, February 03, 2004 10:36 PM
    Subject: [noparse][[/noparse]basicstamps] Re: New stamp project involving air and water
    valves
    suggestions?
    > Thanks
    > --Dan
    Yahoo! Groups Links
    edited 2004-02-05 03:47
    forgot to mention the site www.asco.com they don't sell direct, you'll need to
    find a local rep. What about lawn sprinkler valves?
    Jim Forkin <jjf@p...> wrote:check out this web site for methods to switch
    interfacing.
    From: gremlin8650 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jFyes99ourh4z9ilnLX7s-_ykg5A6GrFjluEyC1EHqCCTDZU7iO004UA4fUy_4i3t9YFvs1HLcM8Op6F]gremlin8650@y...[/url
    valves
    suggestions?
    > Thanks
    > --Dan
    Yahoo! Groups Links
    from the same email address that you subscribed. Text in the Subject and Body of
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Finance: Get your refund fast by filing online
    edited 2004-02-05 10:52
    The ASCO site will direct you to as local distributor, as well as a large
    selection of valves. They are by no means the only supplier, but the only one I
    have used for the past 10 years, due to the quality of the product.
    I purchase them from a distributor in Worcester Mass. They have a large
    selection and have many in stock for overnight delivery.
    Washburn-Garfield Group
    PO Box 947
    100 Prescot Street
    Worcester MA 01613 USA
    508 753 7225
    Alan Bradford
    Plasma Technologies
    In a message dated 2/5/2004 12:50:14 AM Eastern Standard Time,
    gremlin8650@y... writes:
    to find a local rep. What about lawn sprinkler valves?
    edited 2004-02-06 19:50
    Asco valves are indeed nice. I frequently use them in commercial
    applications. (Their payback for donating a couple back when I was a
    poor college student working on senior project.)
    Precision Dynamics also has a nice selection in the $40-60 range. I
    normally buy them hrough a distributor, but supposedly they just set up
    an e-commerce section on their site. www.predyn.com
    IIRC, the original poster didn't define any flow requirements. The size
    and price of the valve will depend on this.
    amg
    On Thu, 5 Feb 2004 05:52:05 EST plasmastamp@a... writes:
    > Hi,
    > large selection of valves. They are by no means the only supplier, but
    the
    > only one I have used for the past 10 years, due to the quality of the
    product.
    ________________________________________________________________
    The best thing to hit the Internet in years - Juno SpeedBand!
    Surf the Web up to FIVE TIMES FASTER!
    Only $14.95/ month - visit www.juno.com to sign up today!
    edited 2004-02-06 20:17
    I didn't mention flow rates because I haven't actually calculated any.
    After looking at the valves and seeing many of them have 1/4" and 3/8" ports
    I realize flow rates are a concern. I was imagining 1" size valves but that
    is just my mind creating the ideal part. Gravity feeding in a 1" valve
    would still have decent flow but 3/8" I am not so sure of. Basically I am
    using gravity to drain a tub full of a solution into a reservoir, spray off
    a part in the now empty tub with fresh water-which will drain to sewer, and
    then use compressed air from a compressor to pressurize the reservoir and
    push the solution from the reservoir back into the tub. The reason for
    using air pressure is because I then do not need a pump. In my experience,
    pumps are great but they eventually fail, so the air pressure eliminates the
    mechanical failure prone pump. I don't know the size of the tub and
    reservoir yet but I am guessing it will be no more than 10 or maybe 15
    gallons-maybe even as little as 5 gallons.
    You guys have been great, I appreciate every bit of input and I still
    appreciate any tips you might have.
    --Dan
    Sent: Friday, February 06, 2004 11:50 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: New stamp project involving air and water
    valves
    > amg
    edited 2004-02-06 20:20
    Thanks for the tip on Precision Dynamics, the website is actually
    http://www.predyne.com/
    --Dan
    valves
    edited 2004-02-06 22:08
    yes ordinary pumps do fail, especially when pumping nutrient solutions or
    other solutions with potentially corressive soloutions. I'm using a 12v dc
    pump from a motorhome. Works great, flow is quite good. Just a thought as
    an alternative3.
    Jay Hocott
    Sent: Friday, February 06, 2004 2:17 PM
    valves
    ports
    that
    off
    and
    experience,
    the
    > Thanks,
    > --Dan
    > From: "amg amg" <controlsdude2000@j...>
    > valves
    > > amg
    > Yahoo! Groups Links
    Hi Dan,
    The bigger the valve the more $ it cost. The 3/8" and 1" sizes are for the
    pipe to thread into it. You need to check the specifications to see what size
    the actual opening of the valve is. It is much smaller than the pipe size.
    You will have to determine how fast the tank drains Vs how much you want to
    spend on valves. If you need to dump the tank quickly, then you will need to
    look into a motorized ball valve. These have a ball that blocks the flow. When
    opened, by rotation, the opening is the pipe size. I have not used motorized
    ones, but hand opening ones work good. Just more $$$.
    This is an excellent application for a stamp controller, as the speed is not
    high, and the reliability is good. I use stamps in this type of industrial
    application all the time. I use 120 VAC solenoids for most of my projects. I
    need
    to use a SSR to control it so by using 120 VAC units I can eliminate the need
    for a 24 VDC power supply.
    You will want to use good quality sensors as overflow problems could be
    expensive.
    I do not know what type of solution you use, but make sure it is not
    reactive, or corrosive to Brass. If so then you may need to use Stainless Steel
    valves. Again more $$$.
    Hope this helps,
    Alan Bradford
    Plasma Technologies
    These are choices you will need to make.
    In a message dated 2/6/2004 3:23:26 PM Eastern Standard Time,
    --Dan
