usb to serial
I am trying to get my laptop to work with a 2sx. The laptop only has
usb and parallel ports. I bought a usb to serial adaptor that works
with my Palm 111c fine but not the stamp. Any ideas?
Ian
Ian
luck with Bafo adapters, but non with anyone else.
-- Jon Williams
-- Dallas Office
From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QhF6uXHc9W3DLBkbkj44P5nidezTFbknYMocfv26m9YQTmEl_lDlCGzI66nus5NOh4W5rqqk3fqmoTIVceY]iphillips@s...[/url
Sent: Tuesday, February 03, 2004 12:25 PM
Subject: [noparse][[/noparse]basicstamps] usb to serial
Ian
Make sure of that.
The adapter may not have all the pins of the RS232 serial port.
Or, the voltage that the BS outputs, may not be sufficient for that adaptor.
Maybe another problem. Check your voltage levels.
Antonio Sergio Sena
> Ian
http://www.parallax.com/detail.asp?product_id=800-00030
I bought one after trying a Belkin on my new Sony machine. The Belkin
didn't work on any of my serial critters (Garmin 12/Topo!, Casio Watch
IR interface, Yaesu VX5 ham radio, and the Basic Stamp). The BAFO
works on all of them.
Dick Ballard
ballardr@a...
port which works just fine with the BS2 and
BX24(netmedia microcontroller).
--- Jon Williams <jwilliams@p...> wrote:
> Not all USB adapters are created equal. We have had
> consistent good
> -- Jon Williams
> -- Dallas Office
> From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zz5rHZ2QGXPM4Y7I4X2oDd8lNr4GoyVXTQ8oKwdeiUrQzCVqzjGa9r7SafnlVXAPoRIS9yrrzZ40IX-SBQ]iphillips@s...[/url
> laptop only has
> adaptor that works
> Ian
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
can anyone tell me the safest Hardware/Software way to program the stamp
over a USB-Port? My new Notebook has no com anymore. I am using Windows XP
home edition.
Thanks in advance,
Uli
from the Parallax web-site. Not all USB-232
converters are created equal. The BAFO unit has
had no complains, nor have the KeySpan 19W units.
Stay away from "PDA" USB-232 converters, they
rarely have all the control lines needed.
Personally, I don't like Belkin, but I've had
issues with them.
--- In basicstamps@yahoogroups.com, "ulibasic" <ulibasic@r...> wrote:
> Hi Stampers,
stamp
Windows XP
> home edition.
> Thanks in advance,
> Uli
Is it possible to connect an adapter to the DB9 connector on the BOE so that
a USB cable can be used to connect the Stamp to the computer?
Sid
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> This is for Jon Williams.
BOE so that
> Sid
descript that change a DB-9 to a USB connection. Most have an attached
cable. That said, I've never had need for what you're asking so I
haven't looked for it.
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jieHLBBD6clNCkF-0Z55T57h5NxQLkWDfkO6nqgLzYLXoxnJFZeQ_DqM0xXe-9xOs1AXKAC1zw]Newzed@a...[/url
Sent: Tuesday, April 20, 2004 10:53 AM
Subject: [noparse][[/noparse]basicstamps] USB to serial
that
Sid
Yes, what you need is the Keyspan USA-19QW. I usually don't connect it
directly to the DB9 connector because they both have stand-offs; I usually
use a strait-thru male to female DB9 cable to connect the USB to serial
dongle to the robot.
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
allan.lane@h... writes:
> Doesn't the BAFO adapter do this?
I think the BAFO has a female serial connector. I need one with a male end
to plug into the BOE DB9 - but maybe I could use a gender-changer.
Sid Weaver
We're always thinking.....
http://www.visualmuses.com/chipcircuit/index.html
and a USB-B connector (the small style like on a printer) on the other
end. A USB A to B cable is included in the BAFO package.
You will have to remove the hex standoffs on the BOE DB9 in order to
use it with the BAFO. I have done this with one of the other Parallax
project boards. Removing the hex fittings won't disturb the connector
assembly mounting because the connector and metal shell are retained
independently of the standoffs.
Alternatively, you could use a standard serial cable (DB9 female to
DB9 male) between the BAFO and the BOE. The BAFO provides exactly what
you would see on a PC back panel serial connector.
This adapter works with all of my serial devices on my new PC which
has no serial ports. The Belkin adapter failed miserably.
Dick Ballard
ballardr@a...
On Tue, 20 Apr 2004 14:28:04 EDT, Newzed@a... wrote:
>In a message dated 4/20/2004 2:20:27 PM Eastern Daylight Time,
male end
The 2 BAFO's I got had 9-pin Male connectors on them. One came from
Parallax.
Knight Designs
