serial communication between BS2sx and PIC16F877
i'm using the BS2sx to interface with the PIC16f877. the PICf877
clock is 20MHz. can i established a serial communication using the
i/o pin?
i had tried to setup the communication. but i get the data from the
PIC16f877 differently everytime i tried. can anyone knows the
solution?
thanks alot for the help.
i/o pin?
solution?
problem. What you have to do is determine the baud rate and polarity of
the UART being used by your PIC device.
-- Jon Williams
-- Dallas Office
From: lewis0479 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O1SXN5T0s80A92FUxHcIzOMrWz0G5vHNCsG2gt1jv0aA8OY9pbUE64O4NWOgt0a9O5bO_9QWpzdLBBxVpw]lewis0479@y...[/url
Sent: Tuesday, February 03, 2004 2:28 AM
Subject: [noparse][[/noparse]basicstamps] serial communication between BS2sx and PIC16F877
i/o pin?
solution?
1) Your turnaround time may be too quick. Clearly, you're using a
compiler for the PIC, so the it's probably sending data back before the
Bs2sx is actually ready for it. Try to delay your response from the PIC
by 150 microseconds or so.
2) Check to make sure that the output from the PIC is driven. If the
serial routine is expecting the serial line to be pulled-up, then the
SERIN on the BS2sx won't see anything on the line. You'll need to talk
to your compiler vendor about this -- we can't be anymore help than I've
just given.
-- Jon Williams
-- Parallax
From: lewis lim [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lZbgewN--x15-1u6vMPT8uNWd1TMBeUz9gOWn88z8q2-wFXZUtY_U3ITYX-nK1YKIhWAqH-tKAvfNok]lewis0479@y...[/url
Sent: Tuesday, February 03, 2004 5:25 PM
To: Jon Williams
Subject: RE: [noparse][[/noparse]basicstamps] serial communication between BS2sx
and PIC16F877
thanks for your help.however, i had tried to interface the BS2sx
with the PIC16f877 using the I/O pins. i did receive some data from the
PIC but the data received is different from what the PIC sent. i oreli
use the same baud rate for both the BS2sx and PIC.
herewith, i enclosed my source code:
source code for BS2sx
' this program is just a simple communication between BS2sx and
PIC. the BS2sx will send a character "A" then receives character "B".
temp var byte
pause 1000
serout 0,1021,[noparse][[/noparse]"A"] '2400 baud rate
serin 1,1021,[noparse][[/noparse]temp]
END
PIC source code:
DEFINE osc 20
b var byte
serin2 portb.1,396,[noparse][[/noparse]b] '2400 baud rate
if b="A" then
high portA.1 'light an LED
endif
serout2 portb.2,396,[noparse][[/noparse]"B"]
END
any problem with this source code? if u had any idea, please
kindly suggest or include the source code as well.
lewis
Jon Williams <jwilliams@p...> wrote:
Since the core of the BS2sx is very PIC-like, there
should be no
and polarity of
-- Jon Williams
-- Dallas Office
From: lewis0479 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lZbgewN--x15-1u6vMPT8uNWd1TMBeUz9gOWn88z8q2-wFXZUtY_U3ITYX-nK1YKIhWAqH-tKAvfNok]lewis0479@y...[/url
BS2sx and PIC16F877
PICf877
using the
i/o pin?
data from the
knows the
solution?
from the same email address that you subscribed. Text in
the Subject and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
_____
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
<http://us.rd.yahoo.com/evt=21608/*http://webhosting.yahoo.com/ps/sb/>
_____
This message has been scanned by WebShield. Please report SPAM
to abuse@p....
