serial port on a homework board? — Parallax Forums
edited 2004-02-02 15:55 in General Discussion
Does anyone know if you can use the builtin serial/rs232 port on the
Homework board to accept/send serial data that is not in the IDE? If
so, could you point me to any examples? Thanx in advance.
    edited 2004-02-02 12:38
    Yes, it can. DEBUG and DEBUGIN are special versions of SEROUT and SERIN.
    The only caveat is that the port echoes everything sent to it, so you
    external application has to deal with that.
    -- Jon Williams
    -- Dallas Office
    From: neverenouph2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=117W6RY0M1hca6Mu1XmY_LbU3ehSbMaOA4KKfAwyq5VvpJyPztVacOrzNKMxZV95psWiGG_i1Lp_465eOVlK8sBnfA]neverenouph2002@y...[/url
    Sent: Sunday, February 01, 2004 8:41 PM
    Subject: [noparse][[/noparse]basicstamps] serial port on a homework board?
    In the 'files' area, see AlDemo\BS2_VBDemo.zip
    This is a simple but complete demo, including
    instructions, of how to interface the VB IDE
    with the BS2.
    Basically, if you do:
    MAIN:
    SEROUT 16, 16384, [noparse][[/noparse]"Hello!",13]
    goto MAIN
    The BS2 will send data out the built-in
    serial port.
    MyData VAR BYTE(10)
    SERIN 16, 16384, [noparse][[/noparse]MyData]
    ' The above will wait for 10 bytes, from
    ' the serial port (you can use Hyperterm) and
    ' put them in 'MyData'.
    ' And yes, anything you send to the BS2 from
    ' the PC will be 'echoed' by the BS2, so your
    ' PC side app needs to know this and toss the
    ' echo.
    --- In basicstamps@yahoogroups.com, "neverenouph2002"
    the
    If
