Train Station ID
I trying to come up with a method for a model train car to passively
identify the different stations along it’s track. The car will have a BS2 on
board. I am thinking about a crude barcode scanner on the train and labeling
the stations. Are there other methods that might be easier for the bs2?
There will be about 20 stations.
Jeff
Jeff
Perhaps IR led's, each transmitting a different code? Could be set in the
track, and the train have the receiver on the bottom.
Jonathan
www.madlabs.info
To: "Basicstamps" <basicstamps@yahoogroups.com>
Sent: Saturday, January 31, 2004 6:39 PM
Subject: [noparse][[/noparse]basicstamps] Train Station ID
> identify the different stations along it's track. The car will have a BS2
on
labeling
> Thanks,
> Jeff
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
Barcode readers are cheap enough.
Please tell us more about what you actually wish to accomplish.
Putting a BS2 in every car (and engine?) seems like a very expensive
undertaking, unless you only have a very few cars. Is the layout
under computer control? Are you using DCC?
Russ
--- In basicstamps@yahoogroups.com, "Jeff Mitchell" <JMitchell@G...>
a BS2 on
labeling
> Thanks,
> Jeff
Russ
Russ,
I am going to install a membrane keypad on a couple of train engines. The
trains will be directed to a certain station on the track by inputting the
station ID on the keypads. I am building the train engines and track myself.
This will be used for a one-off commercial display.
I think I may have the best solution that uses the least processor power...
I can count holes drilled in the track at each station with an optical
switch.
Jeff
>Thanks,
>Jeff
Jeff -
You might consider a series of LED's along side the track which a train could
read by using a photo-diode or other optical means. Use a leading LED to "prime"
the BS-2 scanner, then do a series of checks to see how many LEDs there are.
2^ 2 = 4 possibilities, 2^ 3 = 8 possibilities, 2^ 4 = 16 possibilities, and
2^ 5 gives you 32 possibilities for numbering the stations. One leading
"priming" LED plus 5 station identifiers gives you a total of 6 LEDS to
accommodate 20 stations (actually 32).
So long as the train isn't roaring by the station, I suspect that might be the
least expensive method. Place them far enough ahead of the actual station so the
train can slow down gracefully.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
>>identify the different stations along it's track. The car will have a BS2 on
>>Thanks,
>>Jeff
> For what it worth ,,,,
A few years ago at work , we used a " optical tachometer " .
That used some tape that was very reflective it appeared to use / have
glass beads in it .
the tape was applied to the shaft or pulley , under test and that
was all the tachometer would see . Maybe you can mark the cross
ties of the track
with reflective material then add a " IR " emitter and
sensor pair under the engine . I would think a simple " serial "
format might be readable .
>>Yahoo! Groups Links
>Yahoo! Groups Links
