error message code example
Archiver
hi guys, here is the code which produced the" end of line error". the
error appeared on line #2 after 'reset counter via MCR register, the
character CS=0, popped up as the problem. this is based on an example
posted about two weeks ago.
thanks, mark
'{$STAMP BS2}
'LS7166 TRYOUT 1/29/04
'REVISION HISTORY;
'VARIABLES
ENC_COUNT VAR Word 'WORD to hold encoder count ls bytes
ENC_COUNTHI VAR Byte 'BYTE to hold encount ms byte
'PIN ASSIGNMENTS
'Set initial STAMP2 I/O conditions
DIRS = $0F00 'I/O pins 0-7, 8-11 OUT
OUTC = $F 'LS7166 CD=1, WR=1, RD=1, CS=1(0 true)
'Setup LS7166 initial conditions
RESET:
DIRL = $FF 'LS7166 bus = output
'Set OCCR count control register
OUTL = $80 'count normal binary
OUTC = $C 'CD=1, RD=1, WR=0, CS=0
OUTC = $F 'CD=1, RD=1 WR=1 CS=1
'Set QR register
OUTL = $C3 'quadrature X4 mode
OUTC = $F 'CD=1, RD=1, WR=1, CS=1
'Set ICR input control register
OUTL = $48 'enable A & B inputs
'Reset counter via MCR register
OUTL = $04 'reset counter
'Main program loop
LOOP:
GOSUB READ_ENCODER
GOTO LOOP
'SUBROUTINES
'Reset address pointer and transfer count to OUTPUT LATCH
DIRL = $FF 'bus is output
OUTL = $3 'reset OL address pointer, transfer CNTR to OL
OUTC = $7 'CD=0, RD=1, WR=1, CS=1
'Read encoder
DIRL = $00 'bus is input
OUTC = $2 'CD=0, RD=0, WR=1, CS=0
'Read encoder
ENCODER_COUNT.LOWBYTE = INL 'Read ls byte of
encoder
OUTC = $6 'CD=0, RD=1, WR=1, CS=0
ENCODER_COUNT.HIGHBYTE = INL 'Read mid byte of encoder
ENCODER_COUNTHI = INL 'Read
high byte of encoder
RETURN
thanks, mark
'{$STAMP BS2}
'REVISION HISTORY;
'VARIABLES
'PIN ASSIGNMENTS
RESET:
'Set QR register
'Main program loop
LOOP:
GOSUB READ_ENCODER
GOTO LOOP
'SUBROUTINES
'Read encoder
'Read encoder
encoder
RETURN
>thanks, mark
Mark -
You have at least two undefined variables which I've noted below. They probably
should be referencing ENC_COUNT not ENCODER_COUNT .
Bruce Bates
>'{$STAMP BS2}
>'REVISION HISTORY;
>'VARIABLES
>'PIN ASSIGNMENTS
> RESET:
> 'Set QR register
>'Main program loop
> LOOP:
> GOSUB READ_ENCODER
> GOTO LOOP
>'SUBROUTINES
> 'Read encoder
> 'Read encoder
>ENCODER_COUNT.LOWBYTE = INL 'Read ls byte of **<=== UNDEFINED VARIABLE
>encoder
>ENCODER_COUNT.HIGHBYTE = INL 'Read mid byte of encoder **<=== UNDEFINED
VARIABLE
>RETURN
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
Your subroutine(s) also has (have) no label(s).
I modified your code by changing the undifined variable Bruce noticed
and I put in a label for the subroutine.
The result is shown below and it compiles without error, on my system.
Good luck,
Klaus
'{$STAMP BS2}
'REVISION HISTORY;
'VARIABLES
'PIN ASSIGNMENTS
RESET:
'Set QR register
'Main program loop
LOOP:
GOSUB READ_ENCODER
GOTO LOOP
'SUBROUTINES
READ_ENCODER:
'Read encoder
'Read encoder
ENC_COUNT.LOWBYTE = INL 'Read ls byte of
encoder
ENC_COUNT.HIGHBYTE = INL 'Read mid byte of encoder
ENC_COUNTHI = INL 'Read
'HIGH Byte of encoder
RETURN--- In basicstamps@yahoogroups.com, Bruce Bates <bvbates@u...>
wrote:
the
the
example
> >thanks, mark
> Mark -
They probably
> Regards,
> Bruce Bates
> >'{$STAMP BS2}
> >'REVISION HISTORY;
> >'VARIABLES
bytes
> >'PIN ASSIGNMENTS
> > RESET:
> > 'Set QR register
> >'Main program loop
> > LOOP:
> > GOSUB READ_ENCODER
> > GOTO LOOP
> >'SUBROUTINES
to OL
> > 'Read encoder
> > 'Read encoder
UNDEFINED VARIABLE
> >encoder
UNDEFINED VARIABLE
> >ENCODER_COUNTHI =
INL 'Read
> >RETURN
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
