tras help
Hello. I am trying to make a motor driver using spare parts from old car amps.
I found a schematic for a H-drive using two "TIP125" & "TIP120"
http://www.electronics-lab.com/projects/motor_light/009/index.html .
It will work great but I need more current. I found some "TIP35C" & "TIP36C"
http://www.onsemi.com/pub/Collateral/TIP35A-D.PDF
I want to know would I be able to replace smaller with bigger with little or no
modifications. or should I look for another route. I cant use relays. need speed
control.
control.
Take a look at this link. It just may have the answer you are
looking for. It is from Al Williams stamp project of the month. I
just stubled across his site a few days ago and have picked up some
good information off of it.
http://www.al-williams.com/som.htm
Lu Kwan
--- In basicstamps@yahoogroups.com, "Anthony Conti" <aconti@s...>
old car amps. I found a schematic for a H-drive using two "TIP125"
& "TIP120" http://www.electronics-
& "TIP36C" http://www.onsemi.com/pub/Collateral/TIP35A-D.PDF
little or no modifications. or should I look for another route. I
cant use relays. need speed control.
