Ps2 keyboard protocol, connected to BS2p
I know about the Pak6a buffer uP.
What protocol and synchronous baud rate is used from the keyboard?
Can I connect the BS2p directly to the keyboard, and read the scan
codes, if the keyboard is power by 5 volt, or is the keyboard
transmitting 12volt synchronous, thereby a 232 level converter is
needed?
Stein
needed?
Stein
clock. The rate is too fast -- as far as I know -- to handle with a Stamp.
You could probably do the raw read with a large shift register. Of course,
that doesn't let you send anything out. It also doesn't decode the raw scan
codes for you or any of the other things the PAK-VIa will do.
The problem is that the keyboard generates the clock so you either keep up
or you don't.
Hope that helps.
Al Williams
AWC
*NEW: Inexpensive Servo Control: the PicoPak VIII
http://www.awce.com/ppak8.htm
