Boe-Bot Add On Sensors
I've got my Boe-Bot, with the Bluetooth eb500 transceiver, running on remote
control, from a windows application on my computer. Now I would like to get
feedback from the Boe-Bot so that the computer can 'see' where the Boe-Bot is
going, and automatically control the Boe-Bot. (As you probably figured out, I've
been reading a lot of the press releases about the Mars Rover.)
My question is: what should I buy for an add-on to the Boe-Bot? On the Parallax
web site I see lots of possibilities ( Ultrasonic Range Finder, SSIR Detector,
Gazbot Infrared Detector, CMUcam, and TAOS Color Sensor). Where should I start?
Thanks for your help!
s.nelick@v... writes:
> Parallax web site I see lots of possibilities ( Ultrasonic Range Finder, SSIR
> Detector, Gazbot Infrared Detector, CMUcam, and TAOS Color Sensor). Where
should
> I start?
Look at the sensors for the Boe-Bot that are descrobed in the Robotics manual
that cme with the BoeBot. If you are going to feedback to the PC, then you
will have to serout the IR info. You can use the SRF04 sonic range finder - I
have one attached to my BoeBot. I also mounted a slave BS2 on an AppMod board
and plugged that into the Stamp BOE, so the slave could report back to the
master when sensing something.
Sid
>remote control, from a windows application on my computer. Now I would
>like to get feedback from the Boe-Bot so that the computer can 'see'
>where the Boe-Bot is going, and automatically control the Boe-Bot. (As
>you probably figured out, I've been reading a lot of the press releases
we've already done this using serial and the existing sensor on our
sumobot under linux. it's been a fun learning experience.
>SSIR Detector, Gazbot Infrared Detector, CMUcam, and TAOS Color Sensor).
My next project will include the Ultrasonic Range Finder. That seems like
fun.
Also the TAOS Color Sensor is good for navigation - i.e. your bot can
follow color coded lines.
If you really want to go wacky investigate GPS - I don't know if GPS is a
good idea - how accurate is it anyway - but the biggest problems with
sensors is making sense of the data you get back. And GPS is only
accurate at best to 1 meter - at worst 5.8. I suspect a bot for
navigation would need accurracy down to the foot for some needs.
have fun
joe
Thanks for the suggestion on the Parallax SRF04 Ultrasonic Range Finder!
I just printed out the pdf for the SRF04, and I'm going to study it now. I
see the SRF04 was back-ordered until 1/26, it must be a 'hot' item'.
Steve
__________
Sent: Sunday, January 25, 2004 5:52 PM
Subject: Re: [noparse][[/noparse]basicstamps] Boe-Bot Add On Sensors
> In a message dated 1/25/2004 5:37:15 PM Eastern Standard Time,
SSIR
Where should
> > I start?
manual
you
finder - I
board
> Sid
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
Did you get Bluetooth to work on Linux? How did you do that? I went to the
BlueZ Linux web site, and I tried to follow the instructions for installing
Bluetooth on Linux, but I didn't get it to work, so I went back to Windows.
Steve
______
Sent: Sunday, January 25, 2004 6:09 PM
> fun.
> have fun
> joe
> Yahoo! Groups Links
> Hello Joe,
Sorry - no it's a serial cable not bluetooth. sorry to give that
impression.
cheers
joe
> Steve
> ______
> From: "Joe Baptista" <baptista@d...>
> > fun.
> > have fun
> > joe
> > Yahoo! Groups Links
> Yahoo! Groups Links
