Approach warning for small boat cruisers — Parallax Forums
edited 2004-01-27 03:25 in General Discussion
    edited 2004-01-25 12:25
    Almost all modern radar units have a guard zone feature. This is a user setting
    that sets off an alarm if a radar target enters the preset zone area. The radar
    unit is programed to sleep for a preset time, wake up and transmit a few sweeps
    and if no targets are found, go back to standby until the next wake time. This
    "active" system is a good addition to the "passive" radar reflector up on the
    mast.
    Regards:
    Andy
    edited 2004-01-25 14:12
    I would not rely upon the larger ship watching out for you. There have
    been too many reports of tankers making their destination with sailboat
    rigging snared in their anchor.
    setting that sets off an alarm if a radar target enters the preset zone area.
    The radar unit is programed to sleep for a preset time, wake up and transmit a
    few sweeps and if no targets are found, go back to standby until the next wake
    time. This "active" system is a good addition to the "passive" radar reflector
    up on the mast.
    > Regards:
    > Andy
    > From: "
    edited 2004-01-26 00:29
    > is a user setting that sets off an alarm if a radar target enters
    Yes, but this is installed on the radar on the big ship. Very few
    single-hand cruisers carry radars.
    Gary
    edited 2004-01-26 01:00
    --- In basicstamps@yahoogroups.com, "Gary W. Sims" <simsgw@c...>
    wrote:
    > From: "
    edited 2004-01-26 10:39
    I'm not a mariner but I wondered if a radar detector
    might be a simpler thing to construct? I assume all
    the targets are likely to be running radar of at least
    one type, it's an issue of whether the watch is
    effective?
    Would a signal strength detector give enough
    discrimination for target distance. Could check for a
    rising trend in that.
    If 'big boats' use multiple radar wavelengths (I don't
    know why I think they do, but my memory of trips on
    RoRo is that the have lots of rotating antennae) using
    multiband reciver might give a vessel-type profile?
    Adrian
    ________________________________________________________________________
    Yahoo! Messenger - Communicate instantly..."Ping"
    your friends today! Download Messenger Now
    http://uk.messenger.yahoo.com/download/index.html
    > effective?
    Yes, I would say that's a good statement of the problem. It is much more
    likely that the radar will be operating than that someone will be paying
    attention.
    And we obviously know that signal strength at the target is going to be
    several orders of magnitude greater than it is at the antenna looking for
    the return, so if it might well be practical to build an inexpensive
    detector to show when you're being painted by someone's radar.
    A little research should tell us what frequencies are used for shipboard
    radars, and with luck it won't be the same as shore radars -- nor will it be
    too many different frequencies. I know in general that radar bands are P, L,
    S and so forth up through K or V or something, but I never had to pay
    attention to licensing issues on the ones I used, so I have no idea which
    bands are assigned to which civilian purposes. One of our hams will surely
    know.
    > Could check for a rising trend in that. [noparse][[/noparse]and]
    Quite possibly, especially if I can remember which bands are allocated to
    the US/UK navies. Watchkeeping is more disciplined on those vessels, but
    personally I'd still rather be alerted if a tin can is nearby. I can picture
    a detector that we tune to different bands if that is reasonably cheap to
    build, or possibly a set of detectors for the likely frequency bands. Then
    the Stamp aggregates the positive responses it receives in a given time
    interval and displays either the raw profile, or possibly a "likely source"
    indication.
    Gary
    Whose cruising is limited to the dining room and the
    Internet these days, but I still empathize with Stein
