IR Temperature Sensors? ?
I have been racking my brain.. I am trying to build a non contact
temperature screening device. IR is the 1st thought, but with IR
sensors the width of the temp area changes with the distance from the
surface. Thats the killer.. the surface is uneven. So I am trying to
precisely measure the temp in several areas on an uneven surface at
the same time (or near same time). Is IR the answer, is there an IR
temp sensor that has a fixed width. Should I look at a different
sensor? Can you measure Temp with Fiber or laser?
RT
RT
interface (needs a BS2p or BS2pe for 1-Wire). This kit comes with K, J,
and T thermocouple elements.
-- Jon Williams
-- Parallax
From: rltaylor001 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3Jab63Prxmi7xcHXzdWdO2YLboAlBNU9T9vYuZedfekEuD1l6kx5k2OWNhMkvqQD0n5eci3UiaPCfqWSOQ]rltaylor001@h...[/url
Sent: Friday, January 23, 2004 1:50 PM
Subject: [noparse][[/noparse]basicstamps] IR Temperature Sensors? ?
RT
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
to "attach" to the surface. Spacing, adhesion, power source.. etc.
Essentially I am building a temperature matrix or mesh that transmits
temps to a datalogger in near real time. So if I put may hand under
the IR mesh, I would get temp values from maybe 50 "spots' on my
hand..
If I could measure Temp changes with fiber I could build a glove
RT
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Does it have to be non-contact? You could use our new thermocouple
K, J,
> -- Jon Williams
> -- Parallax
> From: rltaylor001 [noparse][[/noparse]mailto:rltaylor001@h...]
the
to
> Thanks
> RT
Subject
> Yahoo! Groups Links
> abuse@p...
couple of mirrors (off of steppers?).
You could then just fire the IR beam into the first mirror and have the
stamp 'advance' the motor across a series of points that would then be read
back.
Question then is how to get the data out of one of these IR temp guns....a
bit of reverse engineering...??
sb
From: rltaylor001 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x40CrnCNzu0wDqFZwPAMKF5h3hEaVKmttXIIsHfMNooQe2O1-RJ0K29q_bBYtDJSrgUsVZfGWuAfQIPG9Yss6g]rltaylor001@h...[/url
Sent: Friday, January 23, 2004 3:09 PM
Subject: [noparse][[/noparse]basicstamps] Re: IR Temperature Sensors? ?
Pretty much, I run into a whole new set of issues when trying
hand..
RT
K, J,
> -- Jon Williams
> -- Parallax
the
to
> Thanks
> RT
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
