RF module alternatives
Archiver
Pinging the group to see if anyone knows of an RF module that can
communicate with a ucontroller much like the Surelink device, but is
a smaller form factor? I am developing a small electronic device
and have very little room for electronic components.
A response from anyone would be much appreciated.
Patrick
Patrick
would love to help you. Just be patient.
Patrick
--- In basicstamps@yahoogroups.com, "rodroddy_778"
is
> Patrick
dont know what kind of RF module youre looking for, but sure you have space
constrains.
Im using Chipcon's CC1020 with great success. Its a wee RF chip, with all
the RF electronics inbuilt. And its very very small.
Check www.chipcon.com
You may also check www.nvlsi.com and www.rfm.com.
Antonio Sergio Sena
Sent: Saturday, January 24, 2004 10:55 PM
Subject: [noparse][[/noparse]basicstamps] Re: RF module alternatives
> Gee Patrick, what a great question. I'm sure someone in the group
> Patrick
> is
> > Patrick
Ant
Antonio:
I was wondering why kind of application are you using the chip in?
Also did you design your own board for the rf chip? I'm intersted in
using the same chip and was curious about your experiences.
Kevin
--- In basicstamps@yahoogroups.com, "Antonio Sergio Sena" <asena@p...>
wrote:
> Hello Patrick,
have space
> constrains.
with all
> Antonio Sergio Sena
> From: "rodroddy_778" <rodroddy_778@y...>
> > Patrick
can
but
> > is
device
> > > Patrick
> Ant
i am using them to embbed on another small board, that will perform
telemetry of any kind of system you connect it to.
I did my own board design, dual side, pth.
The main points on using this chip:
- since it hasnt any pins, you need a FlipChipBonder machine, to position
the chips. Theyre so small... that its very difficult to do it right, if you
dont use the machine. But still, it has to be done on a good PCB, good flux
and good solder. Even though, doing it at hand with a machine, is tricky. I
know that being done in a factory, the problems disapear.
- just an almost empty hand of passive components go around it. The PLL bias
resistor should be 0.1pct.
- extremely easy to work with SPI to configure it, and the DATA IO is done
by two serial pins.
If you like it, you may purchase an application board from Chipcon. They
have it ready to use. But is big, and only for lab work.
We are planning here to design and assemble a board the size of 1/4 credit
card, with the CC1020 chip, all passives and RF antenna connector, and of
course the connector for the uC. So, anyone that wants to work with it,
doesnt need to be stuck with the only Chipcon's solution.
Above all, if you go through the specifications, youll see that the internal
codecs for data and modulation, are extremely useful for the designer. And
+10dBm output !!
Open to more questions, feel free.
Antonio Sergio Sena
Sent: Monday, January 26, 2004 4:59 AM
Antonio:
Kevin
wrote:
> Hello Patrick,
have space
> constrains.
with all
> Antonio Sergio Sena
Ant
> an RF module that can communicate with a ucontroller
Have a look at http://www.linxtechnologies.com/
I've heard good things about their products. I just bought one of
their RXM-418-LC-S receiver chip and a TXM-418-LC transmitter chip
from Digikey.
They look very easy to use. Just download the data sheets and have a
look.
I have not done anything with the parts yet, but soon...
I have used the LINX modules you mentioned a bunch. While I have got them to
work very well with a PIC, I have only had so-so results with a Stamp. I get
about 1/2 the range. I spent a lot of time trying to track it down, but to
no avail. Please let me know your results, I like the Linx stuff and want to
get it to work properly with a Stamp.
Jonathan
www.madlabs.info
Sent: Monday, January 26, 2004 9:10 PM
> from Digikey.
> look.
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
Thanks for the info. I was wondering if Chipcon has a distributor or
where do you get your CC1020 chips from? I think that the $60 for 5
chips sample is pretty expensive.
wrote:
> Hello Kevin
position
right, if you
good flux
tricky. I
PLL bias
is done
> by two serial pins.
They
credit
and of
it,
internal
designer. And
> +10dBm output !!
> Antonio Sergio Sena
> From: "kevikevtmc" <kevikevtmc@y...>
> Hi,
> Antonio:
> Thanks,
> Kevin
> wrote:
> > Hello Patrick,
> have space
> > constrains.
> with all
> > Antonio Sergio Sena
> Ant
Yes they have distributers, and depend of where you are in the world!
The first time i bought them, i payed that for the 5 samples.
But when buying in quantity, you get a very good deal.
Check their web for distributors.
I bought mines from the Portuguese (terrible) distributer.
Antonio Sergio Sena
> Sent: Tuesday, January 27, 2004 7:08 PM
> Hi,
> wrote:
> > Hello Kevin
> position
> right, if you
> good flux
> tricky. I
> PLL bias
> is done
> > by two serial pins.
> They
> credit
> and of
> it,
> internal
> designer. And
> > +10dBm output !!
> > Antonio Sergio Sena
hathaway@d... writes:
from Digikey.
look.
Take a look at Reynolds Electronics (www.rentron.com). They sell these Linix
modules assembled with antennas. I have used lots of them with very good
success with my Stamps.
