adc with sharp gp2d120 output
I wasn't very clear at all regarding my intentions with the
range-finder. It has an analog output between 2.2V and 5.5V (I think.)
I'd be perfectly happy using it as a boolean if I could trigger a
response at a given voltage between those values.
Can something be rigged together using rctime? I was looking at
http://www.emesystems.com/BS2rct.htm
and thought this was promising for a solution not requiring another
chip purchase. Specifically, the section "Measuring small voltages
with RCtime" looks good but I'm still wading through the unfamiliar
terminology (I'm a genetics/biostats person in real-life, always shied
away from electronics, maybe to spite myself?) and am unable to tell
if it is not possible a dead-end for my needs.
p.s. I found a link to that site plowing my way through Yahoo's
mediocre archive to this very informative group. Y'all are a fun read.
pins on the STAMP need the voltage to be around 1 volt before it reads a
high (I think). Because of this, RC will only work within a limited
rage. When I tried it, I could only get a reading within 3 to 4 inches,
which is not totally useless. You'd do better using a GP2D02, which has
a digital output and is only a little more expensive, or a GP2D15 which
has a on/off output if there is an object in it's range.
chris in napa
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
I'm commited to the gp2d12 (in that I've already bought them) and I
think in the long run I can get more out of them. I looked at some
adc's, TI has the tlv1549C which allows you to set the range using
ref+/ref- inputs. It appears to be what I'm looking for.
I have no idea if it works, though.
Yours,
CM
--- In basicstamps@yahoogroups.com, Chris Burns <mwalimu@s...> wrote:
> The Sharp familly of IR rangers returns a signal of .5 to 3v. The I/O
reads a
inches,
has
> chris in napa
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
