Dallas Semi 1302 timekeeper-alternative?
Archiver
I saw a reference somewhere that said the DS1302 is now obsolete.
Can anyone recommend a direct replacement from DS-Maxim that has the
same 3-wire interface but includes the crystal and has the onboard
battery backup?
thanks, Steve Hinote
battery backup?
Digital Thermometer (not the DS1302 timekeeper).
But I'd still like to hear if someone found an upgrade to the DS1302.
thanks
the
> battery backup?
however it still requires an external 32KHz cystal and battery backup.
search Digikey for the part and datasheet.
At 07:27 PM 1/20/2004, you wrote:
>woops. turns out the obsolete reference was to the 1-wire DS1820
>thanks
>the
> > battery backup?
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
3-wire interface, 4096 bits (512 bytes) of NVRAM, as well as timekeeper
functions(including an alarm interrupt). I think Digikey has these.
Also, if you can do 1-wire (BASIC STAMP 2p), there is the Dallas1994,
which is essentially a 2404 in a 1-wire can (these are my favourites),
the only way I've been able to get these is to order samples from
Maxim/Dallas. JDR used to have them, but not any more. Be careful with
the startup sequence. If you do it wrong you can lock up the chip and
render it useless...read the data sheet CAREFULLY!
chris in napa
>battery backup?
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
with the 1302, it's working OK. now I like the idea of using the
DS32KHZ temp compensated oscillator with the 1302, and a supercap.
My only problem is I haven't yet found a reference about what cap
value to use, or for that matter what a supercap is.
can anyone shed some light on "what supercap should be used to
backup the DS1302 RTC"
steve hinote
--- In basicstamps@yahoogroups.com, Chris Burns <mwalimu@s...> wrote:
> I like the dallas 2404 econoRAM timekeeper chip. It has a 1-wire
or a
timekeeper
these.
Dallas1994,
favourites),
careful with
and
> chris in napa
obsolete.
the
onboard
> >battery backup?
Subject and Body of the message will be ignored.
> >Yahoo! Groups Links
A "supercap" refers to a fairly recent development in the process technology
used to produce capacitors. (Well, fairly recent to an old fogy anyway.) It
makes it practical to build capacitors with values in the whole farad range.
Traditional caps have run from picofarads to microfarads. (That's billionths
of a farad to the millionth of a farad range.) One farad is an enormous
capacitance by comparison, and makes it practical to store as much energy as
small batteries do.
You can find these under names like "Supercap", "Capattery" and probably
others that I haven't noticed. Here's one at Mouser with roughly a half
farad capacitance for two bucks: http://makeashorterlink.com/?B3A313527
and another at Digikey with a whole farad for less than four dollars:
http://makeashorterlink.com/?P2C312527
Both of those are 5V because I assume that's about what you need. I don't
feel like doing the arithmetic, but I'd guess a one farad cap would back up
the DS1302 for half an eternity or so. Give or take an eon.
Gary
