Need Pbasic for Dummies! Help
T.O.-
Can you state your requirements in terms of a truth table? I'm
getting lost in the description. Sounds like the truth table may
need to include former switch settings, current switch settings,
current output states, desired new output states. Also, are the
inputs sampled and the outputs updated continuously, or at specific
intervals?
Cheer up, sounds like something the Stamp can do with just a few
lines of code.
Steve
intervals?
lines of code.
Steve
For the life of me I can't seem to get the hang of writing a program
for the stamp! At first it appeared as though it would be simple to
control two relays with three switches right ! ( have very few hairs
left to pullout ). Was easier to build a logic circuit with a couple
of JK flip-flops, and a few AND gates yet would like to see just
what a stamp can do to save parts and a lot of wiring. 20 plus years
ago enjoyed playing around with the old basic on a VIC 20 now trying
to relearn all this Greek or Latin ( Pbasic ) What I would like to do
is simply toggle the state of two outputs depending on, the on or off
state of the same 2 outputs and 3 inputs ( switches ), with the
following rules.
Must start with outputs =0
Output X and Y can never be toggled on at the same time
Output X can never go on if switch 1 is already on, but can toggle
X on if first was off
Same applies to to output Y and switch 2
Switch 3 toggles off X or Y first if X or Y =on
or allow X on only if switch 3 is on
or allow Y on only if switch 1 is on
Can anyone help?
P.S.
Will purchase the first Pbasic ( Greek ) for Dummies!
Looking for software that will convert a logic circuit to stamp
program ( Un-Greek-tified ) or similar.
Thanks T.O.
First OUTPUT X AND Y = 0
At startup if switch1 is on and switch2 is on then Output X and Output Y
cannot be turned on from switch1 and switch2 because there aready on
therefore switch3 would turn on Output X because it initialized in the
output x = 0 state but if switch1 is on at the same time switch3 is on that
would indicate output X and output Y to be on at the same time
basically stating that
Output x = 0
Output y = 0
if switch1 = 1 and switch2 = 1 and switch3 = 1 then
How is this statement true if they cannot be on at the same time?
At 07:57 PM 1/20/2004 +0000, you wrote:
>Going bald
>following rules.
>Can anyone help?
> P.S.
>Thanks T.O.
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
"Why am i fighting to live, if im just living to fight"
"Why am i trying to see, when there aint nothing in sight"
"Why am i trying to give when no one gives me a try"
"Why am i dying to live if im just living to die"
hairs I had on top are now gone and I'm still unable program my stamp
II to work the way I'd like and replace my logic circuit.
The present logic circuit I've created controls a 3 level elevator.
The top and bottom levels each have two switches with two additional
switch in the elevator wired in series ( see below ) with first and
third level input. All are normally closed type switches. The center
floor has 2 switches wired in series connected to a third input. The
two outputs control a pair of opt-triac that provide up down action.
On start-up one of any single (b.) switch will normally be open
depending on location of elevator. Both outputs must be off on power
up. F3(b.) and F1(b.) prohibits elevator from going beyond that
level. Please not, the (a) switches toggle its correspond outputs on
as long as both outputs are off , and what other (b) switch is open
determines what direction (output to turn on ). Once elevator is in
motion the (b.) switch it was stopped on automatically closes before
the next floor allowing the (b) switch to open and toggles elevator
to stop if output is on. Please note, based on what floor elevator is
on, Y input is the only input that can allow one or the other outputs
to go on but never at the same time.
My logic circuit allows the following:
U=0 and D=0 ` when first turned on
If X input =1 and Y =1 and elevator is stopped outputs =0, elevator
is at Z (Z=0), with input Z open, X or Y must not allow Doutput on
ever.
If X input =1 and Y=0 and Z=1, elevator is at Y (level 2). Note
with Y input open X(a) or Z(a) can still page elevator when one or
the other opens then closes starting elevator in that direction. When
that input again opens, elevator stops on that floor.
Paging Elevator
with input Y open, X (a) or Z (a)inputs when one or the other is
toggled allow elevator back on, X input toggled for Up, Z input
toggled for Down. When elevator reaches the corresponding (b) switch
opens turning output off.
No output can ever be on at same time.
Also note once elevator is toggled in the correct direction and in
motion that level it was on closes leaving all inputs closed until
the next input is opened at the level it reaches.
. Elevator All Switches Normally closed
. Up
.5v
.____.
>f3 in series with F3
. Down
.5v
.____.
>f1 ( in series with F1
. Floor 3
. Toggles elev. up Stop
. ( a.) ( b. )
. (F3)>----.___.
.___.
> input X
. Floor 2 If X=0 Toggles down
. If Z=0 toggles up stop
. (a.) ( b. )
. 5v >----.___.
.___.
> input Y
. Floor 1
. Toggle down Stop
. ( a.) ( b. )
. (F1) >----.___.
.___.
> input Z
I hope this isn't to confusing, any help would be gratefully
appreciated. Terry O.
--- In basicstamps@yahoogroups.com, "tloleksy" <tloleksy@y...> wrote:
> Going bald
program
hairs
couple
years
trying
do
off
> following rules.
toggle
> Can anyone help?
> P.S.
> Thanks T.O.
At 12:36 AM 1/27/2004 +0000, you wrote:
>I apologize for not providing enough info the first time, the few
>ever.
>Paging Elevator
>. Up
>.5v
.____.
>. Down
>.5v
.____.
>. Floor 3
>. ( a.) ( b. )
>. (F3)>----.___.
.___.
> input X
>. (a.) ( b. )
>. 5v >----.___.
.___.
> input Y
>. Floor 1
>. Toggle down Stop
>. ( a.) ( b. )
>. (F1) >----.___.
.___.
> input Z
> > Going bald
>program
>hairs
>couple
>years
>trying
>do
>off
> > following rules.
>toggle
> > Can anyone help?
> > P.S.
> > Thanks T.O.
when i was programming the Allen Bradley PLC at ITT Tech. it was fun if you
ever played with one of those (Ladder Logic). However Things have changed
since the STAMP. its no longer necessary to have switches in series
anymore. your a logic thinker and if you think you have no hair now just
wait until you read the program. first of all the BS2 has 16 I/O lines and
we should utilize this! the elevator system i designed has 9 inputs and 2
outputs. read the program and notes in the program for details. hope its
PBasic Legible !! email if you need assistance. and to those you are
experts in Pbasic you probably know of a way to shrink my variables but
this is how i understand the program. Thanks and good luck
Gary Denison
Kyocera Wireless Corp.
PROGRAM
'{$STAMP BS2}
'IN0 = Floor 1 Sensor
'IN1 = floor 2 sensor
'IN2 = Floor 3 sensor
'IN3 = Floor 1 Call Button 'Table so you dont get a headache !!!!
'IN4 = Floor 2 Call Button
'IN5 = Floor 3 Call Button
'IN6 = Elevator Floor Select (Floor 1)
'IN7 = Elevator Floor Select (Floor 2)
'IN8 = Elevator Floor Select (Floor 3)
'IN9 = down Output control
'IN10 = up Output control
'Basically this program is designed to work like an elevator system. the
elevator will start at
'floor 1 by default on power up. In This System There are a total of 9
inputs and 2 outputs.
'There is a call button on each floor (3). inside the elevator there are
three inputs to select
'the floor you want. Note: you cannot select the floor your already on. and
there are 3 sensors
'to indicate what floor the elevator is positioned at. the call BUTTON only
calls the elevator,
'once you get in the elevator you can select any floor you want. Example,
if your on floor 3 and
'press the call button, you get in the elevator and press floor 1 button
you will go to floor 1,
'FURTHERMORE, If someone on floor 2 presses the call button while the
elevator is going down and
'the elevator has NOT passed the floor 2 sensor it will stop on floor 2 for
5 sec and continue
'until floor 1 sensor goes LOW(0)
'All Switches are Normally high, see the
'command BUTTON in the help menu for wiring.
'Caution !! the program below uses EXTENSIVE
' INPUT and OUPUT commands
' refer To the table above before you GET A HEADACHE
Initialize
LOW 10
HIGH 9
loop1 ' Gets elevator to floor 1
start point
IF IN0 = 1 THEN loop1
LOW 9
get_position
IF IN0 = 0 THEN floor_1
IF IN1 = 0 THEN floor_2
IF IN2 = 0 THEN floor_3
GOTO get_position
floor_1
IF IN4 = 0 OR IN7 = 0 THEN upfloor2
IF IN5 = 0 OR IN8 = 0 THEN upfloor3
GOTO floor_1
floor_2
IF IN3 = 0 OR IN6 = 0 THEN dwnfloor1
GOTO floor_2
floor_3
IF IN4 = 0 OR IN7 = 0 THEN dwnfloor2
GOTO floor_3
dwnfloor1
LOW 10
HIGH 9
loop2
IF IN4 = 0 THEN interupt2
IF IN0 = 1 THEN loop2
LOW 9
GOTO get_position
dwnfloor2
LOW 10
HIGH 9
loop3
IF IN1 = 0 THEN loop3
LOW 9
GOTO get_position
upfloor3
LOW 9
HIGH 10
loop4
IF IN4 = 0 THEN interupt1
IF IN2 = 1 THEN loop4
LOW 10
GOTO get_position
upfloor2
LOW 9
HIGH 10
loop5
IF IN1 = 1 THEN loop5
LOW 10
GOTO get_position
Interupt1
IF in2 = 0 THEN upfloor3
IF IN1 = 1 THEN interupt1 'this will stop on floor 2
LOW 9 'on its way up to floor 3
LOW 10
PAUSE 5000
GOTO upfloor3
interupt2
IF = 0 THEN dwnfloor1
IF IN1 = 1 THEN interupt2 'this will stop on floor 2 on its
LOW 9 'way down to floor 1
LOW 10
PAUSE 5000
GOTO dwnfloor1
End Of Program
> ever.
> Paging Elevator
> . Up
> .5v
.____.
> . Down
> .5v
.____.
> . Floor 3
> . ( a.) ( b. )
> . (F3)>----.___.
.___.
> input X
> . (a.) ( b. )
> . 5v >----.___.
.___.
> input Y
> . Floor 1
> . Toggle down Stop
> . ( a.) ( b. )
> . (F1) >----.___.
.___.
> input Z
> > Going bald
> program
> hairs
> couple
> years
> trying
> do
> off
> > following rules.
> toggle
> > Can anyone help?
> > P.S.
> > Thanks T.O.
This will be a big help to me now trying to learn this pbasic
language. To save chips and wiring with my first logic circuit, my
goal, became a challenge to cut down on switches and wiring. ( 28 IC
chips with 9 inputs 2 outputs). My present logic circuit consists of
a total of only 5 IC with only 3 inputs 2 outputs needed. I still
hope someday to incorporate a smaller circuit with the least amount
switches and wiring. Any additional input as always will be greatly
appreciated .
Terry O.
--- In basicstamps@yahoogroups.com, Gary Denison <gdii@c...> wrote:
> Hey Terry, Hows it going. I designed one these elevator systems way
back when i was programming the Allen Bradley PLC at ITT Tech. it was
fun if you ever played with one of those (Ladder Logic). However
Things have changed since the STAMP. its no longer necessary to have
switches in series anymore. your a logic thinker and if you think you
have no hair now just wait until you read the program. first of all
the BS2 has 16 I/O lines and we should utilize this! the elevator
system i designed has 9 inputs and 2 outputs. read the program and
notes in the program for details. hope its PBasic Legible !! email if
you need assistance. and to those you are experts in Pbasic you
probably know of a way to shrink my variables but this is how i
> Gary Denison
PROGRAM
> '{$STAMP BS2}
system. the elevator will start at
of 9 inputs and 2 outputs.
there are three inputs to select
on. and there are 3 sensors
BUTTON only
> calls the elevator,
Example,
button you will go to floor 1,
the elevator is going down and
floor 2 for 5 sec and continue
HEADACHE
> Initialize
> LOW 10
> HIGH 9
> start point
> LOW 9
> get_position
> GOTO get_position
> floor_1
> GOTO floor_1
> floor_2
> GOTO floor_2
> floor_3
> GOTO floor_3
> dwnfloor1
> LOW 10
> HIGH 9
> loop2
> LOW 9
> GOTO get_position
> dwnfloor2
> LOW 10
> HIGH 9
> loop3
> LOW 9
> GOTO get_position
> upfloor3
> LOW 9
> HIGH 10
> loop4
> LOW 10
> GOTO get_position
> upfloor2
> LOW 9
> HIGH 10
> loop5
> LOW 10
> GOTO get_position
> Interupt1
> LOW 10
> PAUSE 5000
> GOTO upfloor3
> interupt2
> LOW 10
> PAUSE 5000
> GOTO dwnfloor1
End Of Program
stamp
elevator.
additional
and
center
The
action.
power
outputs on
open
in
before
elevator
elevator is
outputs
elevator
on
> > ever.
When
> > Paging Elevator
is
switch
and in
until
> > . Up
> > .5v
.____.
> > . Down
> > .5v
.____.
> > . Floor 3
> > . ( a.) ( b. )
> > . (F3)>----.___.
.___.
> input X
> > . (a.) ( b. )
> > . 5v >----.___.
.___.
> input Y
> > . Floor 1
> > . Toggle down Stop
> > . ( a.) ( b. )
> > . (F1) >----.___.
.___.
> input Z
wrote:
> > > Going bald
> > program
simple to
> > hairs
> > couple
just
> > years
> > trying
like to
> > do
> > off
> > > following rules.
> > toggle
> > > Can anyone help?
> > > P.S.
> > > Thanks T.O.
