LightMeter.bs2
I'm new to these forums, this wonderful technology and a recent
purchaser of the HomeWork board. In the text, "What's a
Microcontroller?", chapter 7, pg 207, refers to code that is supposed
to turn on the segments, (A-F) of a display one at a time at the
speed set for the amount of light at the photocell.
When I run the program, the individual segments come on only once;
segA, then just segB, etc., until segF. They then remain off but the
program is still running because if a place a "DEBUG ? index" into
the Update_Display subroutine, the index cycles between 0 and 6,
repeatedly. The strange thing is: the seven segment display does
what its supposed to do, but only if a DEBUG statement is within the
code.
Please HELP as I JUST DON'T UNDERSTAND WHAT THE PROBLEM IS??
Jon
code.
Jon
believe it or not -- is your serial port. It is shutting off and
resetting the Stamp (we've seen this before). DEBUG keeps the port open
and active so the PC doesn't shut it down. You can usually fix the
problem by setting the port FIFO buffers to there minimum values.
-- Jon Williams
-- Dallas Office
From: jdahpuser2004 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uEo8w6mPQwzYahEhbxktuqWwVls-sT5xYbr3joHgecQw9OwDyMvCIoPMqNGWgZTlp9twqoKituPPE9-TIrI]jda.hpuser@v...[/url
Sent: Sunday, January 18, 2004 3:17 PM
Subject: [noparse][[/noparse]basicstamps] LightMeter.bs2
code.
Jon
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I am thinking that I could use a USB to SerialPort adapter, (as I use
a FaxModem), will I run into the same problems with USB?
Jon
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You're using a laptop computer, aren't you? If yes, the problem --
open
> -- Jon Williams
> -- Dallas Office
> From: jdahpuser2004 [noparse][[/noparse]mailto:jda.hpuser@v...]
> Hi,
supposed
the
the
> code.
> Jon
Subject
> Yahoo! Groups Links
> abuse@p...
not all are create equal (as we are so painfully coming to learn). The
Bafo unit we sell (or you can pick up locally) works well.
-- Jon Williams
-- Dallas Office
From: jdahpuser2004 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Xq9QhZQzHWWgnQdbbr3flbOYtL-HrfWsfVPZFHKvOc-d-KfUb7F6bOXz7pwPTF6nibkaY0AlymPnuETtuQ]jda.hpuser@v...[/url
Sent: Monday, January 19, 2004 1:16 PM
Subject: [noparse][[/noparse]basicstamps] Re: LightMeter.bs2
YES I am!
Jon
open
> -- Jon Williams
> -- Dallas Office
> Hi,
supposed
the
the
> code.
> Jon
intended only for PDA's, then it should
work. The problem with USB adapters is they
need to support the RS232 'handshake' signals
to properly program the BS2.
The 'BAFO' unit sold by Parallax works well,
as do the KeySpan. I've had problems with
older (2002) Belkin adapters, so be warned.
Give it a try, and see what happens if you
already have one on hand.
--- In basicstamps@yahoogroups.com, "jdahpuser2004" <jda.hpuser@v...>
wrote:
> YES I am!
use
> Jon
port
> open
the
> > -- Jon Williams
> > -- Dallas Office
> > Hi,
> supposed
once;
> the
into
> the
> > code.
> > Jon
> Subject
> > Yahoo! Groups Links
> > abuse@p...
