A/D question — Parallax Forums
A/D question
edited 2004-01-19 19:15 in General Discussion
Hello, everyone! I just joined the BASIC Stamp Group!
I have become very interested in the BASIC Stamp concept. By taining
I am an Electrical Engineer, by 40+ years of experience a Software
Engineer.
I have a project in the planning stage that will require Analog to
Digital conversion. The MAX1270 seems to offer the ideal chip for my
needs.
I have to measure 4 DC current sources which will use 100 millivolt
shunts in the negative (to system ground) line. One of these will be
bi-polar. My question is: What is the best way to amplify the 100 mv
max voltage so that it will be in range for the MAX1270? I presume
that I need to use an op-amp, but it has been a looong time since I've
done this sort of thing (retired now).
Any suggestions/pointers will be welcome!
Oh, and a belated Happy New Year!
Russ Ranshaw
    edited 2004-01-17 19:14
    Hi
    Well if you instead use the MAX186 it can measure voltages with 1mV
    precision between 0-4.096V. Should work for you. But if you ever need
    to go beyond that you'll have to use voltage dividers or the MAX1270
    which has higher ranges (at the expense of resolution) of course.
    -Dave
    --- In basicstamps@yahoogroups.com, "russranshaw" <russranshaw@y...>
    taining
    > Engineer.
    my
    > needs.
    be
    mv
    I've
    > Russ Ranshaw
    edited 2004-01-18 14:48
    Russ,
    I like the TLC2543, for the simple reason it can be set to read directly in
    mV, with 1 mV resolution. Max does make chips with 1mV resolution, but I
    don't know the part # off hand.
    If all of your signals are around 100mV, you could use an external vRef of
    100mV or a little above whatever you max input would be. If you need
    resolution of more than 1mV, you will need an op-amp.
    Jonathan
    www.madlabs.info
    Sent: Saturday, January 17, 2004 7:44 AM
    Subject: [noparse][[/noparse]basicstamps] A/D question
    > Engineer.
    > needs.
    > Russ Ranshaw
    > Yahoo! Groups Links
    > To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    > To unsubscribe from this group, send an email to:
    > Your use of Yahoo! Groups is subject to:
    edited 2004-01-18 16:21
    taining
    > Engineer.
    my
    > needs.
    be
    mv
    I've
    > Russ Ranshaw
    Hi Russ,
    One of the questions that comes to mind is the upper and lower end of
    the range you need.
    Do you need rail to rail or can you use 12V as your power supply ?
    Two thoughts here. One is that if you are not going near zero, you
    can use a cheaper op-amp that drops out, and if you use 12V power,
    you can use an op-amp that that drops out near the upper rail, but
    will be fine at 5 volts.
    Jon mentioned the 11 channel TI chip that has serial comm to the
    Stamp. There is a lot of information on this list and the Parallax
    website for this so it is pretty easy to use to get started.
    That said, if you use a quad op-amp in an instrument connection, you
    can eliminate a lot of the variations due to board temperature on the
    signal out of the ap-amp. And the TI chip has internal temperature
    monitoring so you can also calculate out for temperature there.
    And lastly monitor board voltage. Sid (NewZed) and I had worked on
    a project and he realized that all the readings were off ever so
    slightly and in his pursuit for excellence, found that board voltage
    was off and then figured that by monitoring board voltage and
    correcting for that, the readings lined up perfectly.
    Also, IIRC Keithly Metrabyte has a book on low voltage signals. Very
    interesting read. I didn't find it on therei website so it might
    require a phone call.
    Dave
    Jonathan,
    Thanks for your rely. Where can I find information/buy the TLC2543?
    In addition to the four DC currents, there will be three or four DC
    voltages in 0-10v range.
    Russ
    --- In basicstamps@yahoogroups.com, "Jonathan Peakall" <jpeakall@p...>
    wrote:
    > Russ,
    directly in
    vRef of
    > Jonathan
    > www.madlabs.info
    > From: "russranshaw" <russranshaw@y...>
    > > Engineer.
    > > needs.
    > > Russ Ranshaw
    Subject and
    > > Yahoo! Groups Links
    edited 2004-01-18 17:46
    Russ,
    The TLC sample code is on the Parallax website, and if you do a google
    search for "TLC2543" you will find the component spec. sheet in PDF format.
    The TLC2543 has a max input of 6.5V. So, to measure higher voltages, you
    will need to either use a different chip, or use a voltage divider. A
    voltage divider will of course clip your range/resolution.
    One way to approach it might be to use an external vRef for the 100mV
    inputs, then switch over to internal vRef to measure the 10V inputs with a
    volatge divider. The vRef can be set through software on the TLC2543. Note
    that you MUST make sure that the divided voltage is less than the vRef.
    Otherwise, a CMOS lockup can occur that will burn up the chip. And if you
    happen to be running it off the Stamp's VDD, you will burn it out too. Don't
    ask how I know this to be true ;-P. Ouch! I would also reccomend putting a
    10-100k resistor in series with the divided voltage input. This will limit
    current should such a lockup occur.
    What resolution do you need on the 10V inputs?
    Jonathan
    www.madlabs.info
    Sent: Sunday, January 18, 2004 8:21 AM
    Subject: [noparse][[/noparse]basicstamps] Re: A/D question
    > Jonathan,
    > Russ
    > wrote:
    > > Russ,
    > directly in
    > vRef of
    > > Jonathan
    > > www.madlabs.info
    > > > Engineer.
    > > > needs.
    > > > Russ Ranshaw
    > Subject and
    > > > Yahoo! Groups Links
    > Yahoo! Groups Links
    edited 2004-01-18 22:39
    > taining
    > > Engineer.
    > my
    > > needs.
    > be
    > mv
    > I've
    > > Russ Ranshaw
    > Hi Russ,
    > the range you need.
    > Dave
    Who would I call to find out about Keithly's book? Do you know it's
    exact title?
    Russ
    edited 2004-01-19 07:17
    You could use a PGA (programmable gain amplifier) of which you can control
    the gain by software to get an optimal voltage for readout, so you can use
    the full resolution of your adc.
    Oorspronkelijk bericht
    Van: russranshaw [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=I_dWOgncyWb9fzxeuasFGcrhRTToKiC_zvY2ZWk3FRzs0RZV9vBOBvOaYyhCINuAc4rYqnmA6Pm6]home.rr@c...[/url
    Verzonden: zondag 18 januari 2004 23:40
    Aan: basicstamps@yahoogroups.com
    Onderwerp: [noparse][[/noparse]basicstamps] Re: A/D question
    > taining
    > > Engineer.
    > my
    > > needs.
    > be
    > mv
    > I've
    > > Russ Ranshaw
    > Hi Russ,
    > the range you need.
    > Dave
    exact title?
    Russ
    Yahoo! Groups Links
    edited 2004-01-19 16:13
    wrote:
    > Russ,
    format.
    voltages, you
    with a
    TLC2543. Note
    if you
    too. Don't
    putting a
    limit
    > Jonathan
    > www.madlabs.info
    > > Jonathan,
    > > Russ
    > > wrote:
    > > > Russ,
    > > directly in
    resolution, but I
    > > vRef of
    > > > Jonathan
    > > > www.madlabs.info
    taining
    > > > > Engineer.
    for my
    > > > > needs.
    millivolt
    will be
    the 100 mv
    presume
    since I've
    > > > > Russ Ranshaw
    > > Subject and
    > > > > Yahoo! Groups Links
    Subject and
    > > Yahoo! Groups Links
    Jonathan,
    The DC voltages are arbitrary. I can scale them to any needed range,
    as the actual voltages are much higher (50 to 100 volts). So this
    isn't really a problem.
    I just ordered a TLC2543 plus a box full of other goodies. I did find
    the TLC2532 data sheet as was suggested, even found a suppler. Never
    found it on the Parallax site.
    I'd like to discuss the project with you off-line if you wouldn't
    mind. I'm not quite ready to discuss it on an open forum. I think
    you might be interested in the application.
    Russ
    Try this URL:
    <http://www.emesystems.com/OL2tlc2543.htm>
    -- Tracy
