SERIN with VB6
I'm having trouble with a very simple program receiving data from
VB6 via SERIN. In VB6 I'm sending either a "1" or "0" to the SERIN
on my basic stamp. My settings for MScomm1 are 9600,n,8,1. Here is
my program for the Stamp:
'{$STAMP BS2}
'{$PORT COM1}
'{$PBASIC 2.5}
datain VAR Byte
check_data:
SERIN 16,4054, [noparse][[/noparse]datain]
IF datain = "1" THEN GOTO on_sub
IF datain = "0" THEN GOTO off_sub
on_sub:
HIGH 0 ' Turn LED ON
GOTO check_data
off_sub:
LOW 0 ' Turn LED OFF
GOTO check_data
When I click on either the send "0" or send "1" it turns the LED
on. It is suppose to turn on with "1" and off with "0". I'm sure
I'm making some simple mistake, but I've been working on this for a
week and it's bugging me!
Thanks for your help!
Adam
'{$STAMP BS2}
'{$PORT COM1}
'{$PBASIC 2.5}
datain VAR Byte
check_data:
on_sub:
GOTO check_data
off_sub:
GOTO check_data
Adam
The manual has, on page 297, a table of baud rates
to baud selectors.
For 9600,n,8,1, out the '16' port, on a BS2,
you should use:
I9600 CON 16384 + 84 ' 16384 == 'Inverted' (with driver)
' 84 == 9600 baud,n,8,1
' OR, I9600 CON 16468
--- In basicstamps@yahoogroups.com, "sumguy16hem" <a.przybilla@c...>
> '{$STAMP BS2}
> '{$PORT COM1}
> '{$PBASIC 2.5}
> datain VAR Byte
> check_data:
> on_sub:
> GOTO check_data
> off_sub:
> GOTO check_data
> Adam
that should be hex, $4054.
helpful if you insert a GOTO check_data at the end of this routine to keep
from "falling through" into the on_sub.
check_data:
GOTO check_data
-Bruce
tech@r...
http://www.rentron.com
> '{$STAMP BS2}
> '{$PORT COM1}
> '{$PBASIC 2.5}
> datain VAR Byte
> check_data:
> on_sub:
> GOTO check_data
> off_sub:
> GOTO check_data
> Adam
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
longer numbers other than boolean "1" or "0" through the SERIN
command.
thanks,
Adam
http://www.parallax.com/dl/docs/cols/nv/vol3/col/89.pdf
-- Jon Williams
-- Dallas Office
From: sumguy16hem [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OP8ULMgQyufAQirIej7rNUsG5cpzJpnf86oKdLwbhZAeccDZtCN7996JIm6o7jx4XQCAVZDsiYp26a4EZ8hqJBWG]a.przybilla@c...[/url
Sent: Thursday, January 15, 2004 5:47 PM
Subject: [noparse][[/noparse]basicstamps] SERIN with VB6
How would I go about sending other data i.e. strings(words) or
command.
thanks,
Adam
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
