Bluetooth eb500
Archiver
How long should it take for the Embedded Bluetooth transceiver to send a byte to
a pc, and receive a byte from the pc?
On the OPTAscope I'm getting a reading of almost 50 milliseconds. The eb500 is
on the Boe-Bot. SEROUT sends a byte to the pc. Then SERIN reads a byte that the
pc sends right back. Any ideas on why it's taking so long?
According to the Parallax manual, I need to get a pulse out to the Boe-Bot
servos every 10 to 40 ms, so I can't afford 50 ms. Any ideas on how to speed
things up?
things up?
There are a number of factors that effect the timing when sending a byte
round trip from stamp to PC and back to the stamp. I am going to assume
that your stamp and PC are running efficiently and just focus on timing
issues with Bluetooth and the eb500 module.
While the Bluetooth protocol is designed to transmit data reliably at
sustained high data rates of up to 720kbps, it is not specifically
designed for either low latency transfers or timing dependant transfers.
What this means is that if your application requires a latency of less
than 5ms, Bluetooth may not be the right solution for you. Think of a
Bluetooth data transfer a little like TCP/IP over Ethernet in that the
data will arrive intact, but the overall timing with which it will
arrive is a bit unpredictable and will not be the same every time you
send the data. This is simply a tradeoff in the way the protocol is
defined. Bluetooth emphasizes throughput, reliability, and low power
operation rather than low latency.
The eb500 is configured by default to negotiate connections that lean
towards power savings rather than low latency. Specifically it supports
two Bluetooth low power modes called sniff and park. I suspect that the
latency issue that you are seeing is largely due to the eb500 module
entering sniff mode between bytes and then having to come out of sniff
mode to transmit. Sniff mode is a low power state that is negotiated
between the two radios when the connection is established. It allows one
of the radios to enter a low power mode for specific negotiated
intervals of time (20ms to 80ms for an eb500) in order to conserve power
when no data is being transmitted. The down side to this is that when
the first byte is sent from a device currently in sniff mode, it must
wait for the interval to expire before sending the data. Subsequent
bytes are sent immediately as long as the data stream is kept constant.
Any significant pause between bytes will allow the radio to go back into
sniff mode to conserve power.
The initial eb500 version 1.0 firmware release does not allow you to
disable these low power modes in favor of a lower latency connection.
While I can not give you a specific time frame, this is recognized as an
important feature and will be added to a future firmware release.
I do however have a suggestion that may help you with your current
project. If you are going to service the sensors and servos on your BS2
based robot, you need to break away from the idea of a tightly coupled
command response loop between the PC and the BOE-Bot. This can be done
in several ways, one of which is demonstrated in the Monkey Do portion
of the eb500 Monkey See/Monkey Do sample. Take a look at the following
code:
CmdData VAR BYTE
'Wait for the eb500 radio to be ready
PAUSE 1000
'Set the initial state to hold
CmdData = 3
Main:
'Wait for a command
SERIN 0,84,[noparse][[/noparse]DEC1 CmdData]
'Process the command
BRANCH CmdData,[noparse][[/noparse]Hold, Turn_Right, Turn_Left, Move_Fwd]
'If the command was invalid, just loop again
GOTO Main
I did not include the motor routines for each action because the
important element here is the main processing loop. The key to the
motors running at full capacity in this scenario is simply that the
controller, the PC in your example, sends commands frequently. The exact
rate at which you need to send commands will vary depending on how much
processing that you are doing. To get a feel for this, try the following
experiment.
1. Load the Monkey Do application (MonkeyDo.bs2) onto your BOE-Bot. This
is documented starting on page 43 of the eb500 manual.
2. Connect to the BOE-Bot via Bluetooth from your PC using
HyperTerminal. This is documented on page 28 of the manual in the
section titled "Connecting a PC with a DBT-120 to a BOE".
3. Open HyperTerminal on the PC and connect to the COM port from step 2.
4. As you type the numbers 1, 2, and 3 into HyperTerminal your BOE-Bot
will move in very small increments. Notice that the robot is quite
responsive to these commands even though the eb500 has sniff mode
enabled.
5. Now hold down the number 1. The BOE-Bot now moves forward smoothly at
full speed. You will notice a delay between the time that you press and
hold the key and the time that the BOE-Bot is moving forward smoothly.
This is due to the way in which the key repeat in HyperTerminal works
and not Bluetooth latencies.
From your sample description it also sounds like you are sending sensor
data up to the PC. This can be accomplished in a similar manner by
simply adding a SEROUT to write the sensor data to the eb500 each time
through the loop. As long as your sensor read time is not really long,
the robot will keep moving at full speed.
I hope that this clarifies the timing issues for you. Let me know if you
have any further questions.
Bryan Hall
A7 Engineering
www.a7eng.com
From: Steve Nelick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tgSc7gXxABvH7R952vnnPNTn5BzQsv4cZmqkeRI9pptn4py1lW6xR5UbOgtd3CcdWg4s_Yf_iCbezTMG]s.nelick@v...[/url
Sent: Tuesday, January 13, 2004 6:30 PM
Subject: [noparse][[/noparse]basicstamps] Bluetooth eb500
byte to a pc, and receive a byte from the pc?
eb500 is on the Boe-Bot. SEROUT sends a byte to the pc. Then SERIN reads
a byte that the pc sends right back. Any ideas on why it's taking so
long?
Boe-Bot servos every 10 to 40 ms, so I can't afford 50 ms. Any ideas on
how to speed things up?
Thanks for the information on the EmbeddedBlue 500. That's a powerful
device! I had no idea it worked that way.
When I read the instructions for the eb500, I saw the SERIN 0,84, and I
assumed the Bluetooth was running at 9600 baud. I started programming the
BS2 to work like the program in the StampWorks Experiment #31 Serial
Communications.
When I sent a byte to over to the Boe-Bot and back to the pc, I was
disappointed to see that it took 50 ms. So I spent all day yesterday running
tests. First, I blamed the problem on Python, and I switched to C++, but the
timing results were the same. Then I thought the problem was the eb500, so I
started sending bytes between a pc and a notebook computer.
If I sent 1 byte over and back, 1,000 times, it took 30 seconds. But, if I
sent 100 bytes over and back, 1,000 times, it only took 32.2 seconds. How
could 99,000 bytes go over and back in 2.2 seconds!
My wife kept asking me if I was O.K. She said I seemed to be in a highly
agitated state, walking around the kitchen in circles. I said I'm having a
problem with the robot. Eventually I got a bottle of gin and fell asleep.
When I got your note I went back to the my test results, and there it was:
99,000 bytes X 8 bits per byte X 2 (over and back) in 2. 2 seconds
That's the 720 kbps that's in your note.
____________
Sent: Wednesday, January 14, 2004 7:56 PM
Subject: RE: [noparse][[/noparse]basicstamps] Bluetooth eb500
> Hello Steven,
> code:
> CmdData VAR BYTE
> PAUSE 1000
> CmdData = 3
> Main:
> 'Wait for a command
> GOTO Main
> experiment.
> enabled.
> Bryan Hall
> A7 Engineering
> www.a7eng.com
> From: Steve Nelick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E3FBBBn4i6e81BjjBtjsy4GusTS8ZPN0ZtdNzN-yya4-3MCYZ7r2Av5lH3tO62TspwlmSMdEdpyOlm4Xnw]s.nelick@v...[/url
> long?
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
I have a question.
Is there any reason that the eb500 can't be connected to the debug
port instead of the normal I/o pins? Just curious. By the way, so
far, the eb500 is running pretty good, though I have found a bug in
the IPAQ that I've fixed. Still having a little trouble getting the
transmit eb500 to ipaq or PC working right. very sporatic results,
though it does connect. Took me a long tome to figure out the bug in
the IPAQ so I hav'ent been able to concentrate on the BL transmit
stuff. The recieve works superb though. You should consider making a
version of it that hangs off the debug port.
Anyway, the remote control of the hexcrawler works fine. All of the
troubles so far have been on the IPAQ and the NSbasic though as I
said, I still haven't got the transmit stuff working to my
satisfaction. I don't think it is the eb500 though, i think it's the
IPAQ.
You should also consider making a module with a SMA connector on it
for standard bluetooth antennas. I'm still planning on dadding the
eb500 to my own little project, just not there yet.
--- In basicstamps@yahoogroups.com, "Steve Nelick" <s.nelick@v...>
wrote:
> Hello Bryan,
powerful
and I
programming the
Serial
> Communications.
yesterday running
C++, but the
eb500, so I
But, if I
seconds. How
highly
having a
asleep.
it was:
2 seconds
> ____________
> From: "Bryan Hall" <bryan@f...>
> > Hello Steven,
sending a byte
assume
timing
reliably at
specifically
transfers.
of less
of a
that the
will
time you
is
power
lean
supports
that the
module
sniff
negotiated
allows one
conserve power
when
must
Subsequent
constant.
back into
you to
connection.
recognized as an
current
your BS2
coupled
be done
portion
following
> > code:
> > CmdData VAR BYTE
> > PAUSE 1000
> > CmdData = 3
> > Main:
> > 'Wait for a command
> > GOTO Main
the
the
The exact
how much
following
> > experiment.
Bot. This
step 2.
BOE-Bot
quite
> > enabled.
smoothly at
press and
smoothly.
works
sensor
by
each time
long,
know if you
> > Bryan Hall
> > A7 Engineering
> > www.a7eng.com
> > From: Steve Nelick [noparse][[/noparse]mailto:s.nelick@v...]
to send a
milliseconds. The
SERIN reads
taking so
> > long?
the
ideas on
Subject and
> > Yahoo! Groups Links
>> to the debug port instead of the normal I/o pins?
To connect the eb500 to the debug port for communications is fairly
simple. All that you need to do is level translation between the
eb500s 5V TTL levels and the debug ports RS232 levels. You will only
need to do this for the transmit and receive line, but you will also
need to connect the stamp ATN line to ground.
For Stamp programming the situation gets a bit more complex because
of the control signals used to detect the device and reset it before
firmware downloads. This is not possible with the eb500, but A7 is
working on an standard RS232 version of the module that will support
both wireless programming and debugging.
>> connector on it for standard bluetooth antennas.
This is currently in the works but will most likely take the form of
an MMCX connector rather than an SMA. The MMCX connector is quite a
bit smaller and will allow substantial reduction in PCB size. Keep
an eye on both the Parallax (www.parallax.com) and A7 Engineering
(www.a7eng.com) sites for further details as they become available.
Talk to you soon,
Bryan Hall
A7 Engineering
bhall@a...
--- In basicstamps@yahoogroups.com, "Dave Evartt" <davee@a...> wrote:
> Bryon,
> I have a question.
in
the
in
a
the
the
> IPAQ.
it
trouble getting the ipaq to recieve data using NSBASIC.
Transmitting was fine. I've figured it out and here is what
happened.
Turns out that there were two problems reciving on the IPAQ
from the eb500.
First, the recieve port (com5) is not the port that is used.
Even though the Bluetooth manager says com5, it really is
using com8, which is the bluetooth output port. It uses the
same port number for both, though it may be handled
internally just to make you think it is the same port, in
which case, they should not tell you that it's using two
seperate ports. You can't change the port assignments anyway
so there's no real reason to mention a two port setup when
the software knows it's all on the same port.
Second, The NSBASIC addobject statement does not initialize
the comm object properly if it is not declared a certain way.
It is apparently common to declare the comm object with the
following line;
addobject "comm"
While this will work and not generate errors, it also will
not generate oncomm events that make it easy to handle data
coming in.
addobject "comm","comm",0,0,0,0
is the proper way to do it. This is undocumented and likely
to be the single biggest issue with using NSBASIC and
bluetooth on the IPAQ.
Once these two problems were identified, things work out
very well.
There is a tool you might consider building to make it
easier to integrate bleutooth enabled applications and that
is a way to open a specific device from with a VB program
running on the pocket pc. As it is, you have top select a
bluetooth device when the com port gets open. It would be
nice to be able to call a function in VB that would open a
specific device just before we open the com port so the
selction process is transparent.
The thing I'm trying to do requires that the list of
bluetooth devices, all eb500s, be listed inside the program.
This in itself is easy enough to do, but the function call
to open a bluetooth device is currently unknown, though I'm
sure it is available. Since I'm new to the CE, there is
still a lot too learn on it.
Of course, this will all be mute when A7 lets us name our
own devices. Any idea when this feature will become
available? I'm will to play alpha or beta tester. My
bluetooth experience goes back a few years.
Keep up the good work and please have someone email me a
quote for 1000 boards. I'm planning on using the eb500 in my
product (i already told you that) I need to know how much
it's going to set me back with the money people when I pitch
it to them. I don't know if they will go for it, but it
would be nice if they do.
Thanks.
---- Original message ----
>Date: Wed, 21 Jan 2004 09:02:45 -0000
>Subject: [noparse][[/noparse]basicstamps] Re: Bluetooth eb500
>Hi Dave,
is fairly
between the
will only
will also
because
it before
but A7 is
will support
the form of
quite a
size. Keep
Engineering
available.
>Talk to you soon,
>Bryan Hall
>A7 Engineering
>bhall@a...
<davee@a...> wrote:
>> Bryon,
>> I have a question.
the debug
way, so
found a bug
>in
getting
>the
results,
the bug
>in
transmit
consider making
>a
All of
>the
though as I
my
think it's
>the
>> IPAQ.
connector on
>it
dadding the
the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
Regards
Dave Evartt
American Hovercraft
I just emailed you off list with bulk pricing of the eb500. With
bulk pricing, the manuals and cd's are not included and the product
must be purchased in sets of 10, 100, or 1,000. If others are
interested in bulk pricing you may email me off the list.
The team at A7 has reviewed your feedback and will take it into
consideration.
Sincerely,
Erik Wood
ewood@p...
--- In basicstamps@yahoogroups.com, Dave Evartt <davee@a...> wrote:
> Thanks, by the way, you'll remember that I was having
> happened.
> from the eb500.
> following line;
> addobject "comm"
> coming in.
> very well.
> Thanks.
> >Hi Dave,
> is fairly
> between the
> will only
> will also
> because
> it before
> but A7 is
> will support
> the form of
> quite a
> size. Keep
> Engineering
> available.
> >Talk to you soon,
> >Bryan Hall
> >A7 Engineering
> >bhall@a...
> <davee@a...> wrote:
> >> Bryon,
> >> I have a question.
> the debug
> way, so
> found a bug
> >in
> getting
> >the
> results,
> the bug
> >in
> transmit
> consider making
> >a
> All of
> >the
> though as I
> my
> think it's
> >the
> >> IPAQ.
> connector on
> >it
> dadding the
> >Yahoo! Groups Links
> Regards
> Dave Evartt
> American Hovercraft
What you are experiencing is known in the data communciations arena as
"round trip delay". That is, the time to send a message, have the
message transit the communication link (which may involve several
nodes), be received, delivered to the waiting application, and the
same as above for the application to get its message delivered to the
initiating application. 50MS is FAST by the standards I'm used to!
I suggest that, given the behavior of the eb500, you maintain a
continuous stream of data going between the two ends (ie, over the
eb500 link). For example, you could use the ASCII character SYN which
both ends would ignore. Determine the maximum time you can wait
between transmissions to prevent your end from going into "sniff"
mode. Make sure you transmit a SYN well short of that time. Do this
on both ends. This way the link will be kept active and you probably
will get the response you need.
It takes about a millisecond to send a byte at 9600 bps plus
propogation time. (Actually 10/9600 ths of a second.)
Hope this helps!
Russ
send a byte to a pc, and receive a byte from the pc?
The eb500 is on the Boe-Bot. SEROUT sends a byte to the pc. Then SERIN
reads a byte that the pc sends right back. Any ideas on why it's
taking so long?
on how to speed things up?
