Simple Car Alarm
Archiver
Whats up,
Im using the BS2 to complete a project at school and im having a
little trouble coding my alarm portion of the code. Its just a
basic alarm that reads two magnetic door sensors and sets off a
siren if activated. Has anybody had any experience in an automotive
application for such an alarm?? Im using the Linx 5-channel Rf key
fob and reciever setup that plugs in my education board. Any help
on the alarm coding would be greatly appreciated.
Derek
Atl, GA
Derek
Atl, GA
Here maybe some help
Lets assume you connected the Linx outputs 1 through 5 acordingly to inputs
0 through 4 of the stamp (we will only use Input 1 and 2 for now, but there
all connected)
and your magnetic switch Input 5 of the stamp
and for fun lets connect an LED to output 6 for an alarm decoration
and last but not least the siren. Use output 7 for the siren. carefull we
need a relay to drive a siren. simplest way for this
is to connect a 1 Kohm resistor to the base of an NPN transistor (i use
2N2222). connect one side of a 5v relay to a Regulated 5V power supply NOT
Vdd !! Vcc will work in this case. connect the other side of the relay to
the collector of the NPN transistor. and connect the Emitter to ground of
the regulated 5V and to Vss. you can see this Here
www.turbodeuce.com/images/bs2_to_relay.jpg the picture shows 12v relay but
the same design can be used if you switch a 5vdc realy and 5vdc power
supply.
'(stamp bs2)
LED Var OUT6
Siren Var OUT7
Delay Var Word
Main
If IN0 = 1 then arm
GOSUB LED_Status
GOTO Main
Arm
IF IN5 =1 then Alarm
IF IN2=1 then Disarm
Delay = 500
GOSUB LED_Status
GOTO Arm
Disarm
Delay = 150
GOTO Main
LED_Status
Pause Delay
HIGH LED
Pause Delay
LOW LED
Return
End Of
Program
Hope this helps. Good luck with your alarm...
Gary Denison
Kyocera Wireless Corp
GaryD@k...
Sent: Tuesday, January 13, 2004 3:34 PM
Subject: [noparse][[/noparse]basicstamps] Simple Car Alarm
> Whats up,
> Thanks
> Derek
> Atl, GA
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
'(stamp bs2)
LED Var OUT6
Siren Var OUT7
Delay Var Word
Timer Var Byte
Main
If IN0 = 1 then arm
GOSUB LED_Status
GOTO Main
Arm
Delay = 500
GOSUB LED_Status
GOTO Arm
Disarm
LOW Siren
Delay = 150
GOTO Main
LED_Status
Pause Delay
HIGH LED
Pause Delay
LOW LED
Return
Alarm
HIGH Siren
Loop
Timer = Timer + 1
if timer = 60 then Siren_off ' this will ensure the alarm will
shut off after 60 Sec. You must hold Disarm button 1 sec to Disarm Alam.
Pause 1000
GOTO Loop
Siren_off
LOW Siren
GOTO Arm
___________End of program____________________
Sorry About that
Good luck
Gary D
Kyocera Wireless Corp.
