Write to EEPROM / Serial out problem
I'm trying to store 16 samples in the EEPROM and then serial out put
them to a PC when input 1 is pressed.
1)Could somebody tell me why my program want show/write any EEPROM
memory locations used in the memory map.
2)The serial out statment I'm also stuck on as I need to get the
data from the EEPROM memory locations.
'{$STAMP BS2}
'Data Logger Assignemt
'BS1.bs2
'G Evans
'January 2004
MaxSamples CON 16
ADC CON 11 ' pin slect active low
DIO CON 14 ' Data Pin
CLK CON 13 ' Sets clock pin to 13
TX CON 16 ' Sets transmission pin to
16
N9600 CON $4054 ' Sets baud rate as a
constant
NSamples VAR Byte ' Counts the number of
samples taken
add VAR Word ' Address to write sample
value in EEPROM
Sampval VAR Word ' Store for ADC value
SampValLo VAR SampVal.LOWBYTE
SampValHi VAR SampVal.HIGHBYTE
Value VAR Word
adcctrl VAR Nib ' ADC control nibble
adcchan VAR adcctrl.BIT0 ' ADC channel number (alias)
adcctrl=%1101: adcchan=1 ' Set up ADC control nibble
and channel no
DIRS=$00 ' Sets Input pin 1 as start
buttom
OUTPUT 7
'---[noparse][[/noparse]Main program]
StartDelay:
IF IN0=0 THEN Startdelay: 'If input 0 is 1 then start
data capture
Again:
PAUSE 250 ' pause statement to take 4
samples per second
GOSUB READADC ' Read ADC value and then
return to main program
'DEBUG CLS, DEC Sampval ' clear debug screen then
display dec sampval
DEBUG "Sample value ", IHEX sampval,CR
value=sampval
WRITE add,value.LOWBYTE ' write data to EEPROM
WRITE add+1,value.HIGHBYTE
Nsamples=Nsamples + 1 ' Increment count number
IF Nsamples =>Maxsamples THEN Fin1: ' finish data collection when
Max number of samples-
' reached
GOTO Again
Fin1:
OUT7=1
RoutineDelay:
IF IN1=0 THEN Routinedelay: 'If input 1 is 1 then carry on
program and transmit
SEROUT TX,N9600,[noparse][[/noparse]0-010] 'Transmit data from EEPROM to
serial port
DEBUG ? "Spend data to serial port" ' test statment to check out
operation
END
'---[noparse][[/noparse]ReadADC]
ReadADC:
LOW ADC
SHIFTOUT DIO,CLK,MSBFIRST,[noparse][[/noparse]adcctrl\4]
SHIFTIN DIO,CLK,MSBPOST, [noparse][[/noparse]Sampval\12]
HIGH ADC
RETURN
'{$STAMP BS2}
'BS1.bs2
'G Evans
'January 2004
MaxSamples CON 16
16
constant
samples taken
value in EEPROM
Value VAR Word
and channel no
buttom
OUTPUT 7
StartDelay:
data capture
Again:
samples per second
display dec sampval
value=sampval
' reached
GOTO Again
Fin1:
OUT7=1
RoutineDelay:
serial port
operation
END
ReadADC:
LOW ADC
HIGH ADC
RETURN
Suggestions:
1. Take a closer look at the values the variable "add" will take
during sampling.
2. You must READ the values back from EEPROM into variable space in
order to then SEROUT them.
Steve
