PCB etching
Archiver
I'm working on a soccer robot and am up to etching the PCB. I've
got pretty much all the equipment. Now, I'm not sure whether to do
it manually with an etch resistant pen, or to use a comptuer program
and use a toner etch resist transfer.
The problem I see with doing it manually is that I need some kind of
a stencil to draw the sections where the IC's are going to go and so
on.. Does anyone know of such a stencil and where I could get one?
The problem I see with doing it with a computer program is I can't
find a program where I can design it (with all the symbols aready in
the program) and then print it where it's 1:1 with the PCB I've
designed?
If any of you could help me out with eiter of these I'd really
appreciate it.
James
designed?
appreciate it.
James
Output is 1:1 with the real PCB. Is has some big libraries with lots
of components.
There is more software like this, so the software should not be a
reason to go manual. http://www.cadsoft.de/
Peter
--- In basicstamps@yahoogroups.com, "James Dang" <ensignkim113@y...>
wrote:
> Hi,
program
of
so
in
> designed?
> appreciate it.
> Thanks
> James
http://tinyurl.com/2vp95).
However, if you have access to Linux or you will install Cygwin (the Linux
that runs over Windows more or less) you can run PCB which is OK
(http://pcb.sourceforge.net/). Last time I looked, it doesn't really
integrate with gSchem for schematic capture in any meaningful way. The
version I have running required some tweaks to work on Cygwin, but I see
they recently have it building under Cygwin "out of the box".
It isn't Eagle, but it does work.
Al Williams
AWC
* NEW: Universal PCB mounts Stamp, SX, or virtually any CPU
http://www.al-williams.com/gpmpu40.htm
From: James Dang [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y_ejAHp13jpRx4_2wsF7vw8lEOHYIDJvu7yiAEkjgqljxv_riYlpemN2GeffyzvQlZFJ8C-XhrwGJuZ8Mxf6yA]ensignkim113@y...[/url
Sent: Monday, January 12, 2004 6:16 AM
Subject: SV: [noparse][[/noparse]basicstamps] Re: PCB etching
yeah thanks, the package looks quite good, although it's a pity
about the 8 by 10cm restriction. The board I'm thinking to create
is about a semicircle with 10 and a half cm radius, so it's quite
large, the thing is, I think I may need all that space.
If anyone else knows of any other software without any size
restrictions any help would be appreciated.
James
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
wrote:
> Hi,
program
of
so
in
> designed?
> appreciate it.
> Thanks
> James
If you are new to schematic software, try WinQCad. This is much
simplier than Eagle to learn and the free version is limited to 500
pins and something like a 2 inch square board.
And, believe it or not, there is an ASCII CAD that will allow you to
draw with ASCII characters and then turn that into traces and pads.
Another program and one that offers a lot of stuff to the beginner is
ExpressPCB. The problem with Express is that you cannot get a black
and white print.
As far as the toner transfer, check the group
http://groups.yahoo.com/group/Homebrew_PCBs/
Seems they love TIME magazine paper for it's high clay content.
I toner transfer, then with a magnifyihg glass, check for poor traces
and use a pen (They also discuss the pens to use) to fill in the
blanks.
Dave
I use the laser printer toner method. Etch pens for larger circuits are a
pain, I would go to perfboard before I used a pen.
I find that complex circuits made with most CAD programs don't transfer that
well. The transfers seem to like blocky, square style art for the best
results. Even so, a little touch up with a pen is usually required. I also
always seem to want to do oddball stuff which is never in a library. So, odd
as it may seem, I use Photoshop to make PCB art. I have accumulated a lot of
part art, so I can usually cut and paste. I use different layers for pads,
traces, mask, etc. Here is a link to the most complex circuit I have made
with this method:
http://madlabs.info/index.php?x=h2fc_rcom.jsp
While the art isn't on the page, you can see the PCB and get an idea of the
complexity of the circuit.
Here is a page that has a small piece of art drawn as described:
http://madlabs.info/index.php?x=ir_remote.jsp
The other nice aspect for me is that the boards can easily be made "student
friendly", with large pads and spacing. Since many of my projects are built
by students, this is a plus for me.
All that said, I am fooling around with Eagle too. The only reason I am
doing so is to be able to send out boards when I want a number of them. One
off's I will still make the old way.
Jonathan
www.madlabs.info
Sent: Sunday, January 11, 2004 10:49 PM
Subject: [noparse][[/noparse]basicstamps] PCB etching
> Hi,
> designed?
> appreciate it.
> Thanks
> James
> Yahoo! Groups Links
I am
them. One
> Jonathan
> www.madlabs.info
Express is great for learning and their mini-board service.
They offer a flat fee to supply the gerber files of boards you have
already made with them. Kinda costly.
Eagle is kinda pricy if you don't fall under their student program.
And WindQCad offers an unlimited board size for $100.00, but does
limit the pins to 500 actual part pins, not thruholes from traces.
Each has it's merits.
Dave
> Now, I'm not
> sure whether to do
> comptuer program
> need some kind of
> going to go and so
> could get one?
James, what I have done in the past is draw the layout
using a piece of graph paper. Each point where the
lines cross would resemble a hole on a soldering ring
board. I would map the layout onto the graph paper
putting IC holes exactly 1 space apart. Then I would
use a piece of wire-wrap or solder-ring PCB from Radio
Shack to lay over the blank PCB. Then using my Dremel
(Or Dremel drill-press)and a small bit, I would drill
in the holes where I wanted them on the resulting PCB.
This way I am "Pre-Drilling" my PCB. Then I would
hand-draw out the rest of the layout, and where the IC
and component pins would go, I would draw a ring
around the hole using a fine-point Sharpie. This
works great for Prototype boards with a single layer.
I never had much luck with Double Layer and have used
PCB Express for that. Hope this helps.
> program is I can't
> symbols aready in
> the PCB I've
> designed?
> I'd really
> appreciate it.
> Thanks
> James
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
