Servo usage with power supply!!
Hi guys,
When i purchased the basic stamp board of education kit - full kit,
with a rev. B board, a rev. F BS2, it also came with a power
supply. I wanted to know if I could use the power supply when
running my servo which is controlled by the basic stamp or is my
only option to use a 9 volt battery? Theres a warning that said the
servo recieves power from the VIN, meaning i shouldn't use anything
above 6.5VCD when using the servo. I checked the appendix for one
of the tutorials on "what is a microcontroller" and it said when
using BOE rev. A/B boards, use a 9 volt batter, or a 6 volt battery
packing using AA batteries or a DC supply that provides exactly 6
volts regardless of the current draw. When i read the back of the
power supply that came with the kit, it says its output is 9VDC
300mA. Once again my question is just, if i could use this given
power supply to power the servo and everything attached to the board
ie. a few IC's, small series circuit.... or resort to buying more 9
volt batteries (i don't wanna use the 6 volt AA battery option).
Thank you for taking the time to read this, I tried to make it as
clear as possible my situation.
ll_deep_soul_ll@y... writes:
You can use any power supply you want, but if you are using the servo port
your power supply must be a 6 volt battery. If you want to use the servo
with a 9 volt battery or wll power supply, the servo must be plugged into the
breadboard and power patched to it from the Vdd terminal.
Sid Weaver
W4EKQ
Port Richey, FL
on the back on the BOE it looks to me that both the 9 volt battery and the
wall wort power supply are connected to the same line which is fed into the
voltage regulator on the BOE. Why shoud a battery power the regulator any
differently than the Wall wort?
I am also doing the experiments in WAMC student book.
> [noparse][[/noparse]Original Message]
> From: ll_deep_soul_ll <ll_deep_soul_ll@y...>
> To: <basicstamps@yahoogroups.com>
> Date: 1/11/2004 10:25:05 AM
> Subject: [noparse][[/noparse]basicstamps] Servo usage with power supply!!
> Hi guys,
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
the default trace routes Vdd to the servo power connection. You can cut
a trace and solder a jumper to route Vin instead. The Rev C BOE now
includes a shunt that allows you to select between Vdd and Vin for the
servos.
-- Jon Williams
-- Parallax
From: Shawn Lowe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=99VX5T7jssXP4Uira-zKo8lP7gNNfA4BiMLRwssgSUBP6AZCbJ88pH0EaDgQe7_LYSVowQrhZjW-4zlY2ZlhYaWZ]livinlowe@e...[/url
Sent: Sunday, January 11, 2004 12:40 PM
Subject: RE: [noparse][[/noparse]basicstamps] Servo usage with power supply!!
I admit this is confusing me too. When I look at the circuit board
traces on the back on the BOE it looks to me that both the 9 volt
battery and the wall wort power supply are connected to the same line
which is fed into the voltage regulator on the BOE. Why shoud a battery
power the regulator any differently than the Wall wort? I am also doing
> Hi guys,
> and
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
jwilliams@p... writes:
> I'm in a hotel at the moment without access to a Rev B BOE, but I think
> servos.
Hi, Jon
Just measured the servo port. Default trace is Vin.
Where are you - Holland?
Sid
located just below the 4 servo hook up spots.
Yes, mine seems to be connected to Vin as well.
> From: <Newzed@a...>
> Date: 1/11/2004 2:22:01 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Servo usage with power supply!!
> In a message dated 1/11/2004 4:15:40 PM Eastern Standard Time,
> > servos.
> Hi, Jon
> Sid
> Yahoo! Groups Links
