Dang, my loop is to slow... — Parallax Forums
edited 2004-01-12 15:51 in General Discussion
Greetings all,
I'm trying to run the following FOR/NEXT loop.
It works fine, but I was rather astonished that it
takes aprox 1.2 milliSeconds between repetitions
For my application I need to get it down to about 500 microSeconds...
Is that going to be impossible with the BS2, or is there a
"faster way" to write a loop to pulse a pin "X" number of times
depending on the number in a variable.
'{$STAMP BS2}
'{$PBASIC 2.5}
index VAR word
count VAR word
count = 5678
FOR index = 0 TO count
PULSOUT 9, 100
NEXT
END
Thanks much!
Steve
    edited 2004-01-11 01:18
    How fast does it have to be? Right now your pulsout os 200us.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2004-01-11 01:45
    Yes, pulsout is 200uS. If I set it less than about 150, then
    downstream circuitry has trouble with it.
    But I need to be able to repeat the pulse about every
    600 uS. About twice as fast as it runs now. Just wondered
    if there was a faster way to do the loop. I think maybe I've
    got myself screwed into a corner and just need a faster device...
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    index VAR word
    count VAR word
    count = 5678
    PULSOUT 9, 100
    NEXT
    END
    Steve
    edited 2004-01-11 04:59
    That timing sounds about right for a BS2 running that loop. I'm not clear
    exactly how the signal is being used downstream, but it sounds like a
    clocking function. It's fairly straightforward to build an external circuit
    to provide that clock pulse and then enable it with the Stamp pin instead of
    actually creating the pulse from the Stamp. Would a 2 kHz clock with a pulse
    width of 200 us be what you're trying to create?
    Gary
    edited 2004-01-11 05:04
    Hi Steve,
    You could probably do it with a BS2p or a BS2sx, which are at least
    2.5 times faster. But the vanilla BS2 is as you have observed going
    to be too slow. You might find the instruction timing information at
    this url useful:
    <http://www.emesystems.com/BS2speed.htm>
    (FOR:NEXT) loops are relatively slow. The timing info I have at that
    URL for the BS2 gives 763 microseconds for each FOR:NEXT, and 220 to
    set up each PULSOUT, and 200 for the pulse itself. That adds up to
    1183 microseconds, which is close to the 1.2 milliseconds you
    observed.
    On the BS2SX however, your code with the FOR:NEXT loop would run with
    a total time of 600 microseconds, and on the BS2P about 20% faster
    than the BS2sx, it comes down to nearly 500, as required, including
    the 200 uS output pulse.
    -- Tracy
    >Greetings all,
    >'{$STAMP BS2}
    >'{$PBASIC 2.5}
    >index VAR word
    >count VAR word
    >count = 5678
    > PULSOUT 9, 100
    > NEXT
    > END
    >Thanks much!
    >Steve
    edited 2004-01-11 05:07
    For i 1 to myVar
    pulsout pin, myOtherVar
    pause 500
    next
    Quoting "Gary W. Sims" <simsgw@c...>:
    > From: <laurasdog@w...>
    > Gary
    > Body of the message will be ignored.
    > Yahoo! Groups Links
    > To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    > To unsubscribe from this group, send an email to:
    > Your use of Yahoo! Groups is subject to:
    edited 2004-01-11 15:47
    >Gary
    Gary, yes I need a clock pulse that I can vary from around 500 Hz
    to almost 2 KHz. The pulse train is a specific number of
    pulses long, with the exact number to be read from a variable.
    It could be anywhere from about ten pulses all the way up to
    several thousand pulses.
    Thanks!
    Steve
    edited 2004-01-11 15:55
    >this url useful:
    Tracy, I must say that as a "newby stamper" I'm finding your emesystems
    site to be incredibly helpful. What a wealth of good info.
    My hat's off to you man!
    Steve
    edited 2004-01-12 02:24
    >> It's fairly straightforward to build an external circuit to
    >> pin instead of actually creating the pulse from the Stamp.
    >> Would a 2 kHz clock with a pulse width of 200 us be what
    > 500 Hz to almost 2 KHz. The pulse train is a specific number
    > of pulses long, with the exact number to be read from a
    > variable. It could be anywhere from about ten pulses all the
    > way up to several thousand pulses.
    Okay, for what it's worth, here's how I'd go about designing such a circuit.
    I suspect one of our number will be able to tell you "buy a Widget 409 and
    read the app notes" but personally I don't know a specific part off hand. It
    may help to see how I would go about finding what I need if this were my
    application. Grabbing a catalog is not helpful until I understand what I'm
    trying to find. So I would build a notional circuit in my mind like this:
    Requirements: what do we need to control?
    1. The pulse frequency: a range from 500 Hz to 2 kHz.
    2. The pulse count. Must be exact -- not based on time duration, but an
    actual count.
    We do NOT need to control the pulse width. We can let it arise from our
    other design choices within reason. From your earlier comments, I infer that
    we can choose a convenient pulse width for all frequencies, so long as it
    meets a minimum width required by the downstream circuits. 200 us I believe
    you said, and a fifty percent duty cycle at 2 kHz would provide a pulse
    width of 250 us. So as we choose parts we can keep in mind "about 250 us"
    without creating other problems.
    Now creating pulse trains of this frequency is not a job for interpreted
    software. If we ran into this need every day, Parallax easily could put such
    a function into firmware, but it's not common enough for them to have
    considered it I'm sure. Besides, we tie up the microcontroller completely if
    we use it to generate a long pulse train, and we might have other useful
    things to do. (Even at 2 kHz, thousands of pulses takes more than one
    second, and that's a very long time to a microprocessor.) So we want to
    control the creation of each pulse train from our PBasic program in the
    Stamp, but we'll generate it externally.
    For the sake of simplicity, I'll assume we can spare enough pins on the
    Stamp to output the pulse count value in parallel. That is, we can use a
    statement like:
    OUTL=PulseCount
    to put the count on the pins where it can control the external circuit.
    Actually, I assume we will need at least ten pins since you specified a
    count "into the thousands" but I won't complicate that example by adding the
    code to put all ten bits on the output pins.
    Obviously, the simplest device to do all this would be a single integrated
    circuit. If we can find one, it will be called something like: "count-down
    counter with oscillator." I'll describe the use of this hypothetical perfect
    chip first, and then talk about how to divide up the functions if we can't
    find a single "perfect" chip that does the job.
    It will have 10 to 14 pins that are how we enter the starting value for the
    count. Those pins will latch the presented value when we put a high on a pin
    called "enable input" or something similar. The counter will begin to count
    down when we put a high on a pin called "enable count" or, again, something
    similar. Obviously, in accordance with the whims of chip designers, either
    enable pin might require a low instead of a high, but we don't care about
    such differences until we actually start to wire and code.
    The oscillator part of that chip name means it has pins for a resistor and a
    capacitor -- or perhaps just a resistor, with the capacitor on board
    already. This will be how we control the frequency.
    So the procedure for using this hypothetical chip we'd really like to find
    goes like this:
    Step 1. Set the frequency for the on-chip oscillator. If you have a small
    number of fixed frequencies that will be required, then you can do this
    easily with an analog multiplexer. Dedicating three pins to address this
    chip will give us eight different frequencies, and they can be pretty much
    arbitrary frequencies. I won't get into design tricks unless you actually go
    this way, but an analog multiplexer gives you a simple circuit path from one
    input pin to eight output pins. That's eight different circuit paths. You
    can arrange for each one to present a different resistance to the pins that
    control that oscillator. The Stamp picks the frequency by picking the
    resistance, which it does by picking which output pin is addressed on the
    multiplexer. And it does that by putting the three-bit address on three of
    its own output pins. Simpler to do then it is to say. Much.
    If we need a greater selection of frequencies, and especially if they are
    not pre-determined, then a digital potentiometer will be required. Their
    interface is slightly more complex from a programming point of view, but in
    exchange they provide more possible resistance values. On the other hand,
    those values are not arbitrary, but must fall on a linear scale with a step
    size that is fixed once you buy the pot. App notes abound on using a digital
    pot.
    Now we have set up the oscillator to provide anything from a few hundred to
    a few thousand pulses per second to the counter circuit.
    2. Put the count of pulses required on the output pins of the Stamp. Set
    them to output mode. Pulse the Stamp pin tied to the latch enable with a
    high or a low as appropriate. This will load the count value into the
    counter register.
    3. Enable the counter chip. This will start the emission of pulses.
    Depending on the number of downstream circuits, we may have to feed the
    output pulse of the counter to a driver, but that's a separate part of the
    design.
    4. Hopefully, the chip we chose has a stop-when-count-reaches-zero feature.
    If so, it will have a status pin that we tie to a final Stamp pin so we can
    tell when the pulse train is complete. We can check this pin periodically
    while we do other things, or we can just wait in a tight loop until that pin
    changes state. If it doesn't have such a feature (which seems unlikely)
    there are other ways to stop the pulses when count reaches zero.
    Comments:
    A typical oscillator circuit will output roughly a square wave with a fifty
    percent duty cycle. If our highest frequency is 2 kHz, then the high side of
    that wave will never be less than 250 us. It may be as long as one
    millisecond for the low frequencies. I postulated that we have no need to
    control pulse width, but if pulses too long turn out to be a problem then
    you need to configure a 555 as a one-shot. With that chip, you feed it the
    output of the counter and use the 555 to explicitly control the pulse width
    seen by the downstream circuits.
    It's likely that a counter chip is available with all those functions in one
    form or another. If we have to break this up into multiple chips, it still
    won't be many. First, a 555 will provide the pulse source for us and you
    still control the frequency with a variable resistance, just as I described
    above. Oscillators are pretty straightforward and available in many flavors,
    but a 555 is a standby available at any local five and dime. (Well, okay.
    Any local Radio Shack or equal<g>.) Most important, you can find app notes
    everywhere for 555 circuits.
    The output of the pulse source must be used to pulse a counter set to count
    down. Such counters always have an interface to load the initial value, and
    we simply limit our choices to one that offers a pin that tells us when it
    reaches zero. We use that pin to stop the count if it doesn't already do
    that.
    I don't have time to do a parts search for the specific parts we'd need for
    this circuit, but you shouldn't have too much trouble finding what you need
    on Digikey or Mouser with all those keywords to work with: count-down,
    counter, oscillator, and so forth.
    Send me a private note if I've muddied the water too much. This is one of
    those simple things to do, that take a long time to describe.
    Gary
    Thanks to everyone who responded to my question
    about the speed of running this code on a BS2:
    index VAR Word
    qty VAR Word
    qty = 5678
    FOR index = 0 TO qty
    PULSOUT 5, 100
    NEXT
    END
    It appears that the fastest the BS2 will run it is
    about 1.2 mS per iteration. You guys gave me
    a lot of good ideas and possible work-arounds,
    but I guess the real answer is to put a BS2 in it.
    I tested the same loop with an OEM BS2SX and
    it ran at aprox 500 uS per loop, which is just
    fast enough for my purpose...
    The lesser number of allowable EEPROM writes
    may be a problem for me, but it should give me
    about 3.7 years to find a better solution. (-:
    Thanks all!
    Steve
